hustle SUPERIOR
Countries/State : Age : 42 location : telupid Points : 11726 Reputation : 9 Number of posts : 2595
| Subject: Re: sound system buget...!! STreet Audio.... 2/7/2008, 8:20 am | |
| kalu pre amp yb ok2 brnd caliber ada bah rm80, wiring tu dlm 150 blh sdh tu.. |
Altec90 SUPERIOR
Countries/State : Age : 33 location : Sabah, KK, Penampang Tag ID: : SFC 02424 Points : 12706 Reputation : 3 Number of posts : 1890
| Subject: Re: sound system buget...!! STreet Audio.... 2/7/2008, 12:22 pm | |
| Jadi Rm80 + 150 = RM 230? ehh boleh runding kan? dalam wiring tuh ada fuse fuse?? |
hustle SUPERIOR
| Subject: Re: sound system buget...!! STreet Audio.... 2/7/2008, 8:26 pm | |
| setahu aku fuese dr bateri & fuse blok tuk wire2 amp ja la... |
hustle SUPERIOR
| Subject: Re: sound system buget...!! STreet Audio.... 3/7/2008, 8:38 am | |
| memang la pki fuse blok.. nda kan ko mo buat wiring bg setiap amp ko.. abis duit beli wyr2 ja ko nnti... |
street-audio SUPERIOR
Countries/State : Age : 43 location : tuaran.sabah Points : 12692 Reputation : 3 Number of posts : 2497
| Subject: Re: sound system buget...!! STreet Audio.... 3/7/2008, 9:02 am | |
| tapi kalau preamp tia payag fuse pun bole bah.!! kalau pakai fuse pun bole.. !! dari ko jak..!! |
hustle SUPERIOR
| Subject: Re: sound system buget...!! STreet Audio.... 3/7/2008, 9:29 am | |
| taiko, kalu mo pki 2 bateri, mna bgs smbng fuse blok, dr bateri d enjin @ bateri yg kedua dlm keta??? |
kippo SENIOR
Age : 55 location : Labuan-KK Points : 12029 Reputation : 3 Number of posts : 762
| Subject: Re: sound system buget...!! STreet Audio.... 3/7/2008, 11:47 am | |
| di mana ko kasi jalan kabel, di sana ko simpan fuse |
hustle SUPERIOR
| Subject: Re: sound system buget...!! STreet Audio.... 3/7/2008, 11:51 am | |
| ya la... fuse kat bateri tu besa la.. tp aku mau tau tmpt simpan fuseblok yg tuk smbng amp tu... |
kippo SENIOR
| Subject: Re: sound system buget...!! STreet Audio.... 3/7/2008, 12:00 pm | |
| tujuan fuse tu bukan untuk protect amp. Tujuan fuse tu adalah untuk mengelak kebakaran kereta apa bila kabel tu kana kepit sampai insulation dia kuyak. Jadi short circuit tu akan tarik beratus-ratus amps & akan bakar apa saja eg. karpet. Last2 terbakar kereta.
so ko simpan fuse di mana ada power kabel baru jalan. Kalau dari bateri ke distribution block, ko simpan fuse pertama sedekat terminal bateri yang ko dapat. Lepas tu dari distribution block tu ke amp, ada power kabel baru kan? Kalau distribution block tu jenis ada fuse, tidak payah pasang fuse baru. Kalau teda, kana pakai fuse baru.
kalau ko pasang 2 biji bateri ke distribution block (yang ada fuse), ko pasang fuse pertama di bateri (di bonet engine) sedekat terminal bateri tu dan dari bateri kedua (yg dalam kereta) tu ko pasang lagi fuse sedekat terminal bateri nya. Di sini, dua-dua power cabel run suda di protect dengan fuse. Kalau kabel dia short circuit, fuse tu akan blow untuk elak kan kebakaran.
