ada kah anda suka dengan post ini? | 1. Ya | | 100% | [ 5 ] | 2. Tidak | | 0% | [ 0 ] | 3. Post tak best..!!! DELETE..!!! | | 0% | [ 0 ] |
| Total Votes : 5 | | Back | |
Leader MODERATOR
Countries/State : Age : 42 location : Astoria, Oregon Website : http://leader-tm.blogspot.com Tag ID: : SFC 04137 Points : 12562 Reputation : 19 Number of posts : 1531
| Subject: DIY = CD player 10/2/2009, 11:46 pm | |
| pernah kah korang dengar CD player DIY menggunakan CD-Rom. topic ni sebenarnya telah lama dibincangkan oleh kaki2 DIY (seluruh dunia mungkin) antara laman forum yang membincangkan topic DIY cd player ni ialah www.diyaudio.com bermacam-macam versi CD player yang di DIY tapi kebanyakkannya kita ter paksa membeli KIT untuk membolehkan CD-Rom ini berfungsi sebagai CD palyer Display Kit Power supply kit Inilah hasil dia Power Supply For CD-ROM1.First wire from two polaritys of battrey (+) and (-) to where you wanna place your CDROM ( you can use wires of car too ,but first you have to find 12V and GND(Ground) between your wires using a multimeter (set on DC Voltage - Range 20V a tleast) ).2.When you got your 12V DC input , you must use two IC_Regulators : 7809 and 7805 like this :12V DC ------- ( 7809 ) ---------- ( 7805 ) -------->------ 5V DC oooooooooooooo | oooooooooooo | oooooooo GND ------------------------------...You mus see the face of IC's as you making this circuit ( there are written marks on the top )now you have your 5V DC too.3.Find an unused Power Supply of computer ( dameged one ) and cut one of its four wired jakes which matches CDROM input of power ( Yellow . Black . Black . Red )4.Plug 12V DC Directly to Yellow wire where you cut it before plug the GND to both Black wires plug the circuit output ( 5V DC ) to Red wire5.Important : screw your regulators to a heat sink because they get too hut and may get dameged.6.At last wire from socket of audio output at the back panel of your CDROM ( it has marks on above like this : R G G L ) It has four pins.plug R wire to the right speaker wire ( standard color : white ) plug your G G wires to the common wire of your speaker ( standard color : Black ) plug L wire to the left speaker wire ( standard color : Red )7.use a switch in your input line ( 12V DC ) before circuit :12V DC -------------0 \o--------------->----------> circuit ooooooooooooooooooooooooooo | ooooooooooooooooooooooooooo .----------> 12V DC inputto switch your system off when you do not use it.tah aku pun tak berapa faham apa di atas tu Ok bagi versi aku pula, display kit tu tak la penting sangat janji dapat play tu CD, jadi setelah membuat penyelidikan hampir sebulan gitu, penyelesaiannya dan kesimpulannya hanya mencari power supply untuk CD-Rom. sekarang aku hanya menggunakan 3 komponen elektronik - IC_Regulators 7805-2 Kapasitor 1000uf 16Volt (C1&C2)jangan lupa korang kena cari power supply komputer rosak untuk dapatkan penyambung/plug power supply yang korang dah buat tadi (yang ada wayar merah/hitam/hitam/kuning)5V / - / - / 12Vuntuk cd rom pulak aku guna cd-rom jenama asus 52X contoh sambungan ic regulator dan pastikan benda ni diskrukan ke badan cd-rom tu pasal benda ni panas gila ooooo... ok, pas tu sambungan untuk kapasitor pula cam ni rupa dia lebih kurang cam ni ok, cara pakainya senang jak cd-rom ni cuma ada 2 button yng sebelah kiri play/next song, kanan open tray/stop audio output ada dua, depan dan belakang. yang depan ada volume control. blakang tu teda. tapi korang kena apa preamp dan power amp kalau tak korang boleh dengar guna headfon jak ni cucuk dari lubang depan cd-rom tu kalau nak guna audio output di belakang korang kena ada audio analog connector kasi potong pas tu sambung ngan wayar yang guna utk sambung ke preamp kalau dekat rumah begini la jadinya update 5may2018 new power supply from china dvdplayer so kalau ada tak paham, soalan di buka
Leader MODERATOR
| Subject: Re: DIY = CD player 10/2/2009, 11:54 pm | |
| dulu ni la cd player di kereta aku , 1 lagi aku lupa bagi tau ic regulator tu guna yang kualiti baik punya kalo tak hancur tu barang hahaha, kalo ada sapa2 nak try segala masalah yang timbul atas tanggungjawab sendiri |
sgc666 JUNIOR
Age : 46 location : KK Tag ID: : SFC 04495 Points : 11241 Reputation : 0 Number of posts : 230
| Subject: Re: DIY = CD player 11/2/2009, 1:03 am | |
| boleh tahan la ko ni bro..!! mantapss!!! |
| Subject: Re: DIY = CD player 11/2/2009, 10:33 am | |
| mau pndai jga wat nie..nnt slh smbung sot jga 2..hihi. |
CrazyChild JUNIOR
Countries/State : Age : 36 location : Sabah-Kgu Tag ID: : SFC 03623 Points : 11470 Reputation : 0 Number of posts : 147
| Subject: Re: DIY = CD player 11/2/2009, 8:22 pm | |
| tapi dis onli can play regular disc rite? mp3 cannot.. |
Leader MODERATOR
| Subject: Re: DIY = CD player 11/2/2009, 9:11 pm | |
| - CrazyChild wrote:
- tapi dis onli can play regular disc rite? mp3 cannot..
