HIGH END CAR AUDIO SYSTEMS -just info- Facebo10
Go to page : 1, 2, 3  Next
cla'e
SENIOR
SENIOR
cla'e
Number of posts : 796
HIGH END CAR AUDIO SYSTEMS -just info- Empty
PostSubject: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime8/5/2008, 3:07 pm
High End Car Audio Systems
This issue is going to cover the high end of car audio and show you what it takes to get the best sound for your own car. We'll briefly go over each piece and show you what to look for when building the best car audio system possible. This information ties in well with last issue's article on competition vehicles.
HEAD UNIT
This is where it all begins. You'll want to get a upper end CD player and possibly one of the new DVD-Audio players that are slowly becoming available. Look for a high signal to noise ratio of 110+ dBa and a dynamic head room of 100+ dB. The pre-amp voltage should be four volts or higher to help overcome any noise along the path from the head unit to the amps and processors. Some units will have balanced outputs but that's rare and often only work with amplifiers from that same brand. Expect to pay $400+ for this caliber of head unit.
OUTBOARD PROCESSOR
Most systems will do fine with the built in crossovers found in many amplifiers but for the best sound you'll want to look for external units. This includes equalizers, crossovers and sound processors. Stay away from dash mounted equalizers and focus on the trunk mounted units. All processors should have low distortion (<.01%), high signal to noise ratios (>100 dB) and strong preamp outputs (4+ volts). There are a handful of companies that also make digital equalizers and processors that are even better. Expect to pay $150-800 for a top notch processor depending on features and design (analog vs. digital).
AMPLIFIER
One car audio veteran has a standing $10,000 bet that under the exact same conditions (distortion, noise, and a few others) that a person will not be able to tell the difference between any two amplifiers. Of course under real world conditions there are some amps that sound worse than others, usually due to the build quality of the amplifier. That's why you want to have a reliable brand of amplifier in your vehicle for the best sound and for longevity. For high end amplifiers expect to pay $1-2 per watt of power at MSRP. The smaller the amp, the close you'll be to $2 and the larger the amp, the closer you'll be to $1.
SPEAKER
The most important part of any car stereo system, in terms of sound quality, is the speakers. The best electronics hooked to poor speakers will sound terrible. But the best speakers hooked to standard electronics will sound great. If you're on any kind of a budget make sure you don't skimp on your speakers. At least your front speakers should be top notch. Usually a component set in the $400+ range will be superb. Rear speakers don't need to be as pricey and some choose not to use rear speakers at all. Often a quality coaxial from the same brand will match well with the front mounted component set.
SUBWOOFERS
Because our ears are much less sensitive to the bass range a top notch subwoofer may not be necessary. This is something that you will want to determine for yourself. I don't recommend poor quality subwoofers but buying the top of the line isn't always the way to go. You can find many world class subwoofers in the range of $300+. Box design has as much to do with the sound quality of the subwoofer as anything. Make sure your installer is building the right box for the woofer you choose. It's hard to go wrong with a sealed enclosure.
WIRING
Wire, distribution/fuse blocks and power capacitors don't play a big role in the sound quality but do affect the system if they are too small or the connections are poor. Use good quality wire of the correct size with sturdy connections. Speaker wire and RCA cables are the same way. Your biggest decision here will be what type of RCA cable to use. I prefer the twisted pair variety but any cable that is built well and rejects noise will be fine. Expect to pay $20+ for a good set of RCA cables.A true high end system can usually be put together for an equipment cost of $2,000. Installation costs will vary depending on how much custom work you want done. For about $500 you should be able to get a good looking installation that will last as long as you have your vehicle.
cla'e
SENIOR
SENIOR
cla'e
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime8/5/2008, 3:09 pm
info untuk kawan2 suma... guide line cikit2 supaya kita tahu apa sebenarnya yang dikatakan high end....
semutmerah
semutmerah
Number of posts : 251
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime8/5/2008, 7:28 pm
mmg mantap la info ko ni bro. len kali aku bca dr awl hingga akhir hehehe..skrg ni skim n scan jelh What a Face
4x4Drifter
SUPERIOR
SUPERIOR
4x4Drifter
Number of posts : 2547
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime8/5/2008, 11:54 pm
mantap info ko geng ... tp satu jak juling mata sya mo baca hehehehehe ... lama udah tidak baca2 yg telampau panjang .. last sya baca gini panjang time PMR hehehehehe
http://profiles.friendster.com/tulangblakangz
hustle
SUPERIOR
SUPERIOR
hustle
Number of posts : 2595
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime9/5/2008, 8:52 am
komon clae..... mmng ko gak la.... jatuh sinta sa sama ko ni..... hehehe... tp jan silap... sinta ngan infomation ko ja....
cla'e
SENIOR
SENIOR
cla'e
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime9/5/2008, 3:21 pm
wakakakkakakaka.....cinta bertambah kepada sound!!!!!!
