Turbo Wastegate Facebo10
 Turbo Wastegate
blugu
blugu
Tag ID: : SFC02202
Number of posts : 2945
Turbo Wastegate Empty
PostSubject: Turbo Wastegate   Turbo Wastegate Icon_minitime12/9/2008, 12:12 pm
Turbochargers Explained: The Wastegate
Dec 16, 2003 | By: Matyas Varga - SRO
40mm External Wastegate
Turbo Wastegate Wastegate
Without a wastegate, the amount of boost that a turbocharger creates
varies with the pressure of the engine's exhaust. This happens because
exhaust pressure varies with relation to the engine's speed (measured
in RPM's). This implies that as an engine reaches higher RPM's,
increasing amounts of boost will be created by the turbocharger. The
problem with this is that an engine can only accomodate a given amount
of boost. Most stock engines are only meant to take about 10 PSI if not
less. In order to regulate the amount of boost that comes into the
engine, a wastegate acts as a door only allowing a given amount of
exhaust to hit the turbocharger's exhaust turbine. Once the engine
starts producing more exhaust pressure then the wastegate system will
allow, a flap is opened to redirect excess exhaust away from the
turbine blades. In turn, this is where a wastegate gets it's name. It's
a gate to carry away waste. In order to regulate when a wastegate
opens, a boost conroller can be used.
Internal Wastegate Assembly and Actuator
Turbo Wastegate Wastegate2
There are two types of wastegates. The first one is an internal
wastegate (right). An internal wastegate is a component on the turbo
unit itself. The gate is opened via an actuator which is a diaphram
type system (see left picture). Excess exhaust is then fed directly
into the exhaust system. We also have what is called an external
wastegate (left), unlike an internal wastegate, it is seperate from the
turbo unit and does not require an actuator. Excess exhaust can either
be fed into the exhaust system or it can be vented straight out and
into the atmosphere. High performance set-ups typically follow the
latter alternative. Most stock systems come with an internal wastegate
as this set-up is better suited for low boost applications. However
most aftermarket systems perform better with an seperate external
wastegate assembly making it an ideal choice for those generating boost
in the range of 20-30 PSI.
Efazhfazh
Efazhfazh
Tag ID: : SAFC 04675
Number of posts : 230
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime6/5/2009, 2:22 pm
Apa fungsi sebenar wastegate ni ?
Ingin tahu. Untuk Kcar brapa MM yg sesuai?
pioneer_syntium
pioneer_syntium
location : Semporna / Tawau / Lahad Datu / Flamingo / Putatan
Number of posts : 1106
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime6/5/2009, 3:05 pm
selagi internal tu boleh support boost tinggi x payah pakai external wastegate pon x pa... external ni selalunya yg boost 2 bar ke atas....
Danix
Danix
Tag ID: : Saa9X9XU
Number of posts : 433
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime6/5/2009, 3:33 pm
bah..jgn kasih lama. sumbat terus twin turbo. Very Happy
matnoor
matnoor
Number of posts : 390
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime6/5/2009, 7:00 pm
nice info bro blugu... Very Happy
x mampu pakai wastegate pakai down/dump pipe (wesget kampung) pun jadi lah..huhu.. malu
pioneer_syntium
pioneer_syntium
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime6/5/2009, 7:07 pm
sa hanya mampu internal saja, boost hanya 1.6 bar saja...
matnoor
matnoor
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime6/5/2009, 7:16 pm
ceh, 1.6bar?? saja lagi tu ko ckp..kekeke..jgn la rendah diri bro pioneer..utk aku yg lidud 1.6bar tu tggi sdh tu.. malu huhu...
Efazhfazh
Efazhfazh
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime6/5/2009, 10:30 pm
1.6 bar ka??? Buli2 suda tu tau
xiaomao
xiaomao
Tag ID: : 00735
Number of posts : 7994
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime7/5/2009, 12:36 pm
1.6???mati....aku pun 0.5 saja....huhu....
kelisa_hitachi
Tag ID: : TAG ID : SFC 03153
Number of posts : 315
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime14/5/2009, 11:41 pm
pakai remove ni..utk k-car sesuai 30mm-38mm...cari spring yg licak/lembut la supaya kalu yg pakai boost rendah leh lagi rasa power wastegate ni..
yg 44mm ni besa yg hi-boost ja...keta aku pun pakai yg 35mm...
