lim FRESHIE
Age : 56 location : twu Points : 11274 Reputation : 0 Number of posts : 3
| Subject: valve clearance 13/12/2008, 8:40 am | |
| salam semua. kamu tolong dulu abang kamu ni... what is the best gap utk itu valve ah? supaya itu rpm cepat naik.. bagitau detail ah.. intek=? ekzos=? mau pergi edjas ni |
mr.md SUPERIOR
Countries/State : Age : 44 location : anyway Tag ID: : SFC 03898 Points : 12669 Reputation : 9 Number of posts : 2289
| Subject: Re: valve clearance 13/12/2008, 12:54 pm | |
| mr..blugu...where are u?...kekeke ..need some help here... |
Countries/State : Age : 45 location : Kota Kinabalu-Putatan Tag ID: : SFC02202 Points : 12203 Reputation : 10 Number of posts : 2945
| Subject: Re: valve clearance 13/12/2008, 1:42 pm | |
| - lim wrote:
- salam semua. kamu tolong dulu abang kamu ni... what is the best gap utk itu valve ah? supaya itu rpm cepat naik.. bagitau detail ah.. intek=? ekzos=? mau pergi edjas ni
Ikut OEM punya valve clearance saja, sy sarankan bro utk RETARD 1 gigi setting cam pulley (kalau pakai enjin SOHC) Lepastu, rendahkan sedikit timing distributor bro tuh Slamat mencuba! |
Ujang87 MODERATOR
Countries/State : Age : 37 location : all rounder,sabah Points : 11690 Reputation : 3 Number of posts : 1899
| Subject: Re: valve clearance 13/12/2008, 5:08 pm | |
| yal bagus ikut OEm punya setting tu.. ikut langkah mr Blugu itu barulah best.. |
mr.md SUPERIOR
| Subject: Re: valve clearance 13/12/2008, 8:59 pm | |
| br.blugu...klu retard tu 1 gigi cam pulley mo kasi depan ka..mo kasi blakang?...i mean dia punya rotation.. |
Countries/State : Age : 35 location : Kota Kinabalu Tag ID: : SFC 01287 Points : 13593 Reputation : 34 Number of posts : 5595
| Subject: Re: valve clearance 14/12/2008, 1:45 am | |
| apa kereta bro for valve clearance? bukan semua jenis boleh buat valve clearance sesuka hati. kalau rocker arm punya jenis boleh lah.
paling best punya clearance, ikut original punya. |
| Subject: Re: valve clearance 14/12/2008, 2:42 am | |
| - mr.md wrote:
- br.blugu...klu retard tu 1 gigi cam pulley mo kasi depan ka..mo kasi blakang?...i mean dia punya rotation..
Retard.. set cam pulley pergi depan, pick up kuat, set pergi blakang (advance), pick up lambat, enjin respond apabila crank start jadi berat, tp bila RPM sampai 4000 - 5000, enjin jadi ringan & top end meningkat.... biasa org pakai racing cam pakai setting ini, but don't do this setting if you ride is only on Manufacturer setting |
mr.md SUPERIOR
| Subject: Re: valve clearance 15/12/2008, 6:42 pm | |
| bro..klu injin wira yg teda distributor tu...buli set jg ka?... |
| Subject: Re: valve clearance 15/12/2008, 10:07 pm | |
| ada atau tidak boleh set juga, tapi yang penting dia adalah jenis rocker arm, dan bukannya pakai shim. |
mr.md SUPERIOR
| Subject: Re: valve clearance 15/12/2008, 10:41 pm | |
| tu ignition timing cmana mo buat..?....kita crita pasal SOHC n rocker arm la ni.. |
| Subject: Re: valve clearance 15/12/2008, 10:48 pm | |
| oh maaf bro hehehe, silap baca. itu kena set pakai computer tu bro, macam kelisa, kenari semua gitu juga. |
mr.md SUPERIOR
| Subject: Re: valve clearance 16/12/2008, 12:55 pm | |
| ok bha klu ko bro |
| Subject: Re: valve clearance 16/12/2008, 12:57 pm | |
| tapi ada engine walaupun dia jenis distributorless macam 4G91 atau 93, dia masih ada plug cable, tidak macam kelisa, tapi ianya masih boleh diadjust disebelah engine valve cover juga. |
mr.md SUPERIOR
| Subject: Re: valve clearance 16/12/2008, 6:40 pm | |
| apa namanya tu bro...ignition rotor ka?.. |
fuumin CONTRIBUTOR
Countries/State : Age : 39 location : Lahad Datu, Sabah Tag ID: : SFC3259 Points : 12625 Reputation : 7 Number of posts : 1048
| Subject: Re: valve clearance 3/10/2011, 7:10 pm | |
| baru2 ni enjin l2 ku bikin general overhaul..bila smua da psg blk ,mekanik bgtau valve x dpt setting smua sbb ada yg jemm xdpt pusing..jd bunyi enjin agak kasar..skrg mau try bawa smpi 1000km dlu bru bikin maintenance n cuba lg kasi set itu valve..ada effect ka tu yah sma enjin? |
qj3 FRESHIE
Countries/State : Age : 43 location : Kinabatangan Points : 10134 Reputation : 4 Number of posts : 64
| Subject: Re: valve clearance 5/10/2011, 12:42 am | |
| bro,
valve bukan pusing tapi naik turun..klu valve tu macam jem atau keras..bingkuk tu.. standat L2 intake 0.25 exzos 0.30 |
fuumin CONTRIBUTOR
| Subject: Re: valve clearance 5/10/2011, 8:23 am | |
| bro mksdku ,itu nat utk ejas setting valve ada yg x dpt pusing.. |
qj3 FRESHIE
| Subject: Re: valve clearance 6/10/2011, 3:25 am | |
| ooo..
