| | Author | Message |
roy1112 FRESHIE
Countries/State : Age : 34 location : Inanam Points : 11622 Reputation : 0 Number of posts : 50
| Subject: 4G92 SOHC Modification 27/11/2012, 8:04 pm | |
| taiko2 sekalian..cuba ajar dlu pa mau buat untuk kasi tmbh power ni enjin..piston 1.8 or turbokit?which one is better?mana yg x tlmpau mahal tp ptmbahan power lebih byk.. |
| | | blugu ADMINISTRATOR
Countries/State : Age : 45 location : Kota Kinabalu-Putatan Tag ID: : SFC02202 Points : 12221 Reputation : 10 Number of posts : 2945
| Subject: Re: 4G92 SOHC Modification 29/11/2012, 4:54 pm | |
| - roy1112 wrote:
- taiko2 sekalian..cuba ajar dlu pa mau buat untuk kasi tmbh power ni enjin..piston 1.8 or turbokit?which one is better?mana yg x tlmpau mahal tp ptmbahan power lebih byk..
+ power Piston 1.8 = piston 1.6 ( bore saiz 81mm) Turbokit - beli turbo, tukar injector, modified exhaust system, + piggyback (retune), masa & duit yg byk utk Research & development. Modified utk kasi kuat 4G92S, either tukar head p twin cam, 60-70 mm throttle body, tukar intake manifold, racing flywheel, light crank pulley, adjustable crank pulley, 4-1 / 4-2-1 out take manifold, 2" exhaust piping, racing cam, piggy back (Emanage, SaFC, FCON, etc) utk retune semua tu resipi |
| | | roy1112 FRESHIE
| Subject: Re: 4G92 SOHC Modification 30/11/2012, 8:32 am | |
| | | roy1112 FRESHIE
| Subject: Re: 4G92 SOHC Modification 30/11/2012, 8:41 am | |
| kalau mau men tukar piston,mau guna piston pa? or x paya tukar piston?just buat pa yg tuan ckp d ats? |
| | | firdausfarouk01 FRESHIE
Countries/State : Age : 32 location : pahang Points : 8400 Reputation : 1 Number of posts : 4
| Subject: Re: 4G92 SOHC Modification 8/12/2012, 7:48 pm | |
| tukar piston mivec atau b16..piston high compression |
| | | blugu ADMINISTRATOR
| Subject: Re: 4G92 SOHC Modification 13/12/2012, 8:25 am | |
| - roy1112 wrote:
- pakai head apa,bos?
Head SOHC pun masi bleh, ndada masalah, kalau mampu... carila head 4G91, wiring system pun kena tukar utk ni head (4g91) ... kalau suruh cari mekanik utk buat semua ni, sy ndada info - roy1112 wrote:
- kalau mau men tukar piston,mau guna piston pa?
or x paya tukar piston?just buat pa yg tuan ckp d ats? setup fidaus pun ok suda tu, bore 81mm, so.. tidak perlu buat oversize blok |
| | | roy1112 FRESHIE
| Subject: Re: 4G92 SOHC Modification 19/12/2012, 10:47 pm | |
or x paya tukar piston?just buat pa yg tuan ckp d ats? setup fidaus pun ok suda tu, bore 81mm, so.. tidak perlu buat oversize blok jadi skg sa cuma perlu cari piston mivec or b16 ja la? |
| | | blugu ADMINISTRATOR
| Subject: Re: 4G92 SOHC Modification 28/12/2012, 10:04 am | |
| Semuanya terpulang pada anda |
| Subject: Re: 4G92 SOHC Modification 9/4/2013, 12:40 pm | |
| macam mne perkembangan??? |
| | | Sponsored content
| Subject: Re: 4G92 SOHC Modification | |
Similar topics | |
Similar topics | |
Page 1 of 1 | |
Mahu Bincang Tentang?
Aktiviti Kelab Sioloon?
Mencari Yang Menarik?
