    computerbox L2 dan L2s, [dan emanage.]
    azreenlatip
    Number of posts : 4
    13092011
    https://i.servimg.com/u/f3 computerbox L2 dan L2s, [dan emanage.]
    Post by azreenlatip
    salam bro2 smua..
    1.mau tanya, apa beza ECU L2 dgn L2S? satu utk NA, satu utk turbo..macam tu ja ka?
    2.saya pakai ECU L2(NA) + E-Manage blue. hari tu mekanik pasang boost meter, dia tkejut sbb kreta aku ada 2 MAP sensor. kes ni normal atau tidak normal? haha..
    3.suda pasang e-manage, ok ka kalau pakai ecu L2 ja? atau ada beza kalau ECU L2S + E-manage? sy ada ECU L2S d rumah.tapi belum pasang lagi..
    thank you bro2 n otai2 smua sbb bagi feedback cepat utk post sy sblm ni.. Smile
    Post on 14/9/2011, 8:48 pm by qj3
    bro,
    1. ecu l2 sm l2s sama ja (dua2 turbo 12 valve)..yg beza tu klu l2 6 valve punya..injection tapi NA..intake dia x bleh masuk pi head 12 valve..
    2. ko beli kereta ni dari org lain ka? klu pakai emanage normal tu pakai 2 map sensor(suda mod tu)..emanage utk tipu ecu asal kereta ko..yg xtra 1 map sensor tu utk tipu emanage..
    3.klu ko pakai ecu L2 6 valve punya, ko x bleh tukar pi ecu l2s 12 valve punya..sbb soket x sama,wiring x sama,sensor2 x sama...
    Post on 25/9/2011, 1:55 am by saiful090906
    DUA MAP SENSOR ...MAKNA NYA SATU JALAN UNTUK BACAAN BUKAAN THROTTLE....
    SATU LAGI UNTUK BACAAN ORIGINAL MAP SENSOR......
    BANYAK YANG TAK TAU BILA ADA DUA MAP SENSOR NIH.....
    KECUALI KALAU TPS TUKAR PAKAI YG LAIN JADI TAK PAYAH PAKAI 2 MAP SENSOR.....
    KALAU E-MANAGE YG MOD PUNYA BOLEH MAIN TIMING@IGNITION.....TP PERLU MOD SKIT COMPUTER BOX....JD KALAU BOOST TINGGI PON TAK RISAU PSL DH MEN TIMING...RAMAI YG BUKAK EMANAGE PASAL TAK TAU NAK MOD UNTUK JALAN THROTTLE N IGNITION......
    JD MANA2 MEKANIK YG RASA DIRI DIA PANDAI TRUS CAKAP SSH SETTING ATAU EMANIS ROSAK.......
    SYA BERCAKAP MELALUI PENGALAMAN SYA YG PERNAH PAKAI 5BUTTON,SAFC 1,SAFC 2,E-MANAGE N MICROTECH MT4 DI KANCIL SYA.......
    Post on 25/9/2011, 2:08 am by Lockon
    saiful090906 wrote:DUA MAP SENSOR ...MAKNA NYA SATU JALAN UNTUK BACAAN BUKAAN THROTTLE....
    ni bru la otai
    Post on 25/9/2011, 2:17 am by saiful090906
    BUKAN OTAI BRO....SEKADAR BERKONGSI PENGALAMAN BERSAMA......
    KITA KONGSI UNTUK KEBAIKAN BERSAMA.......
    RAMAI YG AGAK BERAHSIA BILA MAIN MANAGEMENT.....TAKUT KETE ORG LAJU DR KETE SENDIRI......HEHEHEHE.....RAMAI YANG BEG2......JD SYA BGTAU APA YG SAYA TAU N BLAJAR....
    Post on 25/9/2011, 5:41 pm by qj3
    ya btul bro saiful..
    bnyk pomen yg trip2 ja tau install emanage tpi x tau apa2..kincing org ja..biasa yg tipu ni dorang smbung tu power emanage ja..asalkan nmpak led tu mnyala..tpi tune zero..
    1 lgi map sensor tu mmg utk kasi jln trotel body..baru boleh tune 16x16 position..boleh jg klu x mo pkai xtra map sensor tpi tune x cntik la 1x16 position ja..tpi klu mo main 1x16 bgus x payah pkai emanage..silap2 buli kuyak injin..
    org yg pkai 3 bar map sensor biasanya tap tu trotel signal dri situ ja..jdi x payah lgi tmbh xtra map sensor...
    sama siapa yg main ignition utk inijn L2, hti2 mod tu ecu..sng tebakar tu ecu klu salah wiring..suda oo cari ecu L2 ni..
    Post on 20/10/2011, 4:58 pm by adeqyana
    itu la masalah klu pakai emanage ni kan bro..bkn masalah dgn emanage tu,tp masalah dgn pomen yg pasangkn tu..kna lg pomen yg mmg main kereta,mana diaorg mau set yg cantik2 utk kereta kita..macam bro saiful ckp tu,takut kereta org lg laju dari kereta dia..hihi..mmg senang kena kencing la org macam aku ni yg br belajar main kereta klu mau pasang emanage..hehehe..
    Post on 21/10/2011, 4:56 am by Lockon
    utk hindar dr kna kenchenng ni,tnya pastu amik ilmu dr rmi tuner dlu,kc bnding stiap ilmu yg korg dpt,smbil2 tu search jgk pngtahuan sal emanage tu d web2..klu da yakin,bru la bli n psg..mmg kbykan tuner2 emanage ni xmo kc set lbih2 sbb xmo kereta dorg lbh kuat & laju..tp ada jg yg baik,xmo set lbih2 utk ktahanan enjin (bkn smua org mo mod lbih2 kn) ada yg minat mo tune & jd hobi.. dlu aku gna emanage pun utk ska2,bkn heavy tune sbb mo rsa tune gna2 laptop,bgaya la knun hehehe ada jg pomen tau psg tp xtau tune,juz men tekan2 d laptop trus dpt cri tune,yg tu ada 1 pomen yg aku knl mmg gila2 sikit tune emanage smbil ktawa2 lg hehehehe
    Post on 21/10/2011, 6:18 am by adeqyana
    ooo,macam tu ya bro locon..tq atas info bro tu..oh ya,bro masi pakai emanage ka skrg?? hari tu berapa harga bro beli emanage?? mmg sdp la bro pakai emanage??
    Post on 24/11/2011, 1:33 pm by syahir09
    nak mencelah bleh?
    klu pakai afc apexi bleh setting enjin melalui situ je ke?
    Post on 11/12/2011, 6:37 pm by keba
    syahir09 wrote:nak mencelah bleh?
    bleh..kasi setting kaw2..hehe
    Post on 15/1/2012, 12:23 pm by ahmad_dhani
    klu mau lg best cuba2 la pakai microtech...
    Post on 6/12/2012, 10:16 am by xiaorullz
    kalaw saya bgus guna safc ja.. sng tune.. janji ada wideband... emanage skrg byk tiruan.. bacaan tak btul.... kwn aq da pena kena masa drag,,..hahhaha
    Post on 7/4/2015, 9:00 am by subaruimpreza81
    salam. sape2 ada diagram ecu l2, sy nak install emanage
      Current date/time is 17/1/2019, 9:23 am
