matnoor REGULAR
Countries/State : Age : 37 location : Labuan - Gerai bukit Tg. Aru... Points : 11424 Reputation : 3 Number of posts : 390
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 17/4/2009, 12:52 pm | |
| - oyoi wrote:
- ni ikt pnglman aku la kn...kwn aku ni mknek...dia pki iswara 4g13 carb...clutch vr4...dia msin sikit la dia pnya casing gbox...piping 4-1..dpn 2 1/2''...tabung pki yg tonado pnya...pas 2 piping blkang 2'' mafler jasma...carb kurik abs...gear 1=80 gear 2=120 gear 3=abs meter...ni bkn mau tembirang la...tp klu kmu ada cni blh jg aku c tngu kn
kuat tu..huhuhu.. iswara warna apa tu bro?? |
bbr 193 REGULAR
Age : 111 location : SELURUH SABAH Points : 11554 Reputation : 0 Number of posts : 291
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 17/4/2009, 9:30 pm | |
susah untuk di percayai....klu honda fullspec mungkinlah.... vr4 pun nda begini oh larian dia... klu begini punya larian masuk kategori open sudah ni... 3gear 200km sudah ohh.... org bilang sap-sai cong... |
Countries/State : Age : 45 location : Kota Kinabalu-Putatan Tag ID: : SFC02202 Points : 12161 Reputation : 10 Number of posts : 2945
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 18/4/2009, 12:15 am | |
Pendek umur enjin nie, tapi kalau drag setting, tidak heran.... honda VTEC pun boleh kena playang nie... |
matnoor REGULAR
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 18/4/2009, 12:25 am | |
| pipng blakng 2" dpn 2.5" backpressure tu ..huhuhu..mgkin ada kacau dlm blok ni/tukar blok besar..mana tau main piston high compression ratio lebih 11.0 mcm vtec/mivec.. |
bbr 193 REGULAR
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 18/4/2009, 3:29 am | |
| klu 4g15 jak...ko tukar piston apa pun..tetap twincam layan..... |
bbr 193 REGULAR
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 18/4/2009, 3:35 am | |
| - matnoor wrote:
- pipng blakng 2" dpn 2.5" backpressure tu ..huhuhu..mgkin ada kacau dlm blok ni/tukar blok besar..mana tau main piston high compression ratio lebih 11.0 mcm vtec/mivec..
klu 4g92 atau 93 soch mungkin ada cerita.... 3gear 200km.....imposible klu utk 4g15 |
matnoor REGULAR
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 18/4/2009, 4:28 pm | |
| - bbr 193 wrote:
- klu 4g15 jak...ko tukar piston apa pun..tetap twincam layan.....
yup, mmg twincam layan dari sohc..sbb single pnya enjin cam nya bekerja keras untk kemasukan dan keluar utk ekzos..twincam ada dua, cam satu utk masuk satu lg utk keluar..kalau slh tlg btl kan...aku newbie masi huhuhu... |
motec12 REGULAR
Countries/State : Age : 37 location : Tawau Tag ID: : SFC 05325 Points : 11510 Reputation : 7 Number of posts : 488
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 18/4/2009, 5:19 pm | |
| piston 1.6 dan 1.5 oversized proton yang mana bagus...... minta pendapat.... |
matnoor REGULAR
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 18/4/2009, 6:26 pm | |
| aku nda byk info ttg oversize² ni...sbb aku x fhm haha..sbnrnya mcm mn kan org bilang oversize piston ni?? kasi besar piston asal atau tukar piston besar?? kalau kasi besar piston asal aku bingung teramat sgt tu.. |
peng283 SENIOR
Countries/State : Age : 37 location : sabah tawau Tag ID: : SFC 05045 Points : 11951 Reputation : 4 Number of posts : 870
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 18/4/2009, 6:28 pm | |
| wah gear 3 hapis meter 4g13 ka....... mana ada gear 3 hapis meter kalau tukar piston gear 4 hapis la........mana ada gear 3 hapis |
bbr 193 REGULAR
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 19/4/2009, 2:53 am | |
| - motec12 wrote:
- piston 1.6 dan 1.5 oversized proton yang mana bagus...... minta pendapat....
bro klu mo jadi pelumba haram..ko mesti tukar injin....tp klo untuk syok2 ko upgred jak sikit sikit....extractor,trottle body,injector,cam pully cukup sudah.. piston nda boleh d over size bah bro...tukar piston boleh... |
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 19/4/2009, 8:56 am | |
Max bore untuk enjin 4G13/15 ialah dlm 76mm, inipun maximum size yang kira masi selamat untuk ketahanan enjin. Piston bore(Diameter piston) X stroke(Panjang Connecting Rod/Conrod) utk spec enjin 4G1x. 4G11 - 69.5 mm x 82.0 mm 4G12 - 74.0 mm x 82.0 mm 4G13 - 71.0 mm x 82.0 mm 4G15 - 75.5 mm x 82.0mm 4G17 - 72.2 mm x 82.0 mm 4G18 - 76.0 mm x 87.3 mm |
matnoor REGULAR
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 19/4/2009, 10:46 am | |
| hehehe..apa lagi kasi musuk itu piston waja..mcm bro blugu ckp.. tp, stroke panjang..jd bro blugu boleh ka pakai konrod 4g13 blk?? piston 4g18 + conrod 4g13? |
motec12 REGULAR
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 19/4/2009, 1:03 pm | |
| saya rasa msh berat kereta saya.... enjin 1.3 cable spark sparko 10.8, open pod air cleaner (cap ayam).... pastu saya tukar flywheel besar sikit dari 1.3 (ntah aku pun tak tau nama dia)... dan efi standard.... saya mau guna mod yang medium jak.... (streer race) boleh otai beritahu apa yang patut lagi saya buat...... saya nie buta pasal injin.... |
matnoor REGULAR
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 19/4/2009, 4:04 pm | |
| pasang lah racing cam + adjust cam pulley..hehehehe mmg best...puas hati.. |
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 19/4/2009, 4:15 pm | |
| - matnoor wrote:
- hehehe..apa lagi kasi musuk itu piston waja..mcm bro blugu ckp.. tp, stroke panjang..jd bro blugu boleh ka pakai konrod 4g13 blk?? piston 4g18 + conrod 4g13?
