    engine L6 cut2 bile tkn mnyk hbs
    syafiqdaniel.eyim
    Number of posts : 11
    24082012
    http://i38.servimg.com/u/f3 engine L6 cut2 bile tkn mnyk hbs
    Post by syafiqdaniel.eyim
    Kete aq cut2 kalau tekan minyak hbs..knape ekk
    Post on 24/8/2012, 1:16 am by syafiqdaniel.eyim
    Tolong sape...yg pakar
    Post on 25/8/2012, 6:27 am by syafiqdaniel.eyim
    Xde sape tau ker dont know
    Post on 26/8/2012, 6:46 am by Yum L2s
    aku rsa minyak x ckup kot..
    Post on 26/8/2012, 8:48 am by syafiqdaniel.eyim
    Aq da pkai pump mes..src full rgulor..xcukop lagi ke..bkn sensor map je hal ke..
    Post on 27/8/2012, 5:32 am by keba
    syafiqdaniel.eyim wrote:Aq da pkai pump mes..src full rgulor..xcukop lagi ke..bkn sensor map je hal ke..
    rpm brp jd semput? ke bila tekan mnyak mngejut?
    Post on 16/9/2012, 12:02 pm by syafiqdaniel.eyim
    bile tekan slow2 ok pulak..dpt pijak hbs...nk pink up xdpt..block off pon bunyi bile dpt pijak hbs..nk kne rpm tingi gile bru bunyi..pe masalah ekk
    Post on 16/9/2012, 12:04 pm by syafiqdaniel.eyim
    bro bgi no fon kwn coll
    Post on 17/9/2012, 4:05 am by ako_swifter
    FR..hehe..
    Post on 17/9/2012, 5:21 am by ecagig
    bakmai dtg, kite cucuk comp box dl.... penah jd hal macam ni.... tp kwn aku kne fuel rail prob... tp dr segi pngalaman bt bengkel... ape2 pun kite cucuk je dl sng skit.... payah nk ckp, byk kemungkinan....
    Post on 17/9/2012, 8:58 am by mini93
    rpm brapa bru semput?.. ada guna safc ka?... fcd ada guna ka?..
    Post on 17/9/2012, 9:11 am by ako_swifter
    klu da cucuk bnde2 yg sptutny pn sme juga try fuel pump.hehe..filtr ke..
    Post on 17/9/2012, 2:09 pm by syafiqdaniel.eyim
    mini93..rpm redah..tpi kalau slow2 tekan ok pula..pening pale ni..fuel pump da besar nk besar mane lagi..haha..aq da pening da ni..pomen aq pon pening..injekter std L6 lagi..da la xdpt tekan habis..nk test pinkup pon xdpt..minyak kuat pula 2
    Post on 17/9/2012, 7:13 pm by mini93
    aq rasa fcd takde kot...
    Post on 17/9/2012, 7:17 pm by mini93
    pling bagus guna nozel standart L2... br set di afc,,blh tu.. janji afc ngan fcd ada.. tak masala da tu..
    Post on 17/9/2012, 7:38 pm by syafiqdaniel.eyim
    fcd gn afc ape bro x phm
    Post on 18/9/2012, 2:18 pm by mini93
    afc tu air fuel converter... fcd tu fuel cut defendser... afc untuk control minyak... yg fcd pula tuk buang boost cut... klu cut bila kw blast kereta kw... kali tu over boost jd tu la cut.. jd tuk mngatasi boost cut psng la fcd... korang buka boost brapa?... cable spark atau spark plug uda ganti ka?..
    Post on 21/9/2012, 9:56 pm by keba
    pakai balik fuel pump asal L6. pakai pump besar, pressure jd tinggi. mixture masuk enjin jd rich mmg semput
    Post on 21/9/2012, 10:04 pm by syafiqdaniel.eyim
    pump mecs x besar ke..
    Post on 22/9/2012, 5:47 am by keba
    pump merc tlebih besar. org pakai pump merc bila main boost tinggi. kalau stakat turbo std, boost 1bar, fuel pump asal L6 bleh support
    Post on 22/9/2012, 7:30 am by syafiqdaniel.eyim
    kwn pkai tebo td04 td05 pon same..skrg pkai tebo kecil rhf ihi 4 subaru full boll bering pon same..skit ari ke laut la engine ni Cool
    Post on 22/9/2012, 9:44 am by ako_swifter
    haha..jgn macam tu bro..besa la men trbo..kena ada research bru ada pngalaman..try and error mmg da besa klu jdik bdk kreta..btul x bro keba?hehe..tkar je pump asal blik..yg smput2 tu kna mntk ajar dgn bro keba..cnfirm ilang macam kelisa sy ari tu..hehe..
    Post on 22/9/2012, 10:42 am by Yum L2s
    kalau semput2..da kaitan ke ngan throttle body..??
    Post on 28/9/2012, 6:26 pm by xiaorullz
    teda.. lari timing tu..
    Post on 29/9/2012, 6:55 am by afiq2306
    sory menyempuk enjin L6 3 cyl ke 4 cyl.....
    sdh try adjust fr ka sebab fuel pump sdh cukup besar jd minyak tu lebih, satu lg spark plug ada ganti ke?...
      Current date/time is 21/4/2018, 10:13 pm