4x4Drifter
SUPERIOR
SUPERIOR
4x4Drifter
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime9/5/2008, 9:09 pm
ui na busS jan ko btul2 jatuh SintaH ngan cla dah lah ,, hekhekhek nanti gay plak orang ingat hekhekhek
hustle
SUPERIOR
SUPERIOR
hustle
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime9/5/2008, 11:48 pm
uinaaaaa.....adakah gay...... pure pla ni tau... hehehehe
cla'e
SENIOR
SENIOR
cla'e
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime10/5/2008, 11:38 am
hehehehehehe...da kawin pulak..hahahahhahahah..kuat lagi malam2.....
hahahahha..kuat men sound kereta ba malam2...jangan pula fikir yang lain2 ..hehehehehehe
wanB1
wanB1
Number of posts : 1652
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime10/5/2008, 11:42 am
ksi melayu bah indo t bos..bru senang pham.. What a Face
cla'e
SENIOR
SENIOR
cla'e
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime10/5/2008, 11:54 am
ooooppss...sory bro...English pula dia kasi terang kan...sa explain sikit pasal tu player la.....
HEAD UNIT
-yang penting signal noise to ratio 110+dBa
-dynamic head room 100+ dB
-harga agak2 $400 (dalam RM 400 x 4 = 1600)
- kalau di setting sound, info dia Head Unit yang bagus= kita kasi 0 bass 0 treble= masi ble blast sampai full volume maximum tapi suara tidak distortion atau pecah...
wanB1
wanB1
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime10/5/2008, 12:05 pm
tq for info bro Very Happy ,apa saya rujuk ko jak nnti
cla'e
SENIOR
SENIOR
cla'e
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime10/5/2008, 12:09 pm
orait bro..kawan2 lain di sini pun boleh membantu juga ni bro wan... Very Happy Very Happy
cla'e
SENIOR
SENIOR
cla'e
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime10/5/2008, 12:18 pm
o ya bro wan.... kalau tidak silap ECLIPSE punya brand ada jual d Yu Classic Auto.. itu pun ok tu....rasa2 saya la...kualiti tinggi semua kalau yang original ni... tapi dari dulu sa rasa ALPINE la tidak pandai drop nama dia ni d persada head unit terbaik...
Nieto
Nieto
Tag ID: : SFC 01287
Number of posts : 5595
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime10/5/2008, 2:07 pm
eclipse di sarawak pun agak banyak orang main. kalau mahu liang, pakai rca RF ~ hehehe
wanB1
wanB1
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime11/5/2008, 12:45 pm
ya saya pn kira2 mau ambil brand eclipse or alpine gk ni..sedang mbuat ptimbangan dlu..klu nda pn sony la..ok ka jua klu sony?..anyway tq bro cla'e atas info yg sungguh berguna utk org yg bru belajar mcm saya ni Very Happy Very Happy
Nieto
Nieto
Tag ID: : SFC 01287
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime11/5/2008, 4:06 pm
player sony tak tahan, dia punya head kecil hati punya~
cla'e
SENIOR
SENIOR
cla'e
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime11/5/2008, 7:40 pm
na tambah info lagi ne....SONY head kecil hati..heheheheheheheh
ECLIPSE atau ALPINE atau ..............................ada cadangan lain ka kawan2??
Nieto
Nieto
Tag ID: : SFC 01287
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime11/5/2008, 8:03 pm
haha... pioneer?
street-audio
SUPERIOR
SUPERIOR
street-audio
Number of posts : 2497
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime12/5/2008, 3:02 am
ya pioneer ... kenwood DVD baru tu ok oo sound dia...!!
Nieto
Nieto
Tag ID: : SFC 01287
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime12/5/2008, 9:32 am
mungkin guandong, atau guangxi pun ok juga... wakakaka!!!
hustle
SUPERIOR
SUPERIOR
hustle
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime12/5/2008, 10:59 am
sama aku alpine la plng solid bny..... yg cd single dia puas ht sdh..... ko bny tapis abis.... blast pun jarang jump cd.... tp hrg mahal sikit la..... eclipse pun ok... lbh kurang alpine.... tp.... beware of fake items.... byk import dr china...
street-audio
SUPERIOR
SUPERIOR
street-audio
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime13/5/2008, 1:57 am
setakat ini eclipse blum ada la china punya macam model CDx-1000 baru rm550.... CD jak. kalau CDx-2000 Cd MP3 built in crossver 3 pre out lagi.. tu mahal la rm790...!!kalau CDx-3000 na tu PRO SQ... mahal oo rm1xxx..!!
hustle
SUPERIOR
SUPERIOR
hustle
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime13/5/2008, 10:15 am
men eclipse la ni.... psl kalu sony byk dr thailand... alpine plak dr china.....
cla'e
SENIOR
SENIOR
cla'e
PostSubject: Re: HIGH END CAR AUDIO SYSTEMS -just info-   HIGH END CAR AUDIO SYSTEMS -just info- Icon_minitime13/5/2008, 1:17 pm
hehehehehe...macam jadi player terbaik bulan MEI tu ECLIPSE tau...hehehehehe...tukar la juga ne.....wakakakkakakka
Page 1 of 3Go to page : 1, 2, 3  Next
SIOLOON FUN CLUB :: START YOUR ENGINE'S :: SOUND SYSTEM ( I.C.E ) :: Talk about Sound system-
