| Car Audio Batteries -Just Info- | |
cla'e SENIOR
Age : 53 location : Qoonark Points : 11767 Reputation : 0 Number of posts : 796
| Subject: Car Audio Batteries -Just Info- 6/5/2008, 3:13 pm | |
| Car Audio Batteries
If extended engine off listening is desired then a second battery can be useful. Keep in mind that this will put a greater strain on your charging system as well as add several hundred dollars for a second battery, dual battery isolator, and installation charges. If you are having problems with your charging system then you might need a new or larger alternator. Have it checked out by a qualified technician. Features and terms that may be encountered with regard to wiring are: Butt Terminals: This type of terminal resembles a long barrel and is used to connect small gauge wires together. These type are crimp terminals and considered less desirable than soldering when soldering is an option. These terminals are also sometimes referred to as crimp connectors though that term can apply to many variations of crimp terminal. Deep Cycle: A battery usually reserved for marine use that can be drained and replenished many times. While popular years ago many installers have relegated this battery to system use only with a traditional car battery for main power. Farad (F): The base unit of measure for capacitor storage. One farad is very larger and is equivalent to one million microfarads (uF). Gauge: This refers to the diameter of the wire. The smaller the number, the larger the wire. Sixteen is common for speaker wire, eight is common for average size amplifiers, while four gauge and below is used for large amplifiers. For reference, four gauge wire is about the same diameter as the average male pinky finger. Gel Cell: A type of battery that uses a gel type acid. These batteries can be desirable because they may be mounted upside down without the danger a standard type battery would pose. Heat Shrink Tubing: A type of insulating plastic that resembles a drinking straw. A small portion of this tube is cut off and placed on a wire before soldering. After the connection is soldered and cooled, the tube is slid over the joint and shrunk around the wires by means of a heat gun or hot hair dryer. Microfarads (uF): The more common unit used to measure capacitor storage. One million microfarads is equivalent to one Farad. OFC: An abbreviation for oxygen free copper. This is the most desirable wire to buy and there is really no reason to buy any other kind. As the name implies it is pure copper that is free from oxygen impurities. Spade Terminals: A type of terminal used on most speakers. The type found on speakers are male spades while the ones used to connect to these terminals are female spades. These terminals are also referred to as quick disconnects though this name can apply to many different types of terminals that come apart quickly. Voltage Rating: Referring to the amount of voltage a capacitor is rated to handle. The very least a capacitor used for reinforcement should be rated at is 16 volts while 20 volts is much more desirable and available on the slightly more expensive capacitors. |
4x4Drifter SUPERIOR
Age : 35 location : Menggatal Kg Paling A Points : 12435 Reputation : 0 Number of posts : 2547
| Subject: Re: Car Audio Batteries -Just Info- 6/5/2008, 6:55 pm | |
| YuiHoooo good info gak nih ..... hehehe patutlah bat sya low jak hehehehe |
AvE JUNIOR
Age : 116 location : Penampang Lido Nosoob Points : 12127 Reputation : 0 Number of posts : 241
| Subject: Re: Car Audio Batteries -Just Info- 6/5/2008, 11:01 pm | |
| wowowwowowowowowowowowow............informative....thnk u |
hustle SUPERIOR
Countries/State : Age : 42 location : telupid Points : 11740 Reputation : 9 Number of posts : 2595
| Subject: Re: Car Audio Batteries -Just Info- 7/5/2008, 11:14 am | |
| itu dia......... org bateri buka topik... memang c clae la pakar bateri... koz time dia men snd dlu.... dia ada byk bateri... lma2 dia yg cipta bateri jenama CLAE..... hehehe.... keep up d good work bro... |
cla'e SENIOR
| Subject: Re: Car Audio Batteries -Just Info- 7/5/2008, 1:41 pm | |
| hehehehehehehe...supaya makin ramai kita men sound tidak weak batri ba bro...hahahhaahhahaahahaha |
4x4Drifter SUPERIOR
| Subject: Re: Car Audio Batteries -Just Info- 7/5/2008, 9:01 pm | |
