| minta bantauan dari otai2 | |
DarkSmoke JUNIOR
Countries/State : Age : 30 location : Melaka Points : 11615 Reputation : 6 Number of posts : 115
| Subject: minta bantauan dari otai2 12/5/2009, 5:07 pm | |
| gini creta nya mula2.. 1- keta ada masalah utk masuk gear,pastu sya slow2 pjak2 clutch balik then bru dpt masuk gear... 2- lepastu,time dkt simpang dri gear 3 mau turun gear 2..gear tu keras,xdpt tolak ke bawah.. 3- setelah mndapati msalah gini trus sya patah balik ke rmh,mau cek2. 4- cek punya cek,minyak clutch habis,padahal baru jak isi tadi pagi. 5- sya pun isi la balik,isi..isi..start enjin..pijak2 clutch n masuk gear smua ok.. 6- ngam2 mau keluar rmh,masalahnya keluar balik,so sya stop la,cek balik...sma juga,minyak clutch kurang.. 7- mcm ada liking,so sya sruh kwn pijak2 tu clutch,skali dia pijak,minyak clutch keluar dari bawah(x taw apa nma tmpt dia keluar tu) ,di padel clutch pun ada minyak clutch tumpah.. skg keta tu ampai2 di depan rmh. so,sifu2 skalian apa yg patut sya buat ni??buli buat sendiri ka ni barang??ataw bawa p workshop??pa benda yg rosak tu??mcm mna dia boleh terjadi?? |
bigcatclaw REGULAR
Age : 48 location : Tenom Tag ID: : SFC 02834 Points : 12244 Reputation : 3 Number of posts : 399
| Subject: Re: minta bantauan dari otai2 12/5/2009, 5:31 pm | |
| Klac pakai sistem hidraulic ka? Memang kena bawa pg bengkel ni. Mcm ada benda mo kena ganti ja tu.
Jumpa di internet bru2 td.
About Hydraulic Clutch
* The hydraulic clutch uses brake fluid. There's no such thing as "clutch fluid" - you'll get laughed at if you go into an auto parts shop asking for it. * Cars with a clutch cable do not use any fluid. * A leak can often be seen at the reservoir/clutch master cylinder, at the other end of the clutch hydraulic line at the clutch slave cylinder, or inside the car behind the clutch pedal. * Take care not to spill brake fluid on yourself or the car's paint - it's highly corrosive. Wash your hands and wipe any spills with a rag. * If the clutch reservoir is consistently low you probably have a leak. The reservoir is very small so even a little leak can empty it out quickly. Without fluid, your clutch pedal is useless so you won't be able to shift, or to drive. See your mechanic if you suspect a leak.
Jumpa 1 jawapan utk masalah yang serupa dengan masalah bro: I don't know if this is it, but it might help. Before you go to a mechanic, check the clutch line from the clutch pedal to the clutch and up to the fluid reservoir. Look for leaks.
My brother had a car once that was losing fluid like crazy. It was a two dollar seal in a step down cylinder located on the line coming from the pedal. It was located under the car. I found it by mashing the pedal and then, looking around for the wet spot. (there's a dirty joke in there somewhere but I'm too tired to work it out).
Anyway, it took about 20 minutes to change it. Check the line going into the cylinder really well. |
sonofthipareth CONTRIBUTOR
Countries/State : Age : 39 location : KB - Putrajaya Tag ID: : SFC 04835 Points : 12217 Reputation : 6 Number of posts : 1189
| Subject: Re: minta bantauan dari otai2 12/5/2009, 5:34 pm | |
| Nice info, now i can DIY hehe |
DarkSmoke JUNIOR
| Subject: Re: minta bantauan dari otai2 12/5/2009, 5:42 pm | |
| sistem hidraulic ni mcm mna arh???sya tia taw pula..tp sya rasa tu keta x pakai sistem hidraulic,sebab keta lama..(rasa2 seja la).. klu bukan sistem hidraulic mcm mna??
btw...thnx for the info |
Countries/State : Age : 36 location : Kk-Keningau-Beaufort-Kuching Tag ID: : SFC02081 Points : 14354 Reputation : 10 Number of posts : 6723
| Subject: Re: minta bantauan dari otai2 12/5/2009, 6:09 pm | |
| sy nie bukan otai lah,tp taw la jga ckit2 heheh..
konfom guna sistem hidraulic nie keta ko bro,sbb guna mnyak tu clutch ko....mmg kit pada clutch pump ko menghadapi masalah sudah n perlu di ganti.kalau atas leak (lokasi tmpt ko isi minyak clutch),kalau bawah di gearbox....
kalau housing clutch pump sudah makan/haus....ko perlu ganti satu set pump lah..... |
DarkSmoke JUNIOR
| Subject: Re: minta bantauan dari otai2 12/5/2009, 6:32 pm | |
| - ProjectD wrote:
- sy nie bukan otai lah,tp taw la jga ckit2 heheh..
kalau housing clutch pump sudah makan/haus....ko perlu ganti satu set pump lah..... aku cek balik td,d bawah pula leak,mcm dkt smbugan p gearbox tu...brapa la harga set pump tu arh?? thnx for the info bro. . . |
| Subject: Re: minta bantauan dari otai2 12/5/2009, 7:46 pm | |
| clutch kit pump bawah lah leak tue.....x mahal kalau kit..x sampai rm20..tp kalau housing pun rosak mau ganti...maybe di bawah 100 lah....(anggaran) |
DarkSmoke JUNIOR
| Subject: Re: minta bantauan dari otai2 12/5/2009, 7:54 pm | |
| okok juga arh kos nya nie...hehe thnx for the info otai2 skalian klu mcm ni,workshop la jawpannya... |
bigcatclaw REGULAR
| Subject: Re: minta bantauan dari otai2 13/5/2009, 4:38 am | |
| Paling senang memang workshoplah juga. Ni ada link yg berkaitan dgn sistem hydraulic clutch ni. komponen hydraulic clutch sama2 kita belajar bah |
| Subject: Re: minta bantauan dari otai2 13/5/2009, 11:23 am | |
| x susah juga mo bwat nie.... |
| Subject: Re: minta bantauan dari otai2 13/5/2009, 11:30 am | |
| - bigcatclaw wrote:
- Paling senang memang workshoplah juga.
sama2 kita belajar bah Wah good info bro.. Tp semua jenis kereta yg guna hydraulic clutch ni sama ka tu ah? Mksd sy installation.. |
bod_supersperm SUPERIOR
Countries/State : Age : 43 location : kota kinabalu sabah Tag ID: : SFC 03551 Points : 14147 Reputation : 6 Number of posts : 2276
| Subject: Re: minta bantauan dari otai2 13/5/2009, 11:49 am | |
| jgn lupa bila dah ganti, pakai minyak yang biasa dulu..1-2minggu pastu, tukar balik minyak clutch tu..yang super kaw punya, baru super namanya..hehe..alang2 ko ganti 1 set clutch..brand new punya.. |
DarkSmoke JUNIOR
| Subject: Re: minta bantauan dari otai2 13/5/2009, 12:32 pm | |
| ok member2 skalian,td sya sdh hntar p workshop utk repair,org tu ckp clutch stop yg rosak...skg keta sdh sihat mcm besa..thnx for all of ur support guys^^.. |
| Subject: Re: minta bantauan dari otai2 | |
