    rpm 4000 warning engine keluar...
    donz01
    Number of posts : 16
    11052011
    http://i38.servimg.com/u/f3 rpm 4000 warning engine keluar...
    Post by donz01
    Salam 1 malaysia warga sioolonn... nak tanya skit boleh..hehehehe... ni masalah aku ni... bila jak masuk minyak cecah rpm 4000 warning engine terus keluar... lagi 1 engine cepat overheat bila naik bukit atau pun jalan tengah jam... air dalam radiator mendidih ni... engine 4agze supercharge... tolong lah otai2 di luar sana sila bagi komen tentang masalah kereta ni...huhuh..trimah kasih
    Post on 11/5/2011, 7:28 am by donz01
    Xda ker org nak bantu saya ni..huhu.... xpalah
    Post on 11/5/2011, 1:47 pm by im
    sebaik2nya bawa pi bengkel yang ada scan tool untuk detect masalah tu...
    sebab mesti ada masalah berkaitan sensor tu...
    Post on 11/5/2011, 2:44 pm by keba
    temp enjin naik x bos?? enjin sa pn salu jd camtu..
    x pyh tgu 4000rpm..maintain 150-160 pn naik temp..
    Post on 11/5/2011, 2:52 pm by syahir09
    nak tanya otai2
    jarum temp normal jarum biasa kt tengah ke?
    Post on 11/5/2011, 3:11 pm by McJeremy
    yup...normal dekat tengah....
    Post on 11/5/2011, 3:13 pm by McJeremy
    radiator awak ada gantikah...atau masih guna original lagi....
    Post on 11/5/2011, 3:16 pm by keba
    McJeremy wrote:radiator awak ada gantikah...atau masih guna original lagi....
    pkai radiator std kancil lg single core..kena tukar radiator aloi double core br ok..
    Post on 11/5/2011, 3:21 pm by McJeremy
    yup...yg penting radiator cukup support kalau tidak temp naik terus lo...
    Post on 11/5/2011, 4:23 pm by syahir09
    ori L5
    yg aluminium double layer brapa harga ek??
    Post on 11/5/2011, 5:02 pm by keba
    aloi double layer L5 x kompom la brp..
    kalau aloi triple core, 250 da dpt kat sni..
    kalau nk brand forge racing skali ngan kipas dlm 350 jgk
    Post on 11/5/2011, 5:07 pm by syahir09
    bleh tahan harganya...
    tp apa lebihnya bro?
    klu air radiator tu kering,xder masalah ker?
    Post on 11/5/2011, 5:11 pm by keba
    kalau air radiator kering, mgkin jd overheat..
    bila da overheat, head pn crack..lg teruk kalau blok twist..
    Post on 11/5/2011, 5:17 pm by syahir09
    keba wrote:aloi double layer L5 x kompom la brp..
    klu pakai radiator forge racing,and then air kering,xder masalah ke pada enjin bro keba??
    Post on 12/5/2011, 2:49 pm by keba
    ader masalh jgk...walaupn pkai radiator 10core pn, kalau air kering mmg overheat jgk enjin tu..
    sb radiator hny tempat heat exchanger..air pulak sbg agent heat exchanger..
    kalau air sbg agent da xdak utk absorb heat enjin, cmana nk sejukkan enjin..
    Post on 12/5/2011, 3:42 pm by syahir09
    oooo info yg baik bro.thanks
    Post on 13/5/2011, 7:28 am by donz01
    keba wrote:temp enjin naik x bos?? enjin sa pn salu jd camtu..
      Current date/time is 22/1/2018, 9:27 am
