    Grounding wire 5 points
    drakult
    Number of posts : 6286
    10122007
    https://i.servimg.com/u/f3 Grounding wire 5 points
    Post by drakult
    Hello otai2 suma..
    Ada sepa2 tau macam mana mo arrange ini benda kah??
    Klu boleh tolong post gambar sekali k..mau DYI bah..MANTAP!!?!!
    Post on 11/12/2007, 10:58 am by junraz
    Pasang wayar tu di (-) terminal bateri...Lepas tu hujungnya kasi pasang dimana yg patut..
    Post on 11/12/2007, 7:45 pm by drakult
    junraz wrote:Pasang wayar tu di (-) terminal bateri...Lepas tu hujungnya kasi pasang dimana yg patut..
    Dimana yg patut tue yang aku nda pasti dmana mau kasi pasang bro.. Suspect
    Post on 12/12/2007, 8:45 pm by apit
    nanti aku antr GUIDE yer....
    Post on 13/12/2007, 12:40 pm by xiaomao
    Suggested connecting points - Example Two
    A = 1st body earth for electrical parts - B = 2nd body earth
    - C = Engine block - D = Throttle body
    - E = Alternator - F = Battery negative terminal
    - G = 3rd body earth
    Suggested connecting points - Example Three (recommended by Sigma Automotive)
    1) Engine head near spark plugs - better spark plug performance
    2) Engine head near stock earth wire - better injector & ignition coil performance
    3) Near alternator - reduces power loss
    4) Near cell motor - quicker engine start-up
    5) Stock body earth cable for electrical parts - electric parts perform better
    6) Stock body earth cable near battery - enhance general stock body earth conduction
    * As you see, there can be multiple connecting points per major
    component. You may be creative & connect up to TEN points. Anything
    beyond that will yield only minimal improvement.
    Post on 13/12/2007, 12:41 pm by junraz
    Apa fungsi ground cable ni..?
    Post on 13/12/2007, 12:51 pm by xiaomao
    utk electrik kereta anda stabil...
    Post on 13/12/2007, 12:59 pm by Nieto
    ada jenis untuk sound, power kereta, atau kestabilan kalau tak silap... by pivot
    Post on 13/12/2007, 1:42 pm by junraz
    xiaomao wrote:utk electrik kereta anda stabil...
    Ya..kah... Suspect
    Post on 13/12/2007, 2:01 pm by Nieto
    biasanya, pada waktu malam, buka aircond lampu dashboard dan kereta terus gelapkan? tapi saya dengar orang yg pasang ground wire, mereka cakap lampu dashboard tidak gelap, dan lampu besar lebih terang. Kira saya pun mau pasang next mth, hehe
    Post on 13/12/2007, 2:54 pm by junraz
    Mungkin juga..sebab ori wireing cuba ada satu grounding wire kalau tdk silap saya..
    Post on 13/12/2007, 8:58 pm by drakult
    apit wrote:nanti aku antr GUIDE yer....
    Bah Bussko, klu ada GUIDE ko post dulu bha..kungsi2 kitani ilmu..MANTAP!!
    Post on 13/12/2007, 9:00 pm by drakult
    xiaomao wrote:Suggested connecting points - Example Two
    Thanx Xiaomao..Memang ko jugalah harapan..MANTAP!!?!!
    Post on 13/12/2007, 9:04 pm by drakult
    Nieto wrote:ada jenis untuk sound, power kereta, atau kestabilan kalau tak silap... by pivot
    ZMAX pun ok juga..Grounding skali sma Voltage Stabilizer..
    Post on 13/12/2007, 9:22 pm by Nieto
    zmax ok ok ja lah, tapi saya recomend kau pakai ja pivot, mahal sikit tapi tahan lama.
    Post on 14/12/2007, 4:18 am by anthonyL500
    Dlm brapa harga pivot tu bro?
    Post on 14/12/2007, 4:25 am by xiaomao
    sekitar kk kalo nda silap dalam rm1XX.....mungkin ada lebih mahal...
    Post on 14/12/2007, 5:14 am by Nieto
    3xx kalau tak silap, tak sure... tak pernah servay
    Post on 14/12/2007, 6:32 am by anthonyL500
    owh...di sini sya belum servay lagi.mau p kadai roda2 dulu.
    Post on 14/12/2007, 11:45 pm by lentugi
    kalau pasang grounding cable without Voltage Stabilizer ok ka??
    kasi komen sikit
    Post on 15/12/2007, 6:15 am by Nieto
    boleh, banyak orang buat cam tu juga~
    Post on 15/12/2007, 12:40 pm by xiaomao
    ekonomi...kekeke....biasa kedai accessorie ada jual tu...
    Post on 15/12/2007, 2:19 pm by lentugi
    ya sana 2020 sa ada nampak ndak sampai RM50
    pivot stabilizer mana mok cari??
    Post on 15/12/2007, 7:24 pm by drakult
    lentugi wrote:kalau pasang grounding cable without Voltage Stabilizer ok ka??
    kasi komen sikit
    Boleh no problem geng...Voltage Stabilizer tue utk control current sound system, klu nda silap aku lah..
    Grounding Cable nie utk tambah Earth jak..
    Post on 15/12/2007, 7:40 pm by Nieto
    bukan saja sound system, tapi control kesuluruhan electric. ground cable menambahkan earth pada benda yg menggunakan electronic, aircond, auto gearbox etc.
    kalau mau jimat, boleh juga guna cable bateri untuk amp sound system punya sebagai grounding cable
      Current date/time is 17/1/2019, 9:54 am