jadi jangan ingat fuse tu untuk jaga amp ko |
kippo SENIOR
| Subject: Re: sound system buget...!! STreet Audio.... 3/7/2008, 1:07 pm | |
| yang atu karaja fuse di badan amp tu hehe |
boy_charger88 CONTRIBUTOR
Age : 36 location : w.p.labuan Points : 11729 Reputation : 0 Number of posts : 1385
| Subject: Re: sound system buget...!! STreet Audio.... 3/7/2008, 1:25 pm | |
| oh.....jd mau pasg fuse blok lglah dbateri kedua |
hustle SUPERIOR
| Subject: Re: sound system buget...!! STreet Audio.... 3/7/2008, 2:18 pm | |
| fuse d setiap bateri mesti ada... len lg fuse blok tuk cucuk wyr2 amp ko... |
Countries/State : Age : 33 location : Kota Belud Tag ID: : SFC 02544 Points : 13054 Reputation : 13 Number of posts : 16246
| Subject: Re: sound system buget...!! STreet Audio.... 3/7/2008, 4:24 pm | |
| jd stiap bateri msti da fuse blok lh nie..jd fuse utk amp prlu lg ka? |
4x4Drifter SUPERIOR
Age : 35 location : Menggatal Kg Paling A Points : 12421 Reputation : 0 Number of posts : 2547
| Subject: Re: sound system buget...!! STreet Audio.... 3/7/2008, 8:26 pm | |
| adeh ,, so klu pasang batt tambahan kana pasang fuse dr alternator la juga tu ???? |
| Subject: Re: sound system buget...!! STreet Audio.... 3/7/2008, 9:09 pm | |
| klu dr altrnator p bateri dpn 2 x pyh bah..dr bateri dpn p blkg 2 ja pkai fuse.. |
| Subject: Re: sound system buget...!! STreet Audio.... 4/7/2008, 12:34 pm | |
| pakai bah fuse bah safty...!! kalau tidakk siapa la kereta ON-FIRE... kekekekkee..!! |
| Subject: Re: sound system buget...!! STreet Audio.... 4/7/2008, 12:59 pm | |
| keselamatan wah 2 bro.....apa2 kt buat msti ada keselamatn bro..heheh |
kippo SENIOR
| Subject: Re: sound system buget...!! STreet Audio.... 4/7/2008, 1:53 pm | |
| dari alternator ke bateri tidak payah pasang fuse sebab kalau engine off, alternator teda ada karan.
yang bahaya tu bateri. |
| Subject: Re: sound system buget...!! STreet Audio.... 4/7/2008, 2:43 pm | |
| 2lh aku heran npa bro charger ckp prlu da fuse blok jga klu dr altrnator p bateri..spttnya mmg x prlu. |
| Subject: Re: sound system buget...!! STreet Audio.... 5/7/2008, 1:30 am | |
| oh....dr alternrt......ingtkN DR Beteri |
| Subject: Re: sound system buget...!! STreet Audio.... 5/7/2008, 10:58 am | |
| klu dr bateri mmg pntg lh 2..klu x fuse,tbakar krta..hihi. |
| Subject: Re: sound system buget...!! STreet Audio.... 5/7/2008, 12:06 pm | |
| - kippo wrote:
- dari alternator ke bateri tidak payah pasang fuse sebab kalau engine off, alternator teda ada karan.
yang bahaya tu bateri. paling baguss ada la bro.. pasall dia tia charg pun.. dia masi ada kareng dirict p batry.. baguss pasang fuse,, ada apa2 dia protech sana jak..!! |
| Subject: Re: sound system buget...!! STreet Audio.... 5/7/2008, 1:16 pm | |
| btl jg ckp bro kotiak nie..hehe |
| Subject: Re: sound system buget...!! STreet Audio.... 5/7/2008, 3:11 pm | |
| oo..jd smua 2 tplg kt msng2 lh kn..hihi. |
| Subject: Re: sound system buget...!! STreet Audio.... | |