| ya bah tetul gak tu ..... ada dianytara kita yg menceburi bidang soundsys nih tia pikir pasal barti duranK .. mcm sya gak dlu 1st time ...... tia pakai double batt tp pakai amp 2 bijik 1200w abis bah tidak boleh start keta hehehe skrng ada oki dah hehehe tp sya buang satu amp tu skrng pki 1 amp jak hehehe |
semutmerah REGULAR
Age : 42 location : kota marudu Points : 12303 Reputation : 0 Number of posts : 251
| Subject: Re: Car Audio Batteries -Just Info- 7/5/2008, 9:40 pm | |
| ngam tul ko bg info ni bro..aku tambah cket a...bateri khusus tuk sound cthnya optima dan kinetik hehehe |
4x4Drifter SUPERIOR
| Subject: Re: Car Audio Batteries -Just Info- 7/5/2008, 9:41 pm | |
| heheh itu lah aku ckp alang2 ko pakai jak generetor kan senang heheheh tidak payah mo risau pow supp lg hehehe |
semutmerah REGULAR
| Subject: Re: Car Audio Batteries -Just Info- 7/5/2008, 9:45 pm | |
| lma suda 2 terlintas d fikiran hehehe.... |
cla'e SENIOR
| Subject: Re: Car Audio Batteries -Just Info- 8/5/2008, 1:21 pm | |
| YA BRO semutmerah...OPTIMA MA KINETIK KIRA PALING SYOK PUNYA BATERI oo......tapi d kk dmana ble dapat aaa... bagi info sikit??? |
semutmerah REGULAR
| Subject: Re: Car Audio Batteries -Just Info- 8/5/2008, 7:44 pm | |
| kalo optima...nda pasti tp kalo kinetik,ble cri d kedai S.S Auto..size 60 amp RM1200 ke atas...bla la dpt pkai 2 bateri hehehe.. |
4x4Drifter SUPERIOR
| Subject: Re: Car Audio Batteries -Just Info- 8/5/2008, 11:50 pm | |
| hahaha klu harga gitu bagus sya bikin diposit kancil boleh buat prebet sapu lg hekhekhek |
cla'e SENIOR
| Subject: Re: Car Audio Batteries -Just Info- 9/5/2008, 3:25 pm | |
| huahuahua.....sa ada chek d internet tu bro..memang bgitu harga dia...macam OPTIMA ada jual d Yu Classic Auto...tapi sama juga kick harga dia sa rasa..hehehehehe....tapi ko ble rasa bateri dia tu betul2 bagus kalau dapat pakai bro!!!! |
hustle SUPERIOR
| Subject: Re: Car Audio Batteries -Just Info- 12/5/2008, 12:10 pm | |
| alalala... upgrd ja altenator ba clae.... pki yg 110 amph... pastu gulung blk coil altenator tu @ pki 2dble altenator.... mcm alvin wong kok pki... |
cla'e SENIOR
| Subject: Re: Car Audio Batteries -Just Info- 12/5/2008, 5:35 pm | |
| hehehehe..sblm ni d kunak ada om ble bikin bro...kedai depan ruma seberang jalan jak...tapi blum sempat upgrade ni alternator dia ikut pula bos dia pindah...kasiwa lagi...kakakkaakakakak |
4x4Drifter SUPERIOR
| Subject: Re: Car Audio Batteries -Just Info- 12/5/2008, 9:10 pm | |
| hahaha ... uikX boleh modipait ka tu alternator gulung coil dia balik ?? tidak plak sya tau geng ,.. baru nih ari hehehe |
hustle SUPERIOR
| Subject: Re: Car Audio Batteries -Just Info- 13/5/2008, 10:37 am | |
| blh ba.... tp bahaya tuk elektronik keta la... kuat tu arus karan dia.... silap2 blh tabakar coil & distributor keta oooo.... |
cla'e SENIOR
| Subject: Re: Car Audio Batteries -Just Info- 13/5/2008, 3:04 pm | |
| hehehehehehehehe...nanti telebih pula.....kakakakakkaka |
semutmerah REGULAR
| Subject: Re: Car Audio Batteries -Just Info- 13/5/2008, 6:38 pm | |
| susah2......................ja mau terlebih hehehe |
4x4Drifter SUPERIOR
| Subject: Re: Car Audio Batteries -Just Info- 13/5/2008, 10:19 pm | |
| hehe ertinya kana kira btl2 lah kan ?? ui seh bagus tul dpt jua info baru maseh2 heheheh |
hustle SUPERIOR
| Subject: Re: Car Audio Batteries -Just Info- 14/5/2008, 8:26 am | |
| yg pntg kalu da upgrde altenator, kc kuat lg grounding ko.... sama selale2 la blast snd buang tu karan keta..... hehehe.... kalu nda blast snd, nnt "telebih sudah" karan ko... wahhhh hehehe... |
cla'e SENIOR
| Subject: Re: Car Audio Batteries -Just Info- 15/5/2008, 12:23 pm | |
| ngam tu bro....mau blast2 juga sikit ba...nanti karan terlebih pun tidak syok ... mesti kasi recycle ba kunun....hahahahahhaha |
semutmerah REGULAR
| Subject: Re: Car Audio Batteries -Just Info- 15/5/2008, 3:50 pm | |
| kalo karan terlabi 2 ble bg ngn yg nda pandai ckup karan kn bgus hahahaha... |
hustle SUPERIOR
| Subject: Re: Car Audio Batteries -Just Info- 16/5/2008, 10:39 am | |
| nnt telebih sudah karan ko, tabar karita nnti..... nnt kana sman sesb.. |
4x4Drifter SUPERIOR
| Subject: Re: Car Audio Batteries -Just Info- 16/5/2008, 7:29 pm | |
| hahah transfer karen lah kunuk2 hekhekhek klu boleh lah hahahaha |
| Subject: Re: Car Audio Batteries -Just Info- | |
