MiRA_TaSHa ADMINISTRATOR
Countries/State : Age : 39 location : Kota Kinabalu Tag ID: : SFC 00002 Points : 12932 Reputation : 0 Number of posts : 2047
| Subject: MALAYSIAN HACKERS 26/4/2007, 3:43 am | |
| Sejak akhir-akhir ini, virus baru yang diketahui telah menggunakan Internet Explorer sebagai mangsanya dengan meninggalkan kesan Hacked by IIC Team dan sebagainya
korang boleh ikuti langkah berikut. TERBUKTI DAN BERJAYA
1.Double Click on My Computer icon on Desktop and select Tools --> Folder Options 2.When Folder Options click at View[b] tab - check at [b]Show Hidden files and folders - unchuck the Hide extention… and Hide protected operating system file - click OK 3.Press Ctrl+Alt+Delete. The Windows Task Manager will display. Click at Processes tab - Click menu Image Name (to sort Files) - Select wscript.exe (one by one) - Click End Process button 4.Open drive (By right click and select Explore. Must not Double Click !) Delete autorun.inf and MS32DLL.dll.vbs (or other file that have extantion .vbs (Press Shift+Delete) in all drives include Handy Drive and Floppy disk. 5.Open folder C:\WINDOWS to delete MS32DLL.dll.vbs (or other file that have extantion .vbs inside (press Shift+Delete) 6.Go to Start --> Run and enter regedit click OK. Registry Edit dialog will display. 6.Select HKEY_LOCAL_MACHINE --> Software --> Microsoft --> Windows --> Current Version --> Run to delete MS32DLL (or the file that have same name with above) (press Delete key on keyboard) 7.Select HKEY_CURRENT_USER --> Software --> Microsoft --> Internet Explorer --> Main to delete Window Title “Hacked by Godzilla” (or anything else) (press Delete key on keyboard) 8.Click Start --> Run and enter gpedit.msc click OK. Group Policy dialog will display. 9.Select User Configuration --> Administrative Templates --> System --> Double Click on file Turn Off Autoplay then Turn Off Autoplay Properties will display - Select Enabled - Select All drives - Click OK To prevent auto open when we insert CD or plug the Handy Drive that is the way virus infect. 10.Click Start --> Run and enter msconfig Click OK. The System Configuration Utility dialog will display - Click Startup tab - Uncheck MS32DLL (p/s:if it didn't have this file, leave it) - Click Apply - Click OK (or Close) When the System Configuration dialog display select Exit Without Restart 11.Double Click on icon My Computer on Desktop. Then select Tools --> Folder Options 12.On Folder Options dialoq select View tab - Check at Hide extention… and Hide protected operating system file - Click OK 13.Right Click at Recycle bin. Then select Empty Recycle Bin to make sure the virus is deleted. |
edd_sengal FRESHIE
Age : 37 location : Malaysia Points : 12674 Reputation : 0 Number of posts : 60
| Subject: Re: MALAYSIAN HACKERS 4/6/2007, 1:48 pm | |
| Leh bg penerangan lanjut tak pasal mende nih cam ape akibatnyer kat pc yg kene mende tu,n mende2 yg relate.. |
| Subject: Re: MALAYSIAN HACKERS 5/6/2007, 11:20 pm | |
| Bende nih masuk ikut mana tah melibatkan registry windows korang besides, kalu dah effect, die akan masuk www.wasiat.org korang set balik pun, still akan masuk web tuh Contoh IE yg da kene... kuang kuang kuang..... |
Taufik JUNIOR
Age : 36 location : Kunak, Sabah Points : 12609 Reputation : 3 Number of posts : 179