DeDiCooL
DeDiCooL
Number of posts : 54
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime27/5/2009, 5:53 pm
terpulang pada citarasa pengguna.. mau lagi sedap bunyi teriak aku cadangkan ext w/gate.. muahahaha... internal gate pun ok..
yang goodnya ext w/gate ni, boost steady all da way.. asal jangan bocor la.. agree sama kelisa hitachi, kcar > 30-38mm punya saiz ok suda.. aku pakai 38mm punya, suda pakai 3 tahun, masi ok tapi mau bucur2 suda.. Sad
witchblade
witchblade
Number of posts : 51
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime2/8/2009, 11:23 pm
sy punya wastegate 38mm tp spring dlm dia macam 1 bar saja.. baru rpm 3 stgh..teriak suda wastegate..nda syok ni.. mau cari spring yg 2 bar punya ni..hehe!
boy_charger88
Number of posts : 1385
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime3/8/2009, 3:47 pm
bro fungsi westegate sama macam blowoffkah..?..
pioneer_syntium
pioneer_syntium
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime9/8/2009, 10:51 am
blow off ko lepas dia bunyi, kalau w'gate ko tekan sampai full boost baru dia bunyi, makin tinggi boost makin kuat bunyi dia, selagi x full boost dia x bunyi itu w'gate.
yoreel
Tag ID: : SFC 03590
Number of posts : 306
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime30/12/2009, 11:56 am
tompinai...diesel turbo..buli psg wastegate ka...tq
Dzen
Number of posts : 69
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime30/12/2009, 5:37 pm
klu turbo diesel enjin standed bighorn isuzu buli pkai ka????berpa mm yg terbaik....boost pun bru 0.5 klu x silap/...tlg2 tnya tuk kawan jk ni....
oky_da_alung
oky_da_alung
Tag ID: : SFC 04806
Number of posts : 1251
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime1/1/2010, 7:17 pm
buli..xda masalah..modfied 2 fuel pump tuk jek boost tggi..kompom berteriak 2 wastegate..kwnku ada modified dia pnya triton lite p turbo..wastegate msti yg ori..klu x bocor 2 klu boost tggi..
ahmad_dhani
ahmad_dhani
Tag ID: : SFC 03009
Number of posts : 341
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime3/1/2010, 10:29 am
tu dia bila otai2 da besuara....
kongsi2 lg ilmu....
naz27
naz27
Number of posts : 48
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime3/1/2010, 10:21 pm
dmax buleh kac msk ka tu brg..
wastgte JAsma tu oK ka..?
ada tjmp mrah ari tu..
tp x tau kt mna nk psg d kk ne..
org bru bha..
hehhe
ahmad_dhani
ahmad_dhani
Tag ID: : SFC 03009
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime4/1/2010, 11:59 pm
takut tidak tahan jak tu westgate.yg buatan siam pun ok....
jasma brand ni buatan mana arrr??????
oky_da_alung
oky_da_alung
Tag ID: : SFC 04806
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime5/1/2010, 12:16 am
beli ja tial ori bh..USA mari..tp pastikan yg ori..harga pasaran rm1k - rm1.2k..
naz27
naz27
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime5/1/2010, 10:43 am
jasma jpun pny buatan..
dgr2 ok bha..
tp x tau la lau ada yg nda ori..
hehhe
DonJuanDeMarco
Countries/State : Selangor
Number of posts : 269
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime5/1/2010, 11:52 am
brand malaysia "ZAP" pun ok bro..murah2 je
ako_swifter
ako_swifter
Number of posts : 121
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime6/7/2013, 10:23 am
macam mna kita mau tau wastegate tu bcor ar..takut jgk ni dgr2.
blugu
blugu
Tag ID: : SFC02202
PostSubject: Re: Turbo Wastegate   Turbo Wastegate Icon_minitime13/12/2013, 3:22 pm
turbo boost yg slama ni steady - jadi tidak steady, kena cek blow valve & waste gate kalau lain² tempat nda bocor.
Turbo Wastegate