ui jarang tu kes bgitu..susa tu nat mo jem..atau pun ko suda pusing abis kasi turun, jdi x boleh pusing lagi.. |
fuumin CONTRIBUTOR
| Subject: Re: valve clearance 6/10/2011, 6:42 am | |
| iya bro qj mmg jemm tu nat..bkn nya da pusing hbs kasi turun..tu yg mslh tu ,ada yg x dpt ejas..so pomen suru bw sja dlu..mna tau blh kasi ilang tu karat2 |
kent1189 CONTRIBUTOR
Countries/State : Age : 40 location : miri sarawak Website : http://www.lowisslow.com Tag ID: : SFC 18976 Points : 10723 Reputation : 19 Number of posts : 1183
| Subject: Re: valve clearance 6/10/2011, 2:18 pm | |
| cuba pusing nut tu time enjin sejuk bro, maybe time panas besi tu mengembang..x pnah juga aku dngar kes x dpt pusing nut nih. karat x mungkin la sbb minyak semua dlm tu.. |
qj3 FRESHIE
| Subject: Re: valve clearance 7/10/2011, 12:13 am | |
| oo kira selamat lgi la tu..tpi klu tu nat suda turun abis smpi tiada gap,pastu jem x dpat kasi naik,bhaya tu..high rpm buli beantuk tu piston sama valve tu..pling abis turun pun klu intake 0.18mm ja..klu exzos 0.25mm..kurang dri tu bahaya suda..ni utk turbo la.. |
fuumin CONTRIBUTOR
| Subject: Re: valve clearance 7/10/2011, 10:02 am | |
| bro kent ,tu pomen adjust time siap bikin overhaul ,mmg enjin sejuk time tu..ada rekod tersendiri ba ni enjin ku sblm² ni iaitu x maintenance selama 2 thn ,hnya tmbh2 myk enjin sja hehe..mgkn tu sbb blh smpi ada ntah apa karat atau kerak2 smpi kasi jem tu nat..nnt nxt week bru try ejas lg..
enjin ku bro qj sejak psg bunyinya mmg senyap sja ,standard habis n blh nmpk x pnh bikin overhaul ,standard kilang la katakan..jd tu nat ejas valve knfm x pnh usik..bbrapa thn lps psg bru bunyi enjin ada kasar skit ,n lps overhaul pun masi kasar jg la sbb x dpt ejas bgs2 tu valve..bro qj ,macam mna mau tau pomen setting dgn bgs ? mksdku klu tgk msa dia buat keja spya blh aku bg komen skit2 nnt hehe |
| Subject: Re: valve clearance 7/10/2011, 1:15 pm | |
| valve ni mau org yg pandai ejas bro, x boleh setakat pndai guna blade sja. aku ada mmber yg pakar ejas valve ni. mmg dia pkai blade utk tengok clearance tu. aku tengok dulu dia ejas pkai blade, pas tu cuba tarik/tekan pkai tangan, pas tu pusing lagi satu skru d dlm arch tayar depan sblah driver tu (skru utk pusing cranksharf rasanya), tthen ejas lagi valve, pusing cransharf, ejas lagi valve dan seterusnya smpai dia puas hati valve tu cun. hasilnya mmg memuaskan, pas dia wat pickup mmg naik mendadak.. enjin pn smooth. ni cara pomen aku keja la, kalu d tmpt lain aku x tau la camana cara mereka wat.. mungkin skrg org pkai komputer suda ejas ni vave.. |
Countries/State : Age : 34 location : Kemaman - Kota Bharu Website : contact 01119778382 Tag ID: : SFC08063 Points : 14907 Reputation : 69 Number of posts : 3981
| Subject: Re: valve clearance 7/10/2011, 1:43 pm | |
| - kent1189 wrote:
- valve ni mau org yg pandai ejas bro, x boleh setakat pndai guna blade sja. aku ada mmber yg pakar ejas valve ni. mmg dia pkai blade utk tengok clearance tu. aku tengok dulu dia ejas pkai blade, pas tu cuba tarik/tekan pkai tangan, pas tu pusing lagi satu skru d dlm arch tayar depan sblah driver tu (skru utk pusing cranksharf rasanya), tthen ejas lagi valve, pusing cransharf, ejas lagi valve dan seterusnya smpai dia puas hati valve tu cun. hasilnya mmg memuaskan, pas dia wat pickup mmg naik mendadak.. enjin pn smooth. ni cara pomen aku keja la, kalu d tmpt lain aku x tau la camana cara mereka wat.. mungkin skrg org pkai komputer suda ejas ni vave..
kalau enjin pakai tappet, ni je cara utk ejas valve clearance.. xbleh pkai komputer lg.. kalau enjin yg pkai shim, kena anta machine balik camshaft |
| Subject: Re: valve clearance 7/10/2011, 2:28 pm | |
| apa "tappet" dan "shim" tu bro keba? x pnah dngar pon.. |
| Subject: Re: valve clearance | |
