| engine L6 cut2 bile tkn mnyk hbs | |
syafiqdaniel.eyim FRESHIE
Countries/State : Age : 37 location : ok Points : 8487 Reputation : 1 Number of posts : 11
| Subject: engine L6 cut2 bile tkn mnyk hbs 24/8/2012, 6:13 am | |
| Kete aq cut2 kalau tekan minyak hbs..knape ekk |
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 24/8/2012, 6:16 am | |
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 25/8/2012, 11:27 am | |
| Xde sape tau ker |
Yum L2s FRESHIE
Countries/State : Age : 32 location : kota belud Points : 8599 Reputation : 1 Number of posts : 43
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 26/8/2012, 11:46 am | |
| aku rsa minyak x ckup kot.. |
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 26/8/2012, 1:48 pm | |
| Aq da pkai pump mes..src full rgulor..xcukop lagi ke..bkn sensor map je hal ke.. |
Countries/State : Age : 34 location : Kemaman - Kota Bharu Website : contact 01119778382 Tag ID: : SFC08063 Points : 14823 Reputation : 69 Number of posts : 3981
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 27/8/2012, 10:32 am | |
| - syafiqdaniel.eyim wrote:
- Aq da pkai pump mes..src full rgulor..xcukop lagi ke..bkn sensor map je hal ke..
rpm brp jd semput? ke bila tekan mnyak mngejut? |
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 16/9/2012, 5:02 pm | |
| bile tekan slow2 ok pulak..dpt pijak hbs...nk pink up xdpt..block off pon bunyi bile dpt pijak hbs..nk kne rpm tingi gile bru bunyi..pe masalah ekk
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 16/9/2012, 5:04 pm | |
ako_swifter JUNIOR
Countries/State : Age : 39 location : Tawau,Btu 8 Points : 9186 Reputation : 2 Number of posts : 121
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 17/9/2012, 9:05 am | |
ecagig FRESHIE
Countries/State : Age : 38 location : rawang,sg buloh,d.damai,selayang,kl... Website : www.bisnesgoji.com, www.roaztrading.com Tag ID: : SFC 12167 Points : 10281 Reputation : 1 Number of posts : 9
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 17/9/2012, 10:21 am | |
| bakmai dtg, kite cucuk comp box dl.... penah jd hal macam ni.... tp kwn aku kne fuel rail prob... tp dr segi pngalaman bt bengkel... ape2 pun kite cucuk je dl sng skit.... payah nk ckp, byk kemungkinan.... |
mini93 FRESHIE
Countries/State : Age : 30 location : tawau Points : 8429 Reputation : 1 Number of posts : 7
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 17/9/2012, 1:58 pm | |
| rpm brapa bru semput?.. ada guna safc ka?... fcd ada guna ka?.. |
ako_swifter JUNIOR
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 17/9/2012, 2:11 pm | |
| klu da cucuk bnde2 yg sptutny pn sme juga try fuel pump.hehe..filtr ke.. |
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 17/9/2012, 7:09 pm | |
| mini93..rpm redah..tpi kalau slow2 tekan ok pula..pening pale ni..fuel pump da besar nk besar mane lagi..haha..aq da pening da ni..pomen aq pon pening..injekter std L6 lagi..da la xdpt tekan habis..nk test pinkup pon xdpt..minyak kuat pula 2 |
mini93 FRESHIE
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 18/9/2012, 12:13 am | |
mini93 FRESHIE
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 18/9/2012, 12:17 am | |
| pling bagus guna nozel standart L2... br set di afc,,blh tu.. janji afc ngan fcd ada.. tak masala da tu..
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 18/9/2012, 12:38 am | |
mini93 FRESHIE
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 18/9/2012, 7:18 pm | |
| afc tu air fuel converter... fcd tu fuel cut defendser... afc untuk control minyak... yg fcd pula tuk buang boost cut... klu cut bila kw blast kereta kw... kali tu over boost jd tu la cut.. jd tuk mngatasi boost cut psng la fcd... korang buka boost brapa?... cable spark atau spark plug uda ganti ka?..
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 22/9/2012, 2:56 am | |
| pakai balik fuel pump asal L6. pakai pump besar, pressure jd tinggi. mixture masuk enjin jd rich mmg semput |
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 22/9/2012, 3:04 am | |
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 22/9/2012, 10:47 am | |
| pump merc tlebih besar. org pakai pump merc bila main boost tinggi. kalau stakat turbo std, boost 1bar, fuel pump asal L6 bleh support |
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 22/9/2012, 12:30 pm | |
| kwn pkai tebo td04 td05 pon same..skrg pkai tebo kecil rhf ihi 4 subaru full boll bering pon same..skit ari ke laut la engine ni |
ako_swifter JUNIOR
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 22/9/2012, 2:44 pm | |
| haha..jgn macam tu bro..besa la men trbo..kena ada research bru ada pngalaman..try and error mmg da besa klu jdik bdk kreta..btul x bro keba?hehe..tkar je pump asal blik..yg smput2 tu kna mntk ajar dgn bro keba..cnfirm ilang macam kelisa sy ari tu..hehe.. |
Yum L2s FRESHIE
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 22/9/2012, 3:42 pm | |
| kalau semput2..da kaitan ke ngan throttle body..?? |
xiaorullz FRESHIE
Countries/State : Age : 30 location : tawau Points : 8424 Reputation : 1 Number of posts : 2
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 28/9/2012, 11:26 pm | |
afiq2306 FRESHIE
Countries/State : Age : 47 location : Labuan Points : 10628 Reputation : 1 Number of posts : 8
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs 29/9/2012, 11:55 am | |
| sory menyempuk enjin L6 3 cyl ke 4 cyl..... sdh try adjust fr ka sebab fuel pump sdh cukup besar jd minyak tu lebih, satu lg spark plug ada ganti ke?... |
| Subject: Re: engine L6 cut2 bile tkn mnyk hbs | |