| Subject: Re: MALAYSIAN HACKERS 22/8/2007, 7:35 pm | |
| rasanya benda ni pena kena kat pc cuctomer aku... bukan takat wasiat.org jer..byk lagik website yg dia masuk. :roll: thanks 4 the info & tutorial. |
| Subject: Re: MALAYSIAN HACKERS 22/8/2007, 10:02 pm | |
| okies.... kalo aku_pendiam ader pengalaman baru pasal pc.. jgn ar malu2 kongsi.... |
Taufik JUNIOR
| Subject: Re: MALAYSIAN HACKERS 5/9/2007, 10:45 am | |
| Hehe... no hal mira. Ilmu utk kita semua.. lebih2 lagi ahli sioloon yg aku kasihi.. Huhu |
edd_sengal FRESHIE
| Subject: Re: MALAYSIAN HACKERS 21/9/2007, 1:53 am | |
| sebut pasal hackers....ade tak sesape tau website mana kat malaysia nih yg dah kene hack? :?: |
haibara SUPERIOR
Countries/State : Age : 39 location : Klang Website : http://maemorrie.ads4blog.net Tag ID: : SFC 00444 Points : 12549 Reputation : -1 Number of posts : 2048
| Subject: Re: MALAYSIAN HACKERS 21/9/2007, 2:13 am | |
| - edd_sengal wrote:
- sebut pasal hackers....ade tak sesape tau website mana kat malaysia nih yg dah kene hack? :?:
aku cume tau syok. org da kena hack.. haha,..alasan dia saje2 so dorang hack blk budak tak bertamadun yg hack org tuh... haha tu la psl..ilmu yg ader jgn salah guna... igt tu... |
edd_sengal FRESHIE
| Subject: Re: MALAYSIAN HACKERS 21/9/2007, 2:20 am | |
| yg meng"hack" 2 org malaysia gak ker? tah pape tah, apesal la diaorang dengki sangat ngan web org lan :evil: |
haibara SUPERIOR
| Subject: Re: MALAYSIAN HACKERS 21/9/2007, 5:16 am | |
edd_sengal FRESHIE
| Subject: Re: MALAYSIAN HACKERS 21/9/2007, 11:13 pm | |
| senang ker nak hack web/portal org ln?ape aspek2 yg patut ade untuk halang mende ni dri berlaku kat forum/web kite eh? |
aLFFiaN ADMINISTRATOR
Countries/State : Age : 41 location : Borneo Island Website : www.sioloon.com Tag ID: : SFC00001 Points : 15018 Reputation : 101 Number of posts : 7895
| Subject: Re: MALAYSIAN HACKERS 21/9/2007, 11:16 pm | |
| memang menjadi ketakutan bila web kena hack ... so minta² jangan ada yg hack website sioloon ni... hehehe... |
edd_sengal FRESHIE
| Subject: Re: MALAYSIAN HACKERS 21/9/2007, 11:22 pm | |
| yup, jgn la sesape nak hank plak...da la sioloon punyer web nih interface dia lawar.. |
eleanor SUPERIOR
Age : 47 location : sabah Points : 12225 Reputation : 0 Number of posts : 2620
| Subject: Re: MALAYSIAN HACKERS 28/1/2008, 7:46 am | |
| wa katingalan pulak aku pasal topik nieeeee.... guna jak antiyaha semua jenis malaysian hackers akan hilang foreverrrrrrrrrrrrrrrrrrrr! hehehe saja nak tambah info walau pun da ketinggalan, boleh kan tuan moderator! |
Age : 47 location : SU, SA, SB Points : 12286 Reputation : -1 Number of posts : 6286
| Subject: Re: MALAYSIAN HACKERS 28/1/2008, 9:46 pm | |
| apa antiyaha nie bushko.. |
eleanor SUPERIOR
| Subject: Re: MALAYSIAN HACKERS 29/1/2008, 8:18 am | |
| sejenis software yg membetulkan syntax dlm sistem win23...... supaya malaysian hackers tak keluar2 lagi..... sama jak fungsi nya dgn yg moderator tu nyatakan di atas... cuma tak perlu la buat banyak kerja double click jak terus selesai...... |
pakalolo9 JUNIOR
Age : 38 location : KoTa BhArU SkRg / My Kg Points : 12692 Reputation : 0 Number of posts : 199
| Subject: Re: MALAYSIAN HACKERS 13/2/2008, 6:44 pm | |
