Tips for Wireless Home Network Security Facebo10
hYNdrAkrAziE
hYNdrAkrAziE
Countries/State : Canada
Number of posts : 390
Tips for Wireless Home Network Security Empty
PostSubject: Tips for Wireless Home Network Security   Tips for Wireless Home Network Security Icon_minitime24/5/2008, 2:51 am
1. Change Default Administrator Passwords (and Usernames)
At the core of most Wi-Fi home networks is an access point or router. To set up these pieces of equipment, manufacturers provide Web pages that allow owners to enter their network address and account information. These Web tools are protected with a login screen (username and password) so that only the rightful owner can do this. However, for any given piece of equipment, the logins provided are simple and very well-known to hackers on the Internet. Change these settings immediately.
2. Turn on (Compatible) WPA / WEP Encryption
All Wi-Fi equipment supports some form of encryption. Encryption technology scrambles messages sent over wireless networks so that they cannot be easily read by humans. Several encryption technologies exist for Wi-Fi today. Naturally you will want to pick the strongest form of encryption that works with your wireless network. However, the way these technologies work, all Wi-Fi devices on your network must share the identical encryption settings. Therefore you may need to find a "lowest common demoninator" setting.
3. Change the Default SSID
Access points and routers all use a network name called the SSID. Manufacturers normally ship their products with the same SSID set. For example, the SSID for Linksys devices is normally "linksys." True, knowing the SSID does not by itself allow your neighbors to break into your network, but it is a start. More importantly, when someone finds a default SSID, they see it is a poorly configured network and are much more likely to attack it. Change the default SSID immediately when configuring wireless security on your network.
4. Disable SSID Broadcast
In Wi-Fi networking, the wireless access point or router typically broadcasts the network name (SSID) over the air at regular intervals. This feature was designed for businesses and mobile hotspots where Wi-Fi clients may roam in and out of range. In the home, this roaming feature is unnecessary, and it increases the likelihood someone will try to log in to your home network. Fortunately, most Wi-Fi access points allow the SSID broadcast feature to be disabled by the network administrator.
5. Do Not Auto-Connect to Open Wi-Fi Networks
Connecting to an open Wi-Fi network such as a free wireless hotspot or your neighbor's router exposes your computer to security risks. Although not normally enabled, most computers have a setting available allowing these connections to happen automatically without notifying you (the user). This setting should not be enabled except in temporary situations.
6. Turn Off the Network During Extended Periods of Non-Use
The ultimate in wireless security measures, shutting down your network will most certainly prevent outside hackers from breaking in! While impractical to turn off and on the devices frequently, at least consider doing so during travel or extended periods offline. Computer disk drives have been known to suffer from power cycle wear-and-tear, but this is a secondary concern for broadband modems and routers.
Fadzliey
Fadzliey
Number of posts : 1268
PostSubject: Re: Tips for Wireless Home Network Security   Tips for Wireless Home Network Security Icon_minitime3/6/2008, 2:44 pm
gud info la geng .. Tq tq
mykazza
mykazza
Number of posts : 92
PostSubject: Re: Tips for Wireless Home Network Security   Tips for Wireless Home Network Security Icon_minitime3/6/2008, 3:09 pm
thanki you .. bagus ni .. tp kan saya malas mo membaca .. haha teda step by step punya pick ka?? kekee rambo ni la ni suda kana bagi paha mau kan buntut
