8dic3rd FRESHIE
Countries/State : Age : 38 location : Seremban Points : 10661 Reputation : 1 Number of posts : 12
| Subject: Fuel regulator 28/4/2010, 5:06 pm | |
| Nk minx tunjuk ajar dr otai2 sume.. perlu kah sy psg apexi safc @ greedy e manage system sekirenye sy sudah ade fuel regulator? |
8dic3rd FRESHIE
| Subject: Re: Fuel regulator 28/4/2010, 5:31 pm | |
| pomen sy ckp xyah.. minx tlg otai sume |
zul@LA SUPERIOR
Countries/State : Age : 42 location : kapayan Tag ID: : 03519 Points : 12775 Reputation : 12 Number of posts : 2259
| Subject: Re: Fuel regulator 28/4/2010, 5:52 pm | |
| mau tengok spec enjin ko jga bro,klu extreme upgred rasa nya perlu,klu standard x payah la.. |
8dic3rd FRESHIE
| Subject: Re: Fuel regulator 28/4/2010, 6:03 pm | |
| sy pkai blok kancil 850, head 12v, piston l2s.. agak2 kene pkai x?? |
zul@LA SUPERIOR
| Subject: Re: Fuel regulator 28/4/2010, 6:14 pm | |
| ni kancil tobo ka NA,klu tobo EFI+spec enjin yg ko ada sebaik2nya ada la ni manegment |
8dic3rd FRESHIE
| Subject: Re: Fuel regulator 28/4/2010, 6:22 pm | |
| ya, mira turbo l2s.. cume blok je standard perodua 850.. perlu ade ek management system, walaupun sudah ade fuel regulator |
zul@LA SUPERIOR
| Subject: Re: Fuel regulator 28/4/2010, 6:28 pm | |
| untuk boost tinggi2 sebaiknya kena ada managment,untuk boost rendah rasa2nya x pakai pun x pa |
8dic3rd FRESHIE
| Subject: Re: Fuel regulator 28/4/2010, 11:03 pm | |
| sy plan mmg nk up boost, so mmg kene pkai la yek.. hmmmm i wonder which one is better, apexi safc @ greedy e manage?? |
zul@LA SUPERIOR
| Subject: Re: Fuel regulator 29/4/2010, 6:14 pm | |
| klu sya pkai ja apexi safc senang mau setting berbanding e manage |
Lockon SENIOR
Countries/State : Age : 38 location : kota kinabalu Points : 12117 Reputation : 23 Number of posts : 756
| Subject: Re: Fuel regulator 29/4/2010, 11:46 pm | |
| safc sng mo pusing2,tp mst org yg cun2..gitu jg dgn emanage,tuner bgs,larian pun kow2..emanage bgs,ada 16 point,..betulkan klu slh..safc tu smpi rpm 7200 ka sja boleh setting klu x silap la..kc upgrade komputer box pastu install safc tu macam pnh jg sy dgr..klu mo low bujet,go to apexi safc,ada bujet lbh go to emanage..hehe |
Countries/State : Age : 36 location : Kota Kinabalu Tag ID: : SFC 01287 Points : 13985 Reputation : 34 Number of posts : 5595
| Subject: Re: Fuel regulator 30/4/2010, 9:15 am | |
| alang2 bah bro, safc 2 pun mahu rm700, e-manage pun mahu rm1000. harga tune pun lebih kurang sama saja tu, kalau turbo pakai e-manage. tapi 16 point itu afc neo, bukan e-manage, e-manage cuma ada 5 point rpm saja.
e-manage boleh adjust air flow signal -/+20%, boleh adjust ignition timing, tapi yang ni kena beli cable dia. |
8dic3rd FRESHIE
| Subject: Re: Fuel regulator 1/5/2010, 5:57 am | |
| macam e manage kene beli byk cable kn.... klu safc ade x @ pnp jek n tune? |
| Subject: Re: Fuel regulator 1/5/2010, 9:26 am | |
| e-manage pun pnp tune juga, konsep dia memang sama dengan safc. e-manage tak perlu beli banyak cable, setakat main harness saja pun boleh dah. ignition harness untuk adjust ignition timing, tak beli pun boleh, tapi kena tengok juga apa yang sudah di modify. |
Lockon SENIOR
| Subject: Re: Fuel regulator 1/5/2010, 1:14 pm | |
| ignition tu sma macam kc pusing2 tu distributor kn??ada jg ckp x pyh pun boleh,tgk modify tahap mn la sda..tp emanage lg berbaloi la..setting npk suma d skrin laptop..stp rpm 500 kena set tu myk..btulkan klu slh..setting ni brg, klu cun, mmg mntp la..safc I sma II pun nek hrga sda..alang2 kc emanage trus |
FAREL SENIOR
Countries/State : Age : 36 location : kundasang,Ranau Website : www.sioloon.com Tag ID: : SFC13231 Points : 11508 Reputation : -7 Number of posts : 818
| Subject: Re: Fuel regulator 1/5/2010, 1:33 pm | |
| walcome 2 the club.......... |
| Subject: Re: Fuel regulator 1/5/2010, 1:53 pm | |
| ya memang macam naik distributor, tapi e-manage boleh adjust ikut rpm timing yang kamu mahu, cthnya rpm 3 kau mahu tinggi sikit, rpm 5 mahu rendah sikit. |
8dic3rd FRESHIE
| Subject: Re: Fuel regulator 2/5/2010, 12:16 pm | |
| dua2 pn bagus.. pening pale ni nk pilih yg mane.. hehehe |
8dic3rd FRESHIE
| Subject: Re: Fuel regulator 2/5/2010, 12:20 pm | |
| ok.. klu sy da pasang either safc @ e manage kt kete sy, da tune cantik sume, andai kate klu kete saye breakdown, kene turun enjin, setting @ tune td ade lari x n kene tune blk ke? |
| Subject: Re: Fuel regulator 2/5/2010, 12:30 pm | |
| e-manage boleh lock setting, setting dia tak lari. tak pasti kalau safc, saya rasa pun ada juga. kalau tidak lock, remove battery saja, setting pun lari. |
Lockon SENIOR
| Subject: Re: Fuel regulator 2/5/2010, 12:42 pm | |
| betul2..tp klu up piston ka, kcu camshaft ka,tkr tobo(utk kereta tobo), adjust myk regualtor tu ka,mo kena tune blk la..betulkan klu slh |
| Subject: Re: Fuel regulator 2/5/2010, 12:43 pm | |
| ya, asal kalau ada barang modify, safc/e-manage kena tune balik, sebab minyak supply yang diperlukan sudah berbeza. |
| Subject: Re: Fuel regulator | |
