| Author | Message |
dre42 JUNIOR
Countries/State : Age : 43 location : Selangor Points : 10466 Reputation : 1 Number of posts : 104
| Subject: Drego Import -New Year Sale-ALL mUST gO 14/12/2010, 12:31 pm | |
| | | dre42 JUNIOR
| Subject: D-Imports TurbochargerS,TD05 20G,T3T4,T70,T25T28 14/12/2010, 12:37 pm | |
| MERRY CHRISTMAS
Drego Imports[/size][color=blue]
STOCK CLEARRANCE !!!
TDO5 16G EVOIII RM1200-OUT OF STOCK
BRAND NEW IN BOX
TD05H -16g ( WATER COOLING )- Mitsubishi EVO ,water cooling , twin fins-16g internal wastegate, TD05H is twin fins compressor wheel . Flow range is 0.05-0.22 kg/s , work for 50-130kw engine. ( especially for EVO III ) UP TO 350 HORSEPOWER
TURBOCHARGER T3/T4 STAGE III WHEEL BRAND NEW RM1200
1/8 NPT OIL INLET T3 / T4 FLANGE FITS T3 AND T3/T4 MANIFOLDS SPECS: . 50 A/R COMPRESSOR .63 A/R TURBINE.57 TRIM
THIS TURBO CAN EASILY DO 25 psi
Standard T3 Flange, TURBINE WHEEL: EXDUCER: 2.48" MAYOR : 2.89"
COMPRESSOR WHEEL : EXDUCER: 2.07" MAYOR : 2.36" 5 BOLT FLANGE SUITS EXTERNAL WASTEGATE
Super T70 turbo RM1600
PRODUCT T70 turbo specs wet float bearings, 1/8 NPT oil inlet compressor a/r = 0.70 turbine a/r =0.84 shaft and wheel trim = 58mm compressor wheel = 56.5mm diameter inlet 4" oulet 2.5" V band rear oil cooled T3 flange
rated to 600hp plus,
in stock now ready to ship
TD05H 20G RM1200
Features: TD05H TURBO UNIT Utilize external wastegate Made of Quality Cast material Oil cooled & lubricated center section - journal bearing Suggested vehicle with1.6L to 2.5L engine: Up to 300-450bHP 3 Bolt Exhaust flange, 5 bolt downpipe flange All flanges pictured are included as well as internal wastegate
Turbo Specs: Journal Bearing and oil cooled Inlet: 2 3/8", Outlet 1 5/8" Compressor :60 trim exducer 79.6 inducer 52 0.50 A/R Turbine: 77 trim exducer 49 inducer 50 N/A A/R
T25/T28 RM960
T25 Flange, Dimension: 73 * 40 Oil Cooled, Inlet: M10*1.5, outlet: 2 M8 Max Power: 270hp, spool time at 2500 RPM Compressor Wheel 0.42 A/R Cold Side Ind: 37.8 mm Exd: 59.7 mm Trim: 40 Turbiner Wheel 5-Bolt Standard 0.86 A/R Hot Side Ind: 52.9 mm Exd: 45.47 mm Trim: 73 25-27 PSI Power Performance Output Internal wastegate at 8PSI CNC Machined Flanges
CALL/TXT 0123505832
DREGO IMPORTS 49D JALAN PJS 1/48 PETALING UTAMA 7,PETALING JAYA Tel: 0377811481 Malaysia ,New Zealand - Attachments
- You don't have permission to download attachments.
- (57 Kb) Downloaded 0 times
- (13 Kb) Downloaded 0 times
| | | dre42 JUNIOR
| Subject: D-Imports intercoolers -evo,vr4,gtr 14/12/2010, 12:42 pm | |
| [SIZE="7"]Drego-Imports[/SIZE]
SPECIAL PROMOTION -NEW SHIPMENT ARRIVED
GT SPEC Intercooler RM550 1.Awesome core to make a custom front mount kit 600*300*76 (GTR SIZE)
Core Size 600*300*76 Overall 780*30076
These intercoolers features:
*Less pressure drop.30% lighter in weight,It effectively reduces turbo lag as well as widen the power bend,Increases maximum power with less engine stress which makes them a perfect for Drag,Drift,Street and Race Use Compressed air flow rate: <750 cubic feet/min - 700-800 Max HP Working pressure:35-40psi pressure drop : 2-5psi @ 35psi / .2 -5psi @15psi
450*300*76 -VR4 & EVO SIZE RM450
VR4 Size: Core size 450*300*76, Awesome core to make a custom front mount kit, medium aluminium polished intercooler. it is a bar and plate type cooler with core size of 450x300x76 and 3" inlet/outlets. Overall length is 630x330x76mm designed for huge air flow, with results showing at least 15hp gained
550*230*65 RM320(VR4,EVO)
Evo, Nissan ETC:Core size 550*230*65 Overall Size 700*230*65, Bar and plate construction, Up to 600PS Working Pressure 10-40psi, Compressed air flow rate: 572CFM/300HP 858CFM/800HP Pressure Drop : 1.5-2.5 psi@35psi : 0.1-0.3psi@15psi, Hot Air Temp: 0-150C,
D-Imports is a registered Trade Mark,Manufactured in Taiwan and assembled in New Zealand.