| sbenarnye virus nie xder la bahaya sngt...cuma just effect autorun jer.....i2 bg aku lah.....mslh nie ader fix utk betulkn dier....sbb mslah registry jew...bnda alah nie wlaupun x bahaya sngt, tp lama kelamaan jd menyusahkn... |
eleanor SUPERIOR
| Subject: Re: MALAYSIAN HACKERS 14/2/2008, 8:54 am | |
| sebenarnya benda2 semua nie utk tujuan business juga ada virus ada penawarnya... si penawarnya latu yang membuat virus jadi org beli la penawarnya... tapi bagi sia ada 2 mcm jak..... pertama semua nie utk tujuan R&D sejauh mana kekuatan web atau komputer seseorang bila kena serang.... tujuannya supaya dpt pertingkatkan lagi kemampuan web tersebut.... tapi ini adalah hack yang positif sekadar mengeluarkan report kelebihan dan kelemahan web tersebut... kedua... memang orang tu saja jak nak menjahanamkan dunia IT nie... jadi sia setujuh juga dgn bro pakalolo9....heheheh tuan moderator boleh sia hack ka nie web! hehehehehehe main2 jak ba bossssss |
pakalolo9 JUNIOR
| Subject: Re: MALAYSIAN HACKERS 14/2/2008, 1:16 pm | |
| heheheh..penerangan yg baik dr eleanor.... btul ckp eleanor tue.... pepehal pun kuatkn protection anda... klau xder virus, maka xder la AV... jd R&D x jln lah... jd ketinggalan.. |
pakalolo9 JUNIOR
| Subject: Re: MALAYSIAN HACKERS 15/2/2008, 12:16 pm | |
| ok sy upkan soft...soft ni utk fix kn......ne bg memudahkn korang slesaikn mslh2 mcm disable nie... korang just run prog nie n ikut instruction...simple jer...
ok nie link dier......
FiX ReGiStRy --> cLiCk cNiE uTk SeDuT <-- |
Fadzliey MODERATOR
Age : 45 location : Beaufort Points : 12500 Reputation : 0 Number of posts : 1268
| Subject: Re: MALAYSIAN HACKERS 15/2/2008, 12:55 pm | |
| sia bab² hack ni nda brapa expert la ada org buli ajar sia ka? |
Countries/State : Age : 40 location : KLIA (hometown papar) Tag ID: : SFC 03920 Points : 17522 Reputation : 116 Number of posts : 6364
| Subject: Re: MALAYSIAN HACKERS 7/2/2009, 12:43 pm | |
| Microsoft sudah kasi keluar news, jangan guna internet explorer sbb senang kena hack... guna Firefox, panda... internet explorer lambat la, kuat hang pun ada, terutama sekali yg version 7 tu... |
the BLitz CONTRIBUTOR
Countries/State : Age : 38 location : kota belud Tag ID: : SFC 04544 Points : 13014 Reputation : 11 Number of posts : 1700
| Subject: Re: MALAYSIAN HACKERS 8/2/2009, 12:33 pm | |
| paling bagus kmu guna opera v9.63 atau mozila firefox version 3.0.1 huhu...ini mcm ada safe sikit dri kena hack..huhu...tpi klu hackers tu expert..no other way lah..huh.. |
mannmizz FRESHIE
Age : 49 location : Sabah Points : 11510 Reputation : 0 Number of posts : 1
| Subject: Re: MALAYSIAN HACKERS 23/2/2009, 12:36 pm | |
| Salam....
AWAS!!!... Local Virus drpd indon telah menjalar ke malaysia sejak tahun lepas lagi....virus dikenali sebagai bulu bebek... |
| Subject: Re: MALAYSIAN HACKERS 23/2/2009, 2:44 pm | |
| - mannmizz wrote:
- Salam....
AWAS!!!... Local Virus drpd indon telah menjalar ke malaysia sejak tahun lepas lagi....virus dikenali sebagai bulu bebek... geng.. sila perkenalankan diri dulu di Ice Breaking http://www.sioloon.com/ice-breaking-f41/ Name: Age: Sex Location: Type of car: Plate number: Colour: Where do you know about this community from? : |
| Subject: Re: MALAYSIAN HACKERS | |
