Saga facelift bakal menganti design saga BLM sebelum ini
Sebelah kiri adalah wajah baru SAGA . Perubahan dari segi Grill depan,Bumper,head lamp dan rekabentuk bonet hadapan.
Kini headlamps SAGA Facelift menggunakan 3 bulbs sebelum ini hanya menggunakan 2 sahaja. Manakala lampu signal diubah masuk ke dalam berbanding sebelum ini.
Side mirror dilengkapi signal lamps
Pada bahagian belakang pula, lampu telah ditukar agak kecil sedikit dan dilengkapi dengan LED lighting. Di atas bonet belakang ditambahdengan spoiler kecil bagi menampakkan pandangan lebih cantik. Selain itu bumper pada bahagian bawah sekali dilengkapi
dengan reflector lamp bagi memantulkan cahaya pada waktu malam.
The 1-DIN Clarion radio looks the same to us (except for the MP3/WMAlogos which indicate support for those files), but there are new USBand AUX-in ports which are not integrated into the radio but areinstead positioned to the lower right of the radio. This takes up someof the cubby hole space below the radio.
Stering dinaiktaraf memiliki button audio
The fabric pattern on the door cards and the seats are now of adifferent design (old one is on the left).
There are now rear power window button controls. As for which of the Malaysian car specs will feature rear power windows and which
won’t,we’ll have to wait for the Malaysian launch.
Pada bagaian RIM hanya rekabentuk sahaja diubah manakala saiznyatetap sama iaitu 185/60R/14
There’s now the option for a front passenger airbag which takes up the ’tissue box’ holder compartment in the pre-facelift Saga.These are the only changes we are able to see so far, and we have tonote that some of these updates like the USB/AUX function, the extraairbag and the rear power windows could only be for the higher specmodels. Four colours are available in Thailand – Solid White,Tranquility Black, Genetic Silver and the new colour you see here whichis Blue Rock.
There could be other changes on the mechanical side of thingsthough, which we will probably only be able to find out when we speakto Proton’s engineers in Malaysia. The Thai spec sheet (which you willbe able to see after the jump) quotes 70kW and 120Nm, which is the sameas the pre-facelift Saga.
sumber : paultan.org
