Leader MODERATOR
Countries/State : Age : 42 location : Astoria, Oregon Website : http://leader-tm.blogspot.com Tag ID: : SFC 04137 Points : 12934 Reputation : 19 Number of posts : 1531
| Subject: Power Rating Amp. ???? 2/1/2009, 11:25 pm | |
| alooo... aku ni baru dalam main sound pastu aku ni kurang pendedahan, soalannya.... apa maksud power rating yang tertulis dekat power amp. ni contohnya aku ada Amp. dekat badan dia tulis 150watt x 2 jadi maksud dia 300watt la kan. jadi aku bongkar la Amp. ni. jadi aku jumpa la Power IC dia, aku ambik CODE dia dan check dekat webside, Power IC ni rating cuma 30watt per channel. Minta tolong bagi pejelasan SIFU sekalian, camana ni |
BON SIFU
Countries/State : Age : 41 location : pitas, sepanggar, k.k Tag ID: : SFC 02761 Points : 13180 Reputation : 3 Number of posts : 5017
| Subject: Re: Power Rating Amp. ???? 3/1/2009, 10:28 am | |
| 150WATTS X 2 APA? 2 CHANNEL ATAU 2 OHM |
Leader MODERATOR
| Subject: Re: Power Rating Amp. ???? 3/1/2009, 6:45 pm | |
| - BON wrote:
- 150WATTS X 2 APA? 2 CHANNEL ATAU 2 OHM
tu yang aku tak paham tu bro, mungkin per channel |
BON SIFU
| Subject: Re: Power Rating Amp. ???? 4/1/2009, 12:52 am | |
| AIKS, CUBA KO CHECK BALIK DIA PUNYA SPEC... KASI DETAIL LAGI... ADA BA TU DIA PUNYA KERTAS KALAU KO BELI BARU... KLU TIA PUN CHECK DI KOTAK DIA |
Countries/State : Age : 33 location : Kota Belud Tag ID: : SFC 02544 Points : 13066 Reputation : 13 Number of posts : 16246
| Subject: Re: Power Rating Amp. ???? 4/1/2009, 1:27 am | |
Leader MODERATOR
| Subject: Re: Power Rating Amp. ???? 4/1/2009, 1:39 am | |
| pasal aku dapat dari kawan ni bro, ada lagi 1 ni aku baru beli jenis 2 chnle, dekat body power amp tu tulis 1800watt PEAK POWER yg ni cikai punya jak, dekat kotak atau kertas teda langsung detail dia cuma spec ja detail yg dia bagi contoh - full MOSFET power supply - 4 Ohm stable stereo - selectble bass boost - Subwoofer on/off - thermal/short circuit protection macam2 lagi tapi pasal power cuma dekat badan dia jak tulis 1800watt peak power. adakah 1800watt tu dia punya operating power atau speaker yang dia boleh handle |
Leader MODERATOR
| Subject: Re: Power Rating Amp. ???? 4/1/2009, 1:41 am | |
| - under18crew wrote:
- apa jenama amp 2?
yang 150watt x 2 tu audio bose yang baru aku beli ni bluepunk model BP-802 |
| Subject: Re: Power Rating Amp. ???? 4/1/2009, 1:51 am | |
| bluepunk?bkn blaupunkt ka? |
Leader MODERATOR
| Subject: Re: Power Rating Amp. ???? 4/1/2009, 1:58 am | |
- bluepunk?bkn blaupunkt ka?
