| offset rim apa yg sesuai??? | |
dexbeckz JUNIOR
Countries/State : Age : 40 location : KK Points : 11220 Reputation : 1 Number of posts : 154
| Subject: offset rim apa yg sesuai??? 18/6/2010, 10:44 pm | |
| hello semua... sy plan mo tkr rim kereta myvi sya.... tp agak risau dgn 'offset'.... kurang fhm la dgn 'offset' ni... kpd otai sioloon, sila beri tnjk ajar.... klu ttg saiz rim tu x masalah... yg mslh offset ni.... takut kejadian lama berulang kembali masa pki kereta lama... dlu pki kereta lama tkr sport rim, kuat hentak ms lalu jln x rata.... ada org ckp 'offset' x ngam.... tp sy kurang fhm dgn 'offset' rim ni.... klu utk myvi brp 'offset' yg sesuai??? kpd pengguna2 myvi @ otai sioloon hrp dpt membantu... tq tq tq.... |
aLFFiaN ADMINISTRATOR
Countries/State : Age : 41 location : Borneo Island Website : www.sioloon.com Tag ID: : SFC00001 Points : 14726 Reputation : 101 Number of posts : 7895
| Subject: Re: offset rim apa yg sesuai??? 18/6/2010, 11:07 pm | |
| The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types. Zero Offset The hub mounting surface is even with the centerline of the wheel. Positive The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars. Negative The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset. If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. 15x6.5 Offset 35~40 is acceptable. too much offset ... rims might rub against the inner parts of the wheel arch. too little offset ... might rub against the outer fender. |
Mivec_23 FRESHIE
Countries/State : Age : 42 location : Keningau Points : 10162 Reputation : 1 Number of posts : 6
| Subject: Re: offset rim apa yg sesuai??? 19/6/2010, 12:52 pm | |
| emm how bout wira bro?...
klu pakai rim 16" ..amcm offset yang ngam kunu..thanksss |
dexbeckz JUNIOR
| Subject: Re: offset rim apa yg sesuai??? 19/6/2010, 9:56 pm | |
| bro aLFFiaN... so u mean 15x6.5 Offset 35~40 ada la sesuai utk myvi??? klu macam tu, thanks 4 da info... really help me... |
dexbeckz JUNIOR
| Subject: Re: offset rim apa yg sesuai??? 19/6/2010, 10:02 pm | |
| ohhh kira offset ni, macam jarak tgh dlm rim tu la.... |
nawi19 SENIOR
Countries/State : Age : 34 location : kk Points : 10888 Reputation : 5 Number of posts : 593
| Subject: Re: offset rim apa yg sesuai??? 19/6/2010, 10:17 pm | |
| bro..offset tuk myvi yg ngam tuk myvi 40 or 42..dlu aku pkai 17inci,lebar 7.5jj,offset 42..ptg spring lgi..x sangkut angkat org..then aku tukar rim baru 17inci juga,tp lebar 7.5jj n offset 38..sangkut gila..then aku grind tulang fender..skrg no hal angkat org..tp 3 org ja la..hehehe..hope blhh bantu ko..ni pengalaman aku la..hehehe |
dexbeckz JUNIOR
| Subject: Re: offset rim apa yg sesuai??? 23/6/2010, 9:38 am | |
| - nawi19 wrote:
- bro..offset tuk myvi yg ngam tuk myvi 40 or 42..dlu aku pkai 17inci,lebar 7.5jj,offset 42..ptg spring lgi..x sangkut angkat org..then aku tukar rim baru 17inci juga,tp lebar 7.5jj n offset 38..sangkut gila..then aku grind tulang fender..skrg no hal angkat org..tp 3 org ja la..hehehe..hope blhh bantu ko..ni pengalaman aku la..hehehe
ohh offset 40 la ok... tp klu rim dia kecil skit macam 15 @ 16 inci, offset masi pki yg sm ka??? 1 lg, mn ko beli rim ko bro??? mn tau bole minta nasihat dr tauke rim tu.... tq... |
nawi19 SENIOR
| Subject: Re: offset rim apa yg sesuai??? 24/6/2010, 6:02 am | |
| ooo aku beli rim ngan member aku juga..bro mau pakai 17 ka??cari offset 40 or 42 la..baru 7jj..tayar pkai 205/40/17.. |
dexbeckz JUNIOR
| Subject: Re: offset rim apa yg sesuai??? 3/7/2010, 9:41 am | |
| - nawi19 wrote:
- ooo aku beli rim ngan member aku juga..bro mau pakai 17 ka??cari offset 40 or 42 la..baru 7jj..tayar pkai 205/40/17..
okok.. offset 40 or 42... sy fhm sda... tp tgh fikir saiz rim lg ni... 16 @ 17... nti besar sgt rasa berat & tyr pula mhl.... apa pun, thanks bro... |
muzz FRESHIE
Countries/State : Age : 44 location : kuching Points : 10126 Reputation : 1 Number of posts : 14
| Subject: Re: offset rim apa yg sesuai??? 10/7/2010, 12:09 pm | |
| pakai offset 6.5 bro...cun la tu.. |
gagoilak FRESHIE
Countries/State : Age : 47 location : kota kinabalu Points : 10547 Reputation : 1 Number of posts : 10
| Subject: Re: offset rim apa yg sesuai??? 14/7/2010, 7:39 pm | |
| askm.dan salam 1 malaysia bro2...mau tanya... tdi gua ada beli rim 16 punya off set nya 40...so..tayar saiz apa yang sesuai di gunakan?? coz mau pasang kat kereta waja gua ne bah...tlg la gua bgi pndapat... |
| Subject: Re: offset rim apa yg sesuai??? | |
