| The best modify for blok 660t | |
Age : 43 location : Semporna / Tawau / Lahad Datu / Flamingo / Putatan Points : 12866 Reputation : 3 Number of posts : 1106
| Subject: The best modify for blok 660t 18/7/2008, 10:52 am | |
| listkan the best modify .... piston , turbo etc ... spec engine |
Age : 47 location : SU, SA, SB Points : 12380 Reputation : -1 Number of posts : 6286
| Subject: Re: The best modify for blok 660t 18/7/2008, 11:10 am | |
| cuba ko dulu mulakan bro..baru kitanie MANTAP!!?!! |
| Subject: Re: The best modify for blok 660t 18/7/2008, 11:28 am | |
| spec enjin sa kapok, tu yg buka thread ni siapa2 yg gila2 punya spec enjin, tebo, piston dan lain2... |
kelisa_hitachi REGULAR
Age : 42 location : keningau~kk Tag ID: : TAG ID : SFC 03153 Points : 12131 Reputation : 0 Number of posts : 315
| Subject: Re: The best modify for blok 660t 21/7/2008, 10:10 pm | |
| 1) pakai turbo hitachi..takpun tebo L9+blok kelisa+piston kenari 2)tebo td04(bulat bkn petak)+blok kelisa(korek siap)+piston 2E tapi depend pada bar or paun yg ko nak buka... sori..nubis lagi dlm dunia permotoran ni.. hehehe...kau slah tlg betulkan |
| Subject: Re: The best modify for blok 660t 24/7/2008, 9:21 pm | |
| - kelisa_hitachi wrote:
- 1) pakai turbo hitachi..takpun tebo L9+blok kelisa+piston kenari
2)tebo td04(bulat bkn petak)+blok kelisa(korek siap)+piston 2E tapi depend pada bar or paun yg ko nak buka... sori..nubis lagi dlm dunia permotoran ni.. hehehe...kau slah tlg betulkan x pa, sama2 belajar sa pon newbie aka. budak mentah tu yg dibuka thread ni. |
| Subject: Re: The best modify for blok 660t 24/7/2008, 10:02 pm | |
| aku dgr metal gasket engine kenari pun boleh MEMANTAPKAN lagi KEMANTAPAN modifikasi ini.. |
Tiara_Humble SENIOR
Age : 36 location : Kota kinabalu Points : 12499 Reputation : 0 Number of posts : 716
| Subject: Re: The best modify for blok 660t 25/7/2008, 3:35 am | |
| pakai metanol...heheheheheeh!!! |
| Subject: Re: The best modify for blok 660t 25/7/2008, 8:42 am | |
| ya enjin drakult...metal gasket kenari pun leh pakai dlm setting camni... |
| Subject: Re: The best modify for blok 660t 25/7/2008, 8:43 am | |
| kete jenis apa bro nak modi???? cara setup turbo berbeza ikut jnis kereta... ada kereta yg pakai nozel..ada juga yg nda pakai nozel...juz pakai fuel regulator n setting comp box je |
| Subject: Re: The best modify for blok 660t 25/7/2008, 2:50 pm | |
| METAL HEAD GASKET
metal gasket dipakai supaya x mudah putus semasa boost tinggi, boleh menjadikan low compression antara head dan piston dan boleh di guna pakai sampai 3 kali. |
| Subject: Re: The best modify for blok 660t 25/7/2008, 6:07 pm | |
| jadi kesimpulan utk metal head gasket nie apa bro..ok atau sebaliknya?? |
Countries/State : Age : 35 location : Kota kinabalu,sabah Website : https://www.facebook.com/profile.php?id=100002328674361 Tag ID: : 00735 Points : 14149 Reputation : 24 Number of posts : 7994
| Subject: Re: The best modify for blok 660t 26/7/2008, 5:44 pm | |
| skrg enjin na ada brg itu tak??hehehehee |
| Subject: Re: The best modify for blok 660t 26/7/2008, 6:45 pm | |
| metal gasket ko kene tambah sendiri...tak dtg dlm NA... pakai turbo sesuai laaa...tapi kalu NA nak pakai lagi mantappppp |
| Subject: Re: The best modify for blok 660t 27/7/2008, 7:10 am | |
| Sebaik2nya pakai gasket biasa utk enjin NA ni sebab menjadikan hi-compression, kalau letak metal gasket jadi low-compression. |
| Subject: Re: The best modify for blok 660t 27/7/2008, 9:41 am | |
| oooo....ada kira branded atau tidak??agak brp arga? |
| Subject: Re: The best modify for blok 660t 27/7/2008, 10:38 am | |
| - xiaomao wrote:
- oooo....ada kira branded atau tidak??agak brp arga?
rm15-20 ringgit jak gasket biasa ni, x payah ber branded |
| Subject: Re: The best modify for blok 660t 27/7/2008, 1:00 pm | |
| tak mau gasket biasa...mau metal gasket utk turbo punya brp? |
| Subject: Re: The best modify for blok 660t 27/7/2008, 1:19 pm | |
| - xiaomao wrote:
- tak mau gasket biasa...mau metal gasket utk turbo punya brp?
x tau kalau di k.k, sa beli rm 80 ringgit di k.l |
| Subject: Re: The best modify for blok 660t 27/7/2008, 1:28 pm | |
| kalao general overhaul berapa kosnya?
pioneer:piston l2 ko masih ada tak? |
| Subject: Re: The best modify for blok 660t 27/7/2008, 1:30 pm | |
| - xiaomao wrote:
- kalao general overhaul berapa kosnya?
pioneer:piston l2 ko masih ada tak? tgk cip ko la berapa kos, ko kena tnya berapa dia mo, ala cip juga takkan mkn duit kan... sdh jadi customer tetap. piston L2 tu sdh pecah 2 biji dan 1 plak sdh bikin buang habuk rokok |
| Subject: Re: The best modify for blok 660t 27/7/2008, 2:09 pm | |
| kete aku pakai piston kenari..ring heavy duty punye..tapi xtau la ngam ke idak kt enjin l2.. |
lentugi CONTRIBUTOR
Age : 37 location : RuNNow ~ Penampang Sabah Points : 12427 Reputation : 0 Number of posts : 1755
| Subject: Re: The best modify for blok 660t 28/7/2008, 7:42 pm | |
pioneer:piston l2 ko masih ada tak? ovohol mo tgk cip la.. ada yg minta mahal ada yg minta mura.. pandai2 la cari ala piston l2 sama kancil 660 bsar nya sama jak 68mm mgkin ring dia saja yg beza.. siapa tau share skit |
| Subject: Re: The best modify for blok 660t 29/7/2008, 10:15 am | |
| l2 low compression...660 high... |
| Subject: Re: The best modify for blok 660t 1/5/2010, 4:46 pm | |
Lockon SENIOR
Countries/State : Age : 38 location : kota kinabalu Points : 12117 Reputation : 23 Number of posts : 756
| Subject: Re: The best modify for blok 660t 3/5/2010, 12:16 am | |
| - xiaomao wrote:
- l2 low compression...660 high...
low compression,jd + metal gasket jd tmbh lg low tu kn? |
| Subject: Re: The best modify for blok 660t | |
