SMG CONTRIBUTOR
Countries/State : Age : 45 location : Miri Bay Tag ID: : SFC01791 Points : 12484 Reputation : 0 Number of posts : 1114
| Subject: Re: Pengalaman menggunakan Adjustable Fuel Regulator 3/2/2008, 12:45 pm | |
| - lentugi wrote:
- kalau pasang ni barang fuel regulator yg sedia di injin musti mo buka ka?pomen sa ckp musti mo buka tu fuel regulator standard luk bru blh pasang yg adjustable punya..
ya,perlu buka tu regulator stended dari enjin dulu.dekat tu fuel rail saja.tapi mesti mok beli tu adapter la baru dpt pasang regulator yang baru. |
zerone CONTRIBUTOR
Age : 55 location : Keningau / Kota Kinabalu Points : 12253 Reputation : 0 Number of posts : 1078
| Subject: Re: Pengalaman menggunakan Adjustable Fuel Regulator 3/2/2008, 2:09 pm | |
| sample pic of FPR from my car club fren.... |
Countries/State : Age : 45 location : Kota Kinabalu-Putatan Tag ID: : SFC02202 Points : 12581 Reputation : 10 Number of posts : 2945
| Subject: Re: Pengalaman menggunakan Adjustable Fuel Regulator 10/2/2008, 2:06 pm | |
| - SMG wrote:
ya,perlu buka tu regulator stended dari enjin dulu.dekat tu fuel rail saja.tapi mesti mok beli tu adapter la baru dpt pasang regulator yang baru. Normally adaptor tuh ada 1 set kalau beli yg baru |
SMG CONTRIBUTOR
| Subject: Re: Pengalaman menggunakan Adjustable Fuel Regulator 10/2/2008, 10:33 pm | |
| tapi mo ingat bukan semua regulator baru datang 1 set dgn adapter.. |
Rojakman FRESHIE
Age : 47 location : Sabah Points : 12255 Reputation : 0 Number of posts : 64
| Subject: Re: Pengalaman menggunakan Adjustable Fuel Regulator 10/2/2008, 11:51 pm | |
| Before fixing the fuel regulator. make sure u know ur standard pressure. Once u have fix in all, set the pressure on standard and work it out (tuning) slowly. To ensure u know wat u doing, u must have AFR meter to monitor. preferably those machine using bosch 5 wire O2 sensor. Using those autagauge, thai gauge that hook up to ur original O2 sensor is worthless! standard idle AFR is 14.7 for gasoline. WOT is 11.0. This is basis to use. |
mercizwa OBSERVER
Countries/State : Age : 42 location : AmpangHill Points : 12722 Reputation : 0 Number of posts : 228
| Subject: Re: Pengalaman menggunakan Adjustable Fuel Regulator 11/2/2008, 1:55 am | |
| aisey kalui.. arituh datang x tanya aku camner nak setting... keter aku aritu pakai aerospeed nyer fuel regulator ada meter... tapi aerospeed ada problem sket... slalu ada bocor kat bahagian atas... aku dah kene.. tapi xpa... sket jee.. ehehe.... tapi lepas pakai fuel regulator.. keter ada kuat skit minyak.. tapi power pon ada laa.. tgk atas setting |
| Subject: Re: Pengalaman menggunakan Adjustable Fuel Regulator 17/2/2008, 6:16 pm | |
| Fuel Regulator Arospeed My original fuel pressure is about 50psi, is this normal? Currently i set it to 54psi, this is because my engine fuel supply is currently lean(Tested with Rojakman AFR kit) |
Age : 47 location : SU, SA, SB Points : 12366 Reputation : -1 Number of posts : 6286
| Subject: Re: Pengalaman menggunakan Adjustable Fuel Regulator 28/6/2008, 5:35 pm | |
| plz do update if got anything to share.. cause im hunger for the precious info..huhuhuhuu Thank you.. |
ikankalui PARTNER
Countries/State : Age : 47 location : Putatan-Kota Kinabalu Website : www.dcl2u.webs.com Points : 12567 Reputation : 0 Number of posts : 1209
| Subject: Re: Pengalaman menggunakan Adjustable Fuel Regulator 14/7/2008, 2:14 pm | |
| I punya 4age blaktop I set sekarang 40psi ngam ngam I rasa ni pressure...(wit vacumm hose intake) set 50psi masa drag sama blugu..asap itam keluar kalah kalah diesel... |
bod_supersperm SUPERIOR
Countries/State : Age : 43 location : kota kinabalu sabah Tag ID: : SFC 03551 Points : 14147 Reputation : 6 Number of posts : 2276
| Subject: Re: Pengalaman menggunakan Adjustable Fuel Regulator 28/5/2009, 10:09 am | |
| bah...kamu pakai ni barang..aku yang tiada ni..pakai standart maut punya.. |
Countries/State : Age : 36 location : Kk-Keningau-Beaufort-Kuching Tag ID: : SFC02081 Points : 14354 Reputation : 10 Number of posts : 6723
| Subject: Re: Pengalaman menggunakan Adjustable Fuel Regulator 13/8/2009, 11:55 am | |
| ni brg mmg bez...pakai di 4G91 N/A pun ada beza....kalau set terlalu tinggi lemas rasa injin then power xda,kalau terlalu rendah kereta macam xda power,xmo jalan....kalau set cun2,mmg kaw2 pickup hehehehe...siapa sudah pakai ni brg,taw lah apa aku maksudkan.... |
Countries/State : Age : 44 location : |||||TAWAU||||| Tag ID: : SFC 07691 Points : 16964 Reputation : 75 Number of posts : 5575
| Subject: Re: Pengalaman menggunakan Adjustable Fuel Regulator 24/8/2009, 5:33 am | |
| - ProjectD wrote:
- ni brg mmg bez...pakai di 4G91 N/A pun ada beza....kalau set terlalu tinggi lemas rasa injin then power xda,kalau terlalu rendah kereta macam xda power,xmo jalan....kalau set cun2,mmg kaw2 pickup hehehehe...siapa sudah pakai ni brg,taw lah apa aku maksudkan....
klu ni brg msuk di 4g15p boleh ker?... setting dia amik masa yg lama kah? |
| Subject: Re: Pengalaman menggunakan Adjustable Fuel Regulator 24/8/2009, 9:52 am | |
| 4g15 boleh, tapi kalau engine standard tak perlu masuk. kalau sudah modify macam camshaft, management, turbo baru pakai ini barang.
AFR jangan terlalu rendah pressure, pipe petrol pandai pecah. |
| Subject: Re: Pengalaman menggunakan Adjustable Fuel Regulator 24/8/2009, 12:23 pm | |
setting dia amik masa yg lama kah? boleh bro,xda masalah.... |
| Subject: Re: Pengalaman menggunakan Adjustable Fuel Regulator 6/4/2011, 2:57 pm | |
| Currently AFR my setting at 38psi with 210cc from the original 192cc injectors, but nowadays the RON95 fuel are so damn giving slow respond to my engine, haiya.... susahla kalau RON97 balik² naik harga, rm50 pun nda sampai stangah tangki.... miss those old days to tarik²... |
| Subject: Re: Pengalaman menggunakan Adjustable Fuel Regulator | |