]CALL/TXT 0123505832]
]DREGO IMPORTS 49D JALAN PJS 1/48 PETALING UTAMA 7 OFF OLD KLANG ROAD,PETALING JAYA,SELANGOR TEL :0377811481 Malaysia,New Zealand EMAIL : ANDRE.REDLINE@GMAIL.COM - Attachments
- (26 Kb) Downloaded 0 times
- (41 Kb) Downloaded 0 times
| | | dre42 JUNIOR
| Subject: D-Imports Evo 4-9 Cast Iron Manifold 14/12/2010, 12:44 pm | |
| DREGO IMPORTS
EVO 4-9 Cast Iron Manifold
RM800
Time to upgrade that stock restrictive turbo and upgrade to a larger more powerful T3/T4 turbo. Very popular cast manifold has put Evo into the 10's! These manifolds are very durable and will withstand all the heat and vibration you can throw at them.
Call / Txt 0123505832
Drego Imports - Attachments
- (5 Kb) Downloaded 0 times
| | | dre42 JUNIOR
| Subject: D-Imports Honda B16,B18 Turbo Cast Iron Manifold 14/12/2010, 12:45 pm | |
| DREGO IMPORTS
Honda B16 B18 Turbo Cast Iron Manifold
RM700
Molded from industrial grade cast iron, this manifold will withstand extreme heat and will never crack, versus the conventional tubular manifolds. This is a great set up if you are looking for mid ranged power (200-390WHP).
Drego Imports |
| | | dre42 JUNIOR
| Subject: Re: FORGED RACING RADIATOR 18/12/2010, 2:55 pm | |
| | | dre42 JUNIOR
| Subject: Re: FORGED RACING RADIATOR 18/12/2010, 2:56 pm | |
| | | Fredy Yeong CONTRIBUTOR
Countries/State : Age : 28 location : LDU - TWU - SDK Website : www.sioloon.com Tag ID: : SFC 17293 Points : 11374 Reputation : 12 Number of posts : 1072
| Subject: Re: FORGED RACING RADIATOR 18/12/2010, 3:10 pm | |
| wakaka... |
| | | dre42 JUNIOR
| Subject: Re: FORGED RACING RADIATOR 21/12/2010, 1:45 pm | |
| | | dre42 JUNIOR
| Subject: Re: FORGED RACING RADIATOR 21/12/2010, 1:47 pm | |
| | | dre42 JUNIOR
| | | dre42 JUNIOR
| Subject: Re: FORGED RACING RADIATOR 21/12/2010, 1:49 pm | |
| | | dre42 JUNIOR
| Subject: Re: FORGED RACING RADIATOR 11/1/2011, 6:04 pm | |
| | | dre42 JUNIOR
| Subject: Re: FORGED RACING RADIATOR 11/1/2011, 6:05 pm | |
| | | dre42 JUNIOR
| Subject: Re: FORGED RACING RADIATOR 11/1/2011, 6:07 pm | |
| | | dre42 JUNIOR
| Subject: Honda B16/18 Race Header,Radiator,Lower Arm,Air ram pipe 25/1/2011, 5:56 pm | |
| | | dre42 JUNIOR
| Subject: STOCK CLEARANCE SALE !!!ALL MUST GO 9/2/2011, 12:19 pm | |
| Drego Imports [size=150]STOCK CLEARRANCE !!!ALL MUST GO[/size]BRAND NEW IN BOX TD05H -16g ( WATER COOLING )- Mitsubishi EVO ,water cooling , twin fins-16g internal wastegate, TD05H is twin fins compressor wheel . Flow range is 0.05-0.22 kg/s , work for 50-130kw engine. ( especially for EVO III ) UP TO 350 HORSEPOWER TURBOCHARGER T3/T4 STAGE III WHEEL BRAND NEW [size=150]RM1000 [/size] NORMAL RETAIL RM12001/8 NPT OIL INLET T3 / T4 FLANGE FITS T3 AND T3/T4 MANIFOLDS SPECS: . 50 A/R COMPRESSOR .63 A/R TURBINE.57 TRIM THIS TURBO CAN EASILY DO 25 psi Standard T3 Flange, TURBINE WHEEL: EXDUCER: 2.48" MAYOR : 2.89" COMPRESSOR WHEEL : EXDUCER: 2.07" MAYOR : 2.36" 5 BOLT FLANGE SUITS EXTERNAL WASTEGATE Super T70 turbo [size=150] RM1400 [/size] NORMAL RETAIL RM1600This is a High Quality Turbo, with Big Wheels, Good For 400 to 500 HP Applications, Such as Mustang, Supra, RX7, and other 4-Clyn Engines with high Power Setup. Civic B18, B20, 240SX SR20DET, RB20, RB25, Eclipse 