aLFFiaN ADMINISTRATOR
Countries/State : Age : 41 location : Borneo Island Website : www.sioloon.com Tag ID: : SFC00001 Points : 14740 Reputation : 101 Number of posts : 7895
| Subject: How to remove “Hacked by Godzilla 24/10/2008, 4:37 pm | |
| How to remove “Hacked by Godzilla - MS32DLL.dll.vbs” (VBS.Zodgila) worm?
- Open Task Manager ( Right click on your taskbar and click “Task Manager” )
- Click on Processes tab and select “wscript.exe” and click “End Process” button. (Remember to remove all wscript.exe)
- Go to My Computer, Click on Tools -> Folder Options, click on View tab
- Under Advance settings,
check “Show Hidden files and folders“, uncheck “Hide extensions for known file types“, uncheck “Hide protected operating system files (Recommended)” and click “OK” button
- Go to C:\WINDOWS or C:\WINNT and delete file MS32DLL.dll.vbs
- Now go to all your drive in your computer, and delete autorun.inf and MS32DLL.dll.vbs
including your USB Drive and Floppy disk. All the autorun.inf and MS32DLL.dll.vbs file is located at the root directory of your drive, ex: c:\MS32DLL.dll.vbs, d:\MS32DLL.dll.vbs …
To access your drive, Go to My Computer, right click on the drive and select “Explore” - Next we are going to clean your registry record. Click Start -> Run, type regedit
- Go to HKEY_LOCAL_MACHINE \Software \Microsoft \Windows \Current
Version \Run and delete MS32DLL (right click on it and select delete)
- Now we are going to disable CD Autorun, Go to HKEY_LOCAL_MACHINE
\SYSTEM \CurrentControlSet \Services \Cdrom look for Autorun and double click on it and enter 0 as it’s DWORD value
You can skip this steps if you do not wish to disable CD Autorun feature. But Hacked By Godzilla worm spread when CD Autorun is ON. - Go to HKEY_CURRENT_USER \Software \Microsoft \Internet Explorer \Main and delete “Window Title” which has it’s value of “Hacked by Godzilla“
- Now go back to My Computer, Click on Tools -> Folder Options, click on View tab
uncheck “Show Hidden files and folders“, check “Hide extensions for known file types“, check “Hide protected operating system files (Recommended)” and click “OK” button
- Empty your Recycle Bin.
- Restart your PC and your PC should be clean from Hacked by Godzilla now
Happy surfing! |
Countries/State : Age : 32 location : Kota Belud Tag ID: : SFC 02544 Points : 12696 Reputation : 13 Number of posts : 16246
| Subject: Re: How to remove “Hacked by Godzilla 26/10/2008, 5:38 pm | |
