Subject: TWINCHARGER aka turbo + supercharger 9/12/2008, 9:23 am
So twin charger, lets discuss
If you still dont know how twin charger, look the picture below.
Twincharger is suitable to use on race, even drifting. below is the video of twin charger.
In simple word~ Use of twincharger: Twin charger is to produce more air flow and it is also to elimate the lag of turbo. supercharger run on lower to mid rpm, while turbo run on mid and higher rpm.
How it work? Supercharger will provide air first, after the turbo reach the operating speed, the turbocharger will function, and supercharger either it continue contribute power or either disconect after turbocharger function.
So supercharger and turbocharge have advantage and disadvantage. We all know twincharge have advantage, how bout disadvantage? yes twin charger have disadvantage too. the twin charger disavantage is higher fuel consumption, produce more heat, and more exhaust flow which is dangerous to enviroment. However, small engine use twincharger will be better, the fuel consumption is lower compare to large engine.
Silent_Night CONTRIBUTOR
Age : 37 location : Keningau-Kota Kinabalu Tag ID: : 3910 Points : 12002 Reputation : 1 Number of posts : 1137
Subject: Re: TWINCHARGER aka turbo + supercharger 9/12/2008, 11:06 am
FUh..this is it? What a power!!...turbo and supercharge combine together.. on the you might see just a glimpse of this car...but then..really a 'drinker' car........how they do it?....
M!$z D3v!L MODERATOR
Countries/State : Age : 36 location : kay kay Tag ID: : SFC 04114 Points : 12367 Reputation : 1 Number of posts : 1451
Subject: Re: TWINCHARGER aka turbo + supercharger 10/12/2008, 3:06 am
Quote" " Volkswagen done it and got an award for it. Nissan done it. Lancia done it and got banned from wrc for it.
Subject: Re: TWINCHARGER aka turbo + supercharger 10/12/2008, 3:24 am
The idea comes in the 1930's for aircraft engine..long before development of ball bearing turbo.so unless ur running big, laggy turbo that spools up at 4k rpm+ i'd say it'd be more hassle than its worth..
Countries/State : Age : 45 location : Kota Kinabalu-Putatan Tag ID: : SFC02202 Points : 12581 Reputation : 10 Number of posts : 2945
Subject: Re: TWINCHARGER aka turbo + supercharger 11/12/2008, 12:13 am
Because of this hassle, i think they invented the aftermarket parts such as racing crank bearing, forged piston & con-rod, racing cams for top end revving, so that the turbo boost can be utilize during track racing, drifting and drag, the quest for more hp's continues...
my two cents
still it'd be nice to have that low end umphh n smooth V8 characteristic dyno curve..IMO this kind of setup is best utilized for track racing, drifting etc. as the power is available steadily at any point of the rev band..no sudden rush of boost coming in as in using big turbo so can control n anticipate ur car behaviour better lah..for drag n dyno comp better bolt on the baddest turbo setup u can get ur hands on
..1 thing that bugs me is the sc belt system looks like a major drag at high rev..opinion?
SC belt, for example supercharge is gain 60% power, but lost its 20% power because of it run via crankshaft. Crankshaft has more load then before. for my opinion, is a overall of lost power.
Let say centrifugal type supercharge (look like turbine from turbo system) it will become faster and faster because of the centrifugal force, so i think this type of supercharge will not a burden for crankshaft at higher rev.
burjawi FRESHIE
Countries/State : Age : 34 location : kampar Points : 11311 Reputation : 1 Number of posts : 55
Subject: Re: TWINCHARGER aka turbo + supercharger 10/7/2009, 4:11 am
is there any twincharger project in malaysia??
did it go well??
bod_supersperm SUPERIOR
Countries/State : Age : 43 location : kota kinabalu sabah Tag ID: : SFC 03551 Points : 14147 Reputation : 6 Number of posts : 2276
Subject: Re: TWINCHARGER aka turbo + supercharger 10/7/2009, 9:56 am
i think, u must try it out. we'll waiting for your new project named "project 7717"hehe..is supercharger producing more power than turbo charger?depend... taiko
gryphoon81 JUNIOR
Countries/State : Age : 42 location : Putrajaya Website : www.bloggermiey.com Points : 11860 Reputation : 0 Number of posts : 113
Subject: Re: TWINCHARGER aka turbo + supercharger 3/8/2009, 11:26 am
Super Turbo Stunner
One of the fastest hatchbacks ever built -the supercharged and turbocharged Nissan March Super Turbo!
With 81kW at 6200 rpm and 130Nm at 4800 rpm the March Super Turbo – which weighs just 770kg - is an absolute rocket.
Countries/State : Age : 37 location : Membakut - KK - Bangi - Shah Alam Website : http://onesensei.blogspot.com/ Tag ID: : SFC 03495 Points : 14413 Reputation : 75 Number of posts : 2551
Countries/State : Age : 39 location : KK Points : 11084 Reputation : 1 Number of posts : 73
Subject: Re: TWINCHARGER aka turbo + supercharger 24/10/2009, 10:25 am
onesensei wrote:
Nieto wrote:
Off topic for a while, who knows the cost(RM) to make the hydraulic adjustable absorber like what shown in the video above?
hydraulic suspension @ mudah.my
myr5100.00 for the controller, cylinder and actuator..that shud give u the ballpark figure..brg2 ni boleh dpt d hafkat cr jak airbag suspension dari cygnus..from there its up to our 'Malaysia Buleh' spirit!! =) back to topic..
bebiri JUNIOR
Countries/State : Age : 43 location : KK and Kuching Points : 11217 Reputation : 4 Number of posts : 219
Subject: Re: TWINCHARGER aka turbo + supercharger 22/11/2009, 10:52 am
emm sya ada tgk tu video drfit king tek bawa twin charger,mmg buli buat tp problem dia satu jak..ssh mo control..cos torque dia sentiasa ada..time masuk,dlm,keluar corner..bahaya...kalau nda terer confirm terbabas..cos time corner ja.. laju..brek pun masi laju..jadi pada pendapat sya utk drag race buli lah..tp utk daily use mmg nda buli..ssh.
