motec12 REGULAR
Countries/State : Age : 38 location : Tawau Tag ID: : SFC 05325 Points : 11944 Reputation : 7 Number of posts : 488
| Subject: Re: changed block engine 1.3 to 1.5 9/6/2009, 9:06 pm | |
| plug n play ja..... klu pakai efi lbh baek tukar injector.... |
Danny Lawrence FRESHIE
Countries/State : Age : 34 location : Kota Kinabalu Points : 11383 Reputation : 1 Number of posts : 33
| Subject: Re: changed block engine 1.3 to 1.5 9/6/2009, 9:46 pm | |
| bro ni crank shaft mana ko beli tu?brapa harga tu?buli masuk saga lama ka itu magma 12valve?? |
Countries/State : Age : 46 location : Kota Kinabalu-Putatan Tag ID: : SFC02202 Points : 12595 Reputation : 10 Number of posts : 2945
| Subject: Re: changed block engine 1.3 to 1.5 10/6/2009, 12:11 am | |
| - napster wrote:
- emmm.... kalau 4g13p, tukar block & head kpd 4g15p... plug & play saja ka... atau ada kena modify lagi...?
tiada beza bro, beza diantara kedua-dua blok ni adalah saiz piston saja. |
Countries/State : Age : 40 location : KLIA (hometown papar) Tag ID: : SFC 03920 Points : 17616 Reputation : 116 Number of posts : 6364
| Subject: Re: changed block engine 1.3 to 1.5 10/6/2009, 10:37 am | |
| - blugu wrote:
tiada beza bro, beza diantara kedua-dua blok ni adalah saiz piston saja. tukar head 4g13p kepada 4g15p blh kasi up power ka? brp besar beza power dia naik? |
tony84 CONTRIBUTOR
Countries/State : Age : 40 location : org twu/stay d kgu/jln2 d kk Tag ID: : SFC 02317 Points : 12710 Reputation : 9 Number of posts : 1300
| Subject: Re: changed block engine 1.3 to 1.5 10/6/2009, 5:09 pm | |
| xbanyak naik tu power...at least ko tukar piston sekali lah.....alang2 pakai 1.5...pakai 1.6 kit lah....baru ada beza... |
| Subject: Re: changed block engine 1.3 to 1.5 10/6/2009, 5:21 pm | |
| 1.6..? dr wira punya tu ka...? apa yg blh masuk...? |
tony84 CONTRIBUTOR
| Subject: Re: changed block engine 1.3 to 1.5 11/6/2009, 1:19 pm | |
| ambik piston sama rod dia saja masuk enjin magma...... |
| Subject: Re: changed block engine 1.3 to 1.5 11/6/2009, 1:37 pm | |
| msg noted... (ambik nota sikit)
thx bro... plug n play saja ka tu atau ada kena modify lagi...? |
tony84 CONTRIBUTOR
| Subject: Re: changed block engine 1.3 to 1.5 12/6/2009, 10:05 am | |
| sama saja....plug n play....xpayah bore xpayah potong..... |
Red Bullet JUNIOR
Age : 43 location : Penampang Points : 12021 Reputation : 3 Number of posts : 211
| Subject: Re: changed block engine 1.3 to 1.5 12/6/2009, 10:49 am | |
| - napster wrote:
- blugu wrote:
tiada beza bro, beza diantara kedua-dua blok ni adalah saiz piston saja. tukar head 4g13p kepada 4g15p blh kasi up power ka? brp besar beza power dia naik? head 4g13 dan 4g15 sama jah bro..yg perlu di tukar cuma blok..utk sumbat sroker kit 1.6 guna lah blok 4g15 supaya lebih tahan.. |
Red Bullet JUNIOR
| Subject: Re: changed block engine 1.3 to 1.5 12/6/2009, 10:50 am | |
| - napster wrote:
- 1.6..? dr wira punya tu ka...? apa yg blh masuk...?