hehehe.. bluepunk di ulangi bluepunk sebut betul-betul "bluepunk", memang aku agak ingat aku salah typing, cikai jak ni bro RM200 dekat 2020 penampang, kedai tu tengah clear stock masa ni |
Leader MODERATOR
| Subject: Re: Power Rating Amp. ???? 4/1/2009, 2:34 am | |
STELLAR SEMPORNA JUNIOR
Age : 35 location : SEMPORNA Points : 11634 Reputation : 0 Number of posts : 124
| Subject: Re: Power Rating Amp. ???? 4/1/2009, 6:50 pm | |
| - Leader™ wrote:
- alooo... aku ni baru dalam main sound pastu aku ni kurang pendedahan,
soalannya.... apa maksud power rating yang tertulis dekat power amp. ni contohnya aku ada Amp. dekat badan dia tulis 150watt x 2 jadi maksud dia 300watt la kan. jadi aku bongkar la Amp. ni. jadi aku jumpa la Power IC dia, aku ambik CODE dia dan check dekat webside, Power IC ni rating cuma 30watt per channel. Minta tolong bagi pejelasan SIFU sekalian, camana ni hello bos !!! u mau twa ka apa mksud itu 150w x 2 ??? klu lu maw tau,,cni mari sy beritahu... Itu amp aa...2 channel meh...mosfet punya..lu hantam itu mid pkai ini amp lor.. 1channel dia bawa 150watts lor...tp boleh kasi turun lg lar klu lu maw.. |
| Subject: Re: Power Rating Amp. ???? 4/1/2009, 7:45 pm | |
| yg 150 watts 2 max dia pnya watts..2 makanya ada sistem ohm 2..hihi..urg kata ohm gere2. |
Leader MODERATOR
| Subject: Re: Power Rating Amp. ???? 4/1/2009, 8:36 pm | |
| jadi kalu 1800watt peak untuk amp baru beli ni 900watt untuk 1 channel la ni |
| Subject: Re: Power Rating Amp. ???? 4/1/2009, 8:38 pm | |
| lbh krg mcm 2lh..tp ble ka c rndah lg 2.. |
Leader MODERATOR
| Subject: Re: Power Rating Amp. ???? 5/1/2009, 12:00 am | |
- lbh krg mcm 2lh..tp ble ka c rndah lg 2..
tula pasal, aku pun kasi rendah sudah ni gaint volume dia, kong suda speaker aku 1, tau ja la barang murah, speaker tu tulis 1000watt, baru blast sikit trus terbakar tu coil dia. sekarang aku guna 1 subwoofer home theater phillips rating 100watt 4ohm 6inci tong dia aku dah rebuild, yang peliknya subwoofer ni kuat dari speaker aku yang terbakar tu, speaker tu 12inci 1000watt |
| Subject: Re: Power Rating Amp. ???? 5/1/2009, 12:11 am | |
| mksd aku bkn ka c rndh setting..men 2 ohm ka,4 ohm ka..mcm 2..jd x sngsara amp 2..mgkn dia tbakar sbb ko pksa 2 amp..mosfet lg amp 2 kn.. |
Leader MODERATOR
| Subject: Re: Power Rating Amp. ???? 5/1/2009, 12:22 am | |
- mksd aku bkn ka c rndh setting..men 2 ohm ka,4 ohm ka..mcm 2..jd x sngsara amp 2..mgkn dia tbakar sbb ko pksa 2 amp..mosfet lg amp 2 kn..
hooo, aku ingat speaker tu cam 4ohm la pulak, ya tu amp mosfet, speaker yang kong tu nda jugak aku sedih sangat pasal beli murah ja $78 1biji masa promosi 2020 putatan tahun lalu, masa ni kena main barang murah dulu la, kalo dah jadi amatur baru pikir yang barang harga ratus2 |
| Subject: Re: Power Rating Amp. ???? 5/1/2009, 10:29 am | |
| woofer murah pn mau rm150 jga tau.. |
farisya7490 FRESHIE
Countries/State : Age : 39 location : Tuaran Sabah Points : 11733 Reputation : 0 Number of posts : 50
| Subject: Re: Power Rating Amp. ???? 6/1/2009, 1:29 pm | |