4G63. PRODUCT T70 turbo specs wet float bearings, 1/8 NPT oil inlet compressor a/r = 0.70 turbine a/r =0.84 shaft and wheel trim = 58mm compressor wheel = 56.5mm diameter inlet 4" oulet 2.5" V band rear oil cooled T3 flange rated to 600hp plus, in stock now ready to ship TD05H 20G [size=150] RM1000 [/size] NORMAL RETAIL RM1200Features: TD05H TURBO UNIT Utilize external wastegate Made of Quality Cast material Oil cooled & lubricated center section - journal bearing Suggested vehicle with1.6L to 2.5L engine: Up to 300-450bHP 3 Bolt Exhaust flange, 5 bolt downpipe flange All flanges pictured are included as well as internal wastegate Turbo Specs: Journal Bearing and oil cooled Inlet: 2 3/8", Outlet 1 5/8" Compressor :60 trim exducer 79.6 inducer 52 0.50 A/R Turbine: 77 trim exducer 49 inducer 50 N/A A/R T25/T28 [size=150] RM800 [/size] NORMAL RETAIL RM960T25 Flange, Dimension: 73 * 40 Oil Cooled, Inlet: M10*1.5, outlet: 2 M8 Max Power: 270hp, spool time at 2500 RPM Compressor Wheel 0.42 A/R Cold Side Ind: 37.8 mm Exd: 59.7 mm Trim: 40 Turbiner Wheel 5-Bolt Standard 0.86 A/R Hot Side Ind: 52.9 mm Exd: 45.47 mm Trim: 73 25-27 PSI Power Performance Output Internal wastegate at 8PSI CNC Machined Flanges CALL/TXT 0123505832 DREGO IMPORTS 49D JALAN PJS 1/48 PETALING UTAMA 7,PETALING JAYA Tel: 0377811481 Malaysia ,New Zealand |
| | | dre42 JUNIOR
| Subject: SPARCO FIGHTER 17/2/2011, 5:57 pm | |
| DREGO IMPORTS
Brand NEW -BLACK Sparco Fighter Full Bucket Seat Comes with universal railing, -BLACK color only. -Fit up to waist size 40 without any problem.
RM580-EACH
HAVE 1 PAIR IN STOCK IF ANYONE INTERESTED
DREGO IMPORTS CALL /TXT 0123505832 ANDRE.REDLINE@GMAIL.COM |
| | | dre42 JUNIOR
| | | | dre42 JUNIOR
| Subject: FORGED RACING RADIATOR 24/2/2011, 11:00 am | |
FORGED RACING radiators are based on sophisticated technology, 100% brazed aluminium cores for a clean OEM fit, designed to be effective in reducing the heat from vital areas, as the design have more tube surface for primary cooling and fewer fins allowing it to cool much more effectively. The technology used in FORGED RACING radiators and heater cores allow for greater heat transfer using the same or less space required for traditional copper/brass components.
Two additional benefits of aluminium racing radiators are strength and weight. Most radiators have the tanks welded to the tubes rather than brazed or sealed with epoxy. This makes the radiator much stronger and more capable of standing up to the rigors of racing. FORGED RACING aluminium racing radiators are also much lighter than original radiators because of the lighter materials and lower fin counts.
AVAILABLE FOR :
H/EK/EG B16A Manual RM850
H/ FD2 2.0 RM1050
H/DC2 RM950
Mit/Evo 1-3 RM950
Mit/Evo 4-6 RM950
Mit/Evo 7-9 RM950
Mit/Airtrek Turbo RM1200
P/Gen2/waja 1.8/Persona offer price until stock finish RM850
P/Myvi 1.3 offer price until stock finish RM700
[SIZE="5"]DREGO IMPORTS 0123505832 EMAIL : [email]Andre.redline[/SIZE]@[SIZE="5"]gmail.com[/SIZE][/email] |
| | | Sponsored content
| Subject: Re: FORGED RACING RADIATOR | |
Similar topics | |
Similar topics | |
Page 1 of 1 | |
Mahu Bincang Tentang?
Aktiviti Kelab Sioloon?
Mencari Yang Menarik?