stroker kit waja bro..4g18..bukan wira..4g92 |
| Subject: Re: changed block engine 1.3 to 1.5 12/6/2009, 11:48 am | |
| - Red Bullet wrote:
- napster wrote:
- blugu wrote:
tiada beza bro, beza diantara kedua-dua blok ni adalah saiz piston saja. tukar head 4g13p kepada 4g15p blh kasi up power ka? brp besar beza power dia naik? head 4g13 dan 4g15 sama jah bro..yg perlu di tukar cuma blok..utk sumbat sroker kit 1.6 guna lah blok 4g15 supaya lebih tahan.. oo... waja 4g18 punya...? ok tq tq... kalau ada kemusykilan aku tanya lagi ya... (tulis nota sikit) |
bod_supersperm SUPERIOR
Countries/State : Age : 43 location : kota kinabalu sabah Tag ID: : SFC 03551 Points : 14161 Reputation : 6 Number of posts : 2276
| Subject: Re: changed block engine 1.3 to 1.5 12/6/2009, 2:37 pm | |
| kalau berat..long distance kuat la..untuk kelajakan mesti yang light punya bro..hehe..pakai flywheel steel lagi..fuh!!mantap!! RPM cepat naik, tapi top speed ada kureng sikit la..kluar dari simpang?mantap!tyco alfian..mau convert 1.3 p 1.5..alang2 juga tu..hehe..tul cakap les, tukar 4g91 ka..inak payah race..tapi kalau kana kasi panas,kana cucuk.. |
| Subject: Re: changed block engine 1.3 to 1.5 12/6/2009, 2:52 pm | |
| mcmn mau buat tu flywheel? modify ka...? atau blh pasang terus...?
apa cara yg simple2...? |
| Subject: Re: changed block engine 1.3 to 1.5 12/6/2009, 9:27 pm | |
Waja punya bro, saiz piston 4G15 75.5mm, piston waja 76mm... saiz piston Wira 81mm, bore maksima utk blok 4G13/15 tidak sampai 81mm, tapi untuk selamat pakai piston waja & stroker kitnya sekali, mod ini juga dilakukan oleh Powerzone.com untuk kebanyakan kreta projek mereka. |
| Subject: Re: changed block engine 1.3 to 1.5 17/6/2009, 10:36 am | |
| - blugu wrote:
Waja punya bro, saiz piston 4G15 75.5mm, piston waja 76mm... saiz piston Wira 81mm, bore maksima utk blok 4G13/15 tidak sampai 81mm, tapi untuk selamat pakai piston waja & stroker kitnya sekali, mod ini juga dilakukan oleh Powerzone.com untuk kebanyakan kreta projek mereka. 75.5mm... 76mm... beza sikit ja kan... brp budget utk buat upgrade blok ni bro? |
wiramaroon REGULAR
Countries/State : Age : 39 location : Selangor Tag ID: : SFC00231 Points : 12839 Reputation : 0 Number of posts : 411
| Subject: Re: changed block engine 1.3 to 1.5 25/6/2009, 10:34 pm | |
| aloo tyco² sekalian... alang² dah ade thread ni aku mo tny skali.. klu wira 1.5GLi masuk block dgn head putra boleh ka?? ade rasa perbezaan??? kawan aku bilang POWERRRR!!!! ye ke??? |
tony84 CONTRIBUTOR
| Subject: Re: changed block engine 1.3 to 1.5 26/6/2009, 10:13 am | |
| pakai block sama head putra sohc kah dohc????kira tukar enjin suda itu lol bro......1.8cc of coz power.... |
chronical star FRESHIE
Countries/State : Age : 34 location : B'4ft - kp - kk Points : 11296 Reputation : 1 Number of posts : 24
| Subject: Re: changed block engine 1.3 to 1.5 26/6/2009, 12:29 pm | |
| Subject: Re: changed block engine 1.3 to 1.5 26/6/2009, 12:44 pm | |
wiramaroon REGULAR
| Subject: Re: changed block engine 1.3 to 1.5 26/6/2009, 7:53 pm | |
| - tony84 wrote:
- pakai block sama head putra sohc kah dohc????kira tukar enjin suda itu lol bro......1.8cc of coz power....
tukar enjin?? xpaham la.. buleh xplain details sket bro?? |
tony84 CONTRIBUTOR
| Subject: Re: changed block engine 1.3 to 1.5 29/6/2009, 10:34 am | |
| - wiramaroon wrote:
tukar enjin?? xpaham la.. buleh xplain details sket bro?? kan bro cakap ada kawan bro pakai head dan block putra dlm wira dia......maksud dia kwn ko tukar enjin lah kan...coz xpakai balik enjin asal dia.... |
wiramaroon REGULAR
| Subject: Re: changed block engine 1.3 to 1.5 29/6/2009, 12:15 pm | |
| dia cakap dia guna enjin standard.. tapi tukar head,block n piston je.. bole masuk ke?? lg 1 brp kos dia?? |
| Subject: Re: changed block engine 1.3 to 1.5 29/6/2009, 8:00 pm | |
| Subject: Re: changed block engine 1.3 to 1.5 | |
