    1.3 saga piston
    appangguak86
    Number of posts : 34
    04072011
    http://i38.servimg.com/u/f3 1.3 saga piston
    Post by appangguak86
    bro piston 1.3 saga brpa boost boleh support?minta pandangan otai2 sekalian....
    Post on 4/7/2011, 7:09 pm by keba
    x kompom la bos..sb ad yg boost 1.3bar da picah..
    ad jgk yg try boost 1.5bar baru picah..
    Post on 4/7/2011, 7:46 pm by appangguak86
    keba wrote:x kompom la bos..sb ad yg boost 1.3bar da picah..
    stkat ni..sya pkai 1.5 bar je..mac lg ok...pena dapat 1.7 bar tp kereta pandai tunduk da..macam rpm cut...tu yg mau tnya otai2 ni..brapa max boost..tuk piston 1.3 ni..blum pasang fuel regultor,sistem lain.
    injctor stndard l2s,tangki L9..klau bunyi teppet kuat x ada kesan sampingan ka?
    Post on 5/7/2011, 5:21 am by Lockon
    jgn kc tgi boost,piston saga 1.3 x thn boost tgi tu..psg la fuel regulator,nt rpm tgi myk x ckup supply pula..pch tu piston..alang ko gna saga punya,npa x kc msuk piston kelisa ka,2e ka..slalunya org pakai piston saga utk n/a jak
    Post on 5/7/2011, 8:17 am by appangguak86
    Lockon wrote:jgn kc tgi boost,piston saga 1.3 x thn boost tgi tu..psg la fuel regulator,nt rpm tgi myk x ckup supply pula..pch tu piston..alang ko gna saga punya,npa x kc msuk piston kelisa ka,2e ka..slalunya org pakai piston saga utk n/a jak
    dlu main NA bos...tp da boring mau tukar slera main tebo..jd psg tebo kit je trus..lpas ni kra mau kac masuk pistn kelisa kepala hitam punya..tp saiz 72.5mm boleh pkai ka msuk block 660
    Post on 5/7/2011, 8:18 pm by keba
    saiz 72.5 bleh masuk..tp xsmpai sbulan kot blok tu..hehe
    bila da pkai pump besaq n regulator, elok la pkai management..
    plg krg pn 5button..macam lockon ckp, high rev mmg mnyak x cukup..
    Post on 8/7/2011, 5:51 pm by Lockon
    bleh tu ko pakai piston kelisa hitam..ko menten jak la boost 1.3..hi comp piston saga tu..takut nt tgh2 ko jln,pch pla..tp klu da plan mo tkr,pch pun x hal ba kn hehehe
    Post on 8/7/2011, 10:33 pm by keba
    bhuleh ka bos?? ingt max 72mm je bleh masuk..
    mgkin btol kot org dk pkai piston 73mm kat blok L2..
    tp bleh pkai skali je..nk men drag bleh la..
    ingt tipu2 je..hehe malu
    Post on 9/7/2011, 1:39 am by Lockon
    bkn 72mm yg max,73 yg max rebore utk 660..tp msti blok turbo la tahan kn..aku pun pakai 73mm..jln2,drag lg, 660 mmg tahan tukul
    Post on 9/7/2011, 7:34 pm by keba
    ya ka bos?? ingt 72mm tu da max..tq 4 da info drive
      Current date/time is 18/7/2018, 7:54 am
