    kelisa 850 bolt on turbo
    sherald
    Number of posts : 102
    17012010
    http://i38.servimg.com/u/f3 kelisa 850 bolt on turbo
    Post by sherald
    mau tanya pkar2 klau enjin 850 msuk piston lowcomp pkai tubokit...
    piston apa yg ssuai??
    Post on 17/1/2010, 4:54 pm by Nieto
    bro cadang mahu naik boost tinggi ka ni?
    Post on 17/1/2010, 5:14 pm by MyDeCeMb3r_09
    maw kasi tggi boost ka bus..??nak pkai pistun pa arr..klu blok 1.0..pkai pistun l2s..
    Post on 17/1/2010, 5:40 pm by sherald
    MyDeCeMb3r_09 wrote:maw kasi tggi boost ka bus..??nak pkai pistun pa arr..klu blok 1.0..pkai pistun l2s..
    bgitu la tu kira2 dia tu...hehe
    klau blok 1.0 piston 72mm boleh msuk l2 ka? piston l2 kan68mm
    blok 850 piston bru 66.6mm... boleh msuk piston 4e ka??hehe..
    Post on 17/1/2010, 6:15 pm by oky_da_alung
    piston 4e macam besar 2..cr piston 1.0 seramik..
    Post on 18/1/2010, 3:19 am by sherald
    kereta apa yg pkai piston 1.0 seramik arr?? piston turbo punya ka tu??
    Post on 18/1/2010, 7:37 am by giruk
    sori...menyampuk..cuba ko cari piston dr charade carb turbo...kwn ckp ni piston sesuai masuk blok 1.0..Lg pun tahan lasak...
    Post on 18/1/2010, 3:44 pm by sherald
    giruk wrote:sori...menyampuk..cuba ko cari piston dr charade carb turbo...kwn ckp ni piston sesuai masuk blok 1.0..Lg pun tahan lasak...
    blok sya tu 850 pla tau, bkan yg 1.0, boleh ngam ka tu??
    Post on 18/1/2010, 6:10 pm by xiaomao
    masuk piston kelisa 1000c potong kepala rata supya low compression ja...
    yg penting minyak mesti nak cukup.....1 bar ke bawah ok la tu....
    Post on 18/1/2010, 6:15 pm by giruk
    pkai piston L2 ja la ...senang keja..heheheh
    Post on 18/1/2010, 6:16 pm by Nieto
    l2 muat ka? tidak kecil ka piston l2 masuk block 850 ni???
    Post on 18/1/2010, 6:25 pm by xiaomao
    boleh...jadi 882cc turbo sudah.....kalao piston kelisa 1000cc jadi la 1000cc....
    Post on 18/1/2010, 6:27 pm by MyDeCeMb3r_09
    kecil tuh bro..rsa≤nya la..klu bgs jga cadangan c xiaomao tuh..klu aku pun mmg macam tuh jga..kali la..
    Post on 18/1/2010, 6:28 pm by giruk
    x..piston L2 lebih besar bbanding piston 850..tu blok 850 kena rebore la..so cc up to 882T
    Post on 18/1/2010, 6:30 pm by xiaomao
    giruk wrote:x..piston L2 lebih besar bbanding piston 850..tu blok 850 kena rebore la..so cc up to 882T
    betul....alang2 kasi masuk 2e jak....hehehehehe
    Post on 24/1/2010, 4:46 pm by sherald
    Nieto wrote:l2 muat ka? tidak kecil ka piston l2 masuk block 850 ni???
    l2-68mm, blok850-66.6mm
    mau korek lagi 1.4mm la kan.. bole ka tu?? tiada apa2 efect ka??
    mcmmna dengan conrod dan pin?? mau modfied lgi ka??
    Post on 24/1/2010, 4:49 pm by sherald
    piston 2e brpa mm??
    lowcomp juga ka tu klau msuk blok850??
    Post on 24/1/2010, 5:45 pm by xiaomao
    ya low juga...kalau xsilap 2e piston 72mm
    Post on 26/1/2010, 12:45 pm by sherald
    kreta apa yg pkai 2e ni? turbo ka??
    klau 4e tu starlet 1.3 kan??
    Post on 31/1/2010, 12:12 am by keba
    bleh masuk..
    piston 850 br 66mm++
    piston l2 68mm
    korek block sikit, bleh masuk piston l2..
    nk main boost tgi pn sdp..
    kalau ad slh, tlg btolkn..
    Post on 31/1/2010, 12:22 am by keba
    sherald wrote:kreta apa yg pkai 2e ni? turbo ka??
    toyota 6silinder turbocharged..kalau xsilap la..
    ak xingat model mn 1..
    piston turbo..72mm
    max boost 1.5bar
    Post on 12/2/2010, 4:43 pm by sherald
    ada member ckp psal head l2 msuk p blok klisa..
    snang adjust valve..
    head l2 tahan skit & lowcomp dri head klisa..
    Post on 26/2/2010, 2:57 pm by Putra
    kalau saya.. pakai piston 1.0.. korek lagi piston tu kasi low comp... blok 850 tinggi sedap.. pastu set boost 1.3 - 1.8 wakakaka..
    Post on 9/3/2010, 4:43 am by sherald
    boleh ka tu bro blok kelisa 850 korek smpai muat piston kelisa 1.0?
    pstu klau pkai metal gasket ksi 2 layer boleh ka? tdak leakg ka tu?
    Post on 12/3/2010, 5:25 am by kelisa_hitachi
    sori mencelah.lama x join forum
    piston stendet kelisa leh tahan sampai 1.2 bar dgn injector stendet kalu AFR cun..btw,piston 1.0 kelisa dikira low comp juga
    sekian
      Current date/time is 25/5/2018, 9:37 pm
