| sape bole bg info pasl modified single cam.. | |
faizuli91 FRESHIE
Age : 32 location : johor bahru Points : 12000 Reputation : 0 Number of posts : 35
| Subject: sape bole bg info pasl modified single cam.. 10/3/2008, 8:56 pm | |
| alo all member...kwn tengah nak carik cara yang betul untuk modefide 1.6 single cam. kwn malas nak tukar enjin ni pening kepala lah. .kalu ade info pasal modefide enjin 1.6 single cam bagi2 le kat kwn. hehehehehehe. die pkai satria 1.6... |
| Subject: Re: sape bole bg info pasl modified single cam.. 11/3/2008, 6:39 am | |
| - faizuli91 wrote:
- alo all member...kwn tengah nak carik cara yang betul untuk modefide 1.6 single cam. kwn malas nak tukar enjin ni pening kepala lah. .kalu ade info pasal modefide enjin 1.6 single cam bagi2 le kat kwn. hehehehehehe. die pkai satria 1.6...
Dia nak psg turbo? atau cuma nak main N/A? Kelebihan Single cam adalah pada torque pick up, tewas pada top end, enjin nie bleh di upgrade sama seperti twin cam, cuma kosnya murah sedikit berbanding dgn twincam, kerana terpaksa beli 2 cam pulley & cam |
^TeRRoRiSTz^ REGULAR
Age : 48 location : Manjung, Perak Points : 12132 Reputation : 0 Number of posts : 439
| Subject: Re: sape bole bg info pasl modified single cam.. 11/3/2008, 9:40 am | |
| Masuk jak hicam, adjustable cam pulley, lighten crank pulley, buat port polish, masuk JAF extrector, buat piping yg cun, upgrade computer box ( masuk chip ka atau tuka jek management) .. sure mantap pas nie.. |
faizuli91 FRESHIE
| Subject: Re: sape bole bg info pasl modified single cam.. 11/3/2008, 12:18 pm | |
| klau die psang turbo kne wat pe lg bro?..klau main n/a plak nk wat per?.. klau bley bg info 2 2 tu bro..thanx.. |
| Subject: Re: sape bole bg info pasl modified single cam.. 11/3/2008, 12:24 pm | |
| - ^TeRRoRiSTz^ wrote:
- Masuk jak hicam, adjustable cam pulley, lighten crank pulley, buat port polish, masuk JAF extrector, buat piping yg cun, upgrade computer box ( masuk chip ka atau tuka jek management) .. sure mantap pas nie..
Tukar cam 272 degree, cari di powerzone atau matspeed extractor 4-1 atau 4-2-1 Piggy back - Emanage, SAFC, etc Drop in air filter - K&N Piping dari depan sampai blakang pakai 1.7 - 2 inci Tambah² saja... |
diff lock FRESHIE
Age : 47 location : tg lipat Points : 11840 Reputation : 0 Number of posts : 47
| Subject: Re: sape bole bg info pasl modified single cam.. 11/3/2008, 9:32 pm | |
| bro..klu ko masuk turbo jak..nda ble boost tinngi nanti pinking..paling bagus ko tukar piston low compression..VR4 turbo punya piston..tp kna masuk sekali sma con rod..Bagus ko main NA jak..bnyk masalah.. |
faizuli91 FRESHIE
| Subject: Re: sape bole bg info pasl modified single cam.. 12/3/2008, 8:21 am | |
| ooo...ok bro..thanx...klau nk bikin yg turbo punye cmaner r?? |
| Subject: Re: sape bole bg info pasl modified single cam.. 12/3/2008, 11:17 am | |
| Cari piston GSR atau 4G93T kalau mau main turbo |
Age : 42 location : Semporna / Tawau / Lahad Datu / Flamingo / Putatan Points : 12494 Reputation : 3 Number of posts : 1106
| Subject: Re: sape bole bg info pasl modified single cam.. 12/3/2008, 4:32 pm | |
| kalau modified gila2 bagi keta NA ko pegi area SEMPORNA. |
| Subject: Re: sape bole bg info pasl modified single cam.. 12/3/2008, 6:11 pm | |
| N/A is better... huhuhuhuhu MIVEC ROCK... |
| Subject: Re: sape bole bg info pasl modified single cam.. 13/3/2008, 8:03 pm | |
- N/A is better... huhuhuhuhu
MIVEC ROCK... Ya, mivec jugala yg power |
| Subject: Re: sape bole bg info pasl modified single cam.. 14/3/2008, 9:59 am | |
| di SEMPORNA diorg main cara tipu2, head 1.5 tapi blok fuh sdh 1.8 |
| Subject: Re: sape bole bg info pasl modified single cam.. 14/3/2008, 7:54 pm | |
| nie mau tanya cip blugu... |
te37 MODERATOR
Countries/State : Age : 37 location : Kota Kinabalu - Keningau Tag ID: : SFC 02132 Points : 12190 Reputation : 0 Number of posts : 2660
| Subject: Re: sape bole bg info pasl modified single cam.. 14/3/2008, 10:53 pm | |
| ni klu c rizal men webber sdh ni.. |
| Subject: Re: sape bole bg info pasl modified single cam.. 15/3/2008, 7:54 am | |
| p masuk steel flywheel.. p balancing cranksap ka hehehe.... |
Lemon_ae92 SENIOR
Age : 36 location : Keningau Tag ID: : SFC 02137 Points : 12024 Reputation : 0 Number of posts : 711
| Subject: Re: sape bole bg info pasl modified single cam.. 11/4/2008, 3:19 am | |
| cam ni lah taiko ko trY resipi sa .... buang kaburetor ...masuk injection .. janji bukan injection mati punya ... wiring 4age... komputernya skali la ..... ada mmbr try ...lau 4a cikai2 ...blakang loo... hehehe (sekadar cadangan ) sa pun nda tau tp bleh try bha ... |
faizuli91 FRESHIE
| Subject: Re: sape bole bg info pasl modified single cam.. 4/6/2008, 1:12 pm | |
RBN76 SUPERIOR
Age : 46 location : ANYWHERE AND ANYTIME Points : 11755 Reputation : 0 Number of posts : 2142
| Subject: Re: sape bole bg info pasl modified single cam.. 4/6/2008, 1:21 pm | |
MIVEC ROCK... Ya, mivec jugala yg power nah,Blugu juga lah master of the universe kalu cerita main head dan block ni...berguru sama dia saya plug and play saja hehehe |
Age : 46 location : SU, SA, SB Points : 12008 Reputation : -1 Number of posts : 6286
| Subject: Re: sape bole bg info pasl modified single cam.. 5/6/2008, 5:39 pm | |
| Respect bro blugu..too much info that can make people doin head shot..MANTAP!!?!! Harap suma penerangan dapat membantu sedikit sebanyak kepada bro faizuli91 .. MANTAP!!?!! |
| Subject: Re: sape bole bg info pasl modified single cam.. | |