pakai con rod waja pun masi boleh bro, kasi kahwin 1.3 conrod & 1.6 piston pun tiada masalah |
oyoi FRESHIE
Age : 35 location : labuan Points : 11102 Reputation : 0 Number of posts : 68
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 20/4/2009, 9:11 am | |
| naa kn...msi kmu xcya...mmg kmu ckp mustahil kn..ada 1 iswara wana hijau atap dia wana hitam...klu kmu xcya...p la tnya dia @ klu kmu tjmpa...test la trus |
tony84 CONTRIBUTOR
Countries/State : Age : 39 location : org twu/stay d kgu/jln2 d kk Tag ID: : SFC 02317 Points : 12276 Reputation : 9 Number of posts : 1300
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 20/4/2009, 9:22 am | |
| - blugu wrote:
pakai con rod waja pun masi boleh bro, kasi kahwin 1.3 conrod & 1.6 piston pun tiada masalah klu pakai vtec piston bule kah???honda sohc punya lah.. |
tar_007 FRESHIE
Countries/State : Age : 39 location : Labuan Points : 11226 Reputation : 0 Number of posts : 31
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 20/4/2009, 9:34 am | |
| - blugu wrote:
pakai con rod waja pun masi boleh bro, kasi kahwin 1.3 conrod & 1.6 piston pun tiada masalah bro, enjin saya 1.3 efi proton. klu d kasi kawin sm 1.6 piston & conrod & pki blok 1.5 (d kasi rebore) bleh ka tu? |
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 20/4/2009, 12:13 pm | |
| - tar_007 wrote:
- blugu wrote:
pakai con rod waja pun masi boleh bro, kasi kahwin 1.3 conrod & 1.6 piston pun tiada masalah bro, enjin saya 1.3 efi proton. klu d kasi kawin sm 1.6 piston & conrod & pki blok 1.5 (d kasi rebore) bleh ka tu? blok 4G13/15 sama ja panjang conrodnya bro, piston waja(4G18 - 1.6) memang boleh.... Rebore saja blok 1.3 tu ke 1.6... |
tar_007 FRESHIE
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 20/4/2009, 1:46 pm | |
| bro, area kk ni , mn bgus ntar keta sya ni p bikin oversize piston ni ah? aku pny injin 1.3 ni leaking truk sdh.. abis d bwh injin sana keluar myk.. d bwh gear box pun keluar myk oo.. tunggu ms sj lg tu mo docking.. heehe |
matnoor REGULAR
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 20/4/2009, 6:45 pm | |
| kalau truk sdh leaking sna sni..alang² bgs kasi tukar la hafkat p mivec kalau kaya hehehe..kalau nda pun 4g91 1.5 atau enjin v6 6A10 1.6 pun ok kalau jmpa ni enjin di kedai hafkat kk.. |
matnoor REGULAR
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 20/4/2009, 6:47 pm | |
| - tony84 wrote:
- blugu wrote:
pakai con rod waja pun masi boleh bro, kasi kahwin 1.3 conrod & 1.6 piston pun tiada masalah klu pakai vtec piston bule kah???honda sohc punya lah.. aku rasa ok kali..lg la hi compression kan.. |
motec12 REGULAR
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 20/4/2009, 10:23 pm | |
| nak tanya lagi.... kalau pakai piston 1.8 (76mm) radiator kena tukar tak? barang asal yang lain kat block 1.5 tu boleh pakai balik tak...... |
matnoor REGULAR
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade 21/4/2009, 6:41 am | |
| boleh pakai...mcm bro blugu ckp kalau ko mo pakai konrod asal 4g15 tiada masalah tp, klu mo pakai konrod waja rebore ja tu blok..ttg radiator tu..aku x brapa pasti kalau bab mit/proton ni..mgkin boleh pakai radiator besar punya..ambil dari 4g92p ka 4g93p ka.. nda mo tukar pun bole jga..kalau tukar utk tujuan safety.. tp bro blugu..apa yg mo di korek itu block 4g13/15 kalau pakai piston waja skali sma konrod nya?? kasi besar itu bore pastu stroke nya?? kan pnjg tu kan? stroke waja 1.6 dari proton 1.3/1.5 ni..pastu kalau stroke panjang dari asal byk brg kena tukar kan? timing belt, pulley bwh..kna pakai waja punya.. |
| Subject: Re: enjin 4g13,15 upgarede normal n full upgrade | |