| sori intrupt....semua amp kena produce kpd dua jenis mosfet and digital....pastu kpd mono, 2ch, 4ch, 5 ch.....pastu kepada jenis class D, AB, T atau hybrid....lepas cte pasal ni barulah cte pasal Ohm atau kadar rintangan sama ada 1 Ohm, 2 Ohm atau 4 Ohm....baru cte pasal bridge, mono atau stereo....lepastu baru cte pasal keupayaan atau kekuatan.....dia ada dua tahap 1 tahap sebenar kuasa amp...ia diukiur dgn RMS dan kedua tahap redline atau maximum power diukur dgn Peak Power XXXX Watts....wlu mcm mana pun kebanyakan amp diukur secara perbundaran titik perpeluhan...ada kalanya yg dicatat 1000Watts peak power X 2ch tapi sebenarnya kuasa maksimum ialah 899Watts peak power X 2ch....pendek kata bnayak cte lah pasal amp ni..... amp2 cikai ni diproduce kebanyakkan secara brg rakyat yg mampu dimiliki oleh ramai org...oleh itu ia tidak dicipta dgn kos RND yg besar...malah sesetengahnya tidak menepati prosedur SIRIM atau JASMA di jepun....sebab itulah brg cikai ni susah kita mau jangka apa yg akan berlaku jika kita pasang....nway......pengalaman mengajar kita tntng banyak hal...untuk mendapatkan pengalamn inilah xsalah kalau kita pakai brg murah mula2......hehehe....((sori yer kalu slh atau xfhm......)) |
Leader MODERATOR
| Subject: Re: Power Rating Amp. ???? 6/1/2009, 5:54 pm | |
| - farisya7490 wrote:
- sori intrupt....semua amp kena produce kpd dua jenis mosfet and digital....pastu kpd mono, 2ch, 4ch, 5 ch.....pastu kepada jenis class D, AB, T atau hybrid....lepas cte pasal ni barulah cte pasal Ohm atau kadar rintangan sama ada 1 Ohm, 2 Ohm atau 4 Ohm....baru cte pasal bridge, mono atau stereo....lepastu baru cte pasal keupayaan atau kekuatan.....dia ada dua tahap 1 tahap sebenar kuasa amp...ia diukiur dgn RMS dan kedua tahap redline atau maximum power diukur dgn Peak Power XXXX Watts....wlu mcm mana pun kebanyakan amp diukur secara perbundaran titik perpeluhan...ada kalanya yg dicatat 1000Watts peak power X 2ch tapi sebenarnya kuasa maksimum ialah 899Watts peak power X 2ch....pendek kata bnayak cte lah pasal amp ni..... amp2 cikai ni diproduce kebanyakkan secara brg rakyat yg mampu dimiliki oleh ramai org...oleh itu ia tidak dicipta dgn kos RND yg besar...malah sesetengahnya tidak menepati prosedur SIRIM atau JASMA di jepun....sebab itulah brg cikai ni susah kita mau jangka apa yg akan berlaku jika kita pasang....nway......pengalaman mengajar kita tntng banyak hal...untuk mendapatkan pengalamn inilah xsalah kalau kita pakai brg murah mula2......hehehe....((sori yer kalu slh atau xfhm......))
ngam jugak ko post ni bro, pasal aku pun baru dan banyak yang kena blajar lagi ni |
taktahu MODERATOR
Countries/State : Age : 43 location : Papar & Sandakan Tag ID: : 01370 Points : 15165 Reputation : 9 Number of posts : 5398
| Subject: Re: Power Rating Amp. ???? 7/1/2009, 7:48 pm | |
| wah .... banyak lagi info baru aku dapat nie taw.... leh wat rujukan nie.... |
lan74sha JUNIOR
Countries/State : Age : 44 location : sabah Tag ID: : SFC 04310 Points : 11682 Reputation : -1 Number of posts : 245
| Subject: Re: Power Rating Amp. ???? 7/1/2009, 7:56 pm | |
tula pasal, aku pun kasi rendah sudah ni gaint volume dia, kong suda speaker aku 1, tau ja la barang murah, speaker tu tulis 1000watt, baru blast sikit trus terbakar tu coil dia. sekarang aku guna 1 subwoofer home theater phillips rating 100watt 4ohm 6inci tong dia aku dah rebuild, yang peliknya subwoofer ni kuat dari speaker aku yang terbakar tu, speaker tu 12inci 1000watt Wah law gitu aku pun maw pakai subwoofer home theater ni bro..(abislah hifi bapa aku..huhu) |
Leader MODERATOR
| Subject: Re: Power Rating Amp. ???? 7/1/2009, 11:21 pm | |
| Ni la subwoofer phillips home theater tu, box tu dah rebuild, bukan yang asal -100 Watt -4 Ohm -6 inci |
taktahu MODERATOR
| Subject: Re: Power Rating Amp. ???? 12/1/2009, 1:01 am | |
Leader MODERATOR
| Subject: Re: Power Rating Amp. ???? 12/1/2009, 1:06 am | |
| ported ni. nda minat lak aku kalo sealed ni, nda tau napa nda pernah aku buat jenis sealed box. ok ka kalo sealed box??? |
| Subject: Re: Power Rating Amp. ???? | |