yup only can play CD audio, if you want to play MP3disk, you hav to buy MP3 codec kit via the internet and not even MP3 you can play, all type of disk media including xXx rated, uppss.... chey... apa yang aku mencarut ni |
mR.cuSTOm CONTRIBUTOR
Countries/State : Age : 34 location : keningau Tag ID: : SFC 02852 Points : 11854 Reputation : 0 Number of posts : 1150
| Subject: Re: DIY = CD player 16/2/2009, 10:18 am | |
| utak2 king slalu bleh wat ney brg.. ahahah |
| Subject: Re: DIY = CD player 16/2/2009, 11:11 am | |
| kalau pasang dvd dengan lcd boleh ka? hehehe |
skachild SENIOR
Age : 40 location : Penampang Tag ID: : SFC 04756 Points : 11613 Reputation : 8 Number of posts : 949
| Subject: Re: DIY = CD player 16/2/2009, 11:56 am | |
| aku pernah nmpak bas mini putatan pasang gni... aku pn tanya la amcm pasang... da pn explain dgn teliti.. dari kepayan sana da cita smpai kk.... aku x paham sebiji pn apa da ckp time tu... haha...
tapi lpas aku baca post Leader... masi x paham jugak.... aku ni mmang x ada otak utk eletonik sya rasa... haha...
tapi mmang mantap la bro... buat kaji selidik sendiri... BUMP.! |
Leader MODERATOR
| Subject: Re: DIY = CD player 16/2/2009, 3:51 pm | |
| bukan jugak otak king bro biasa2 jugak ni. kalo pasal pasang dvd n lcd memang bole cuma guna dvd-rom, tapi apa yang penting kena cari tu kit untuk decode data dia, ini kit bukan lagi guna cam diatas tapi guna IDE interface sambung kepada codec kit, malah bukan jak pasang LCD biasa korang boleh guna LCD pc korang lagik, malangnya kit tu tiada jual di malaysia, dekat china banyak. dulu aku pernah nak buat project VCD player tapi codec kit aku tak sesuai dengan cd-rom aku, so kaciwa jugak dan project terbengkalai cam tu jak. cerita pasal qualiti sound dia memang mantap, pa lagi kalo guna brand asus, brand ni pun memang popular untuk convert jadi cd player, malangnya tiada shock resistan so kalo langgar buaya melingtang tengah jalan atau perigi buta kompom sangkut, hahaha. tapi design dekat atas tu cuma basic use saja, aku pun bukan pakar dalam elektronik main hantam ja tu, |
| Subject: Re: DIY = CD player 23/2/2009, 3:06 pm | |
| aku prnh buat jga ni, dulu la 4 - 5 tahun lepas... tp nda tahan lama, lepas beberapa bulan trus nda blh read tu cd... tak tau la apa masalah... tp mmg bgs, teda masalah kalau jalan tak rata, cd tak lompat2... |
Leader MODERATOR
| Subject: Re: DIY = CD player 23/2/2009, 7:28 pm | |
| itu la tu kelemahan dia kalau pasang d kereta, nda tahan lama. tapi yang ni jak masi bertahan sampai sekarang, dulu aku ada buat 3 biji, 2 sudah kong |
| Subject: Re: DIY = CD player 23/2/2009, 9:15 pm | |
| aku buat dua kali... kali kedua buat, lepas beberapa bulan rusak juga masalah y sama, tp tmpt cd msh blh eject lg cuma tak bleh read cd sdh... masuk kali ketiga teda mo buat lagi, teda stock sdh cdrom...
kira2 mcm mau try jg buat balik tp lupa sdh mau buat, nasib bro Leader ada manual cni, ada masa nnt blh la try buat lg... |
intrax ELITE
Countries/State : Age : 37 location : Kota belud-SaNdAkaN Website : http://dynastyclub.forumotion.net Tag ID: : SFC 03293 Points : 12177 Reputation : 9 Number of posts : 3111
| Subject: Re: DIY = CD player 3/3/2009, 1:25 pm | |
| wow boleh juga ni klu mo main jimat budget kan |
Leader MODERATOR
| Subject: Re: DIY = CD player 3/3/2009, 7:51 pm | |
| - intrax wrote:
- wow boleh juga ni klu mo main jimat budget kan
nak kata jimat budget tu.... ya jugak. ulu aku buat ni pun suka2 and try2 |
venusz MODERATOR
Countries/State : Age : 37 location : SanDaKaN--keninGau..Ten0m-- Tag ID: : SFC 03921 Points : 12350 Reputation : 6 Number of posts : 1886
| Subject: Re: DIY = CD player 5/4/2009, 11:54 am | |
| waaa..kreatif juga ko ni aa..mseti d umah kakak aku tu bnyak brg2 elektronik gara2 ko ni kan..hehe..btul ka ko pnah guna tu lu? so, brapa lama la boleh btahan? |
Leader MODERATOR
| Subject: Re: DIY = CD player 5/4/2009, 7:42 pm | |
| - babY bakTeria wrote:
- waaa..kreatif juga ko ni aa..mseti d umah kakak aku tu bnyak brg2 elektronik gara2 ko ni kan..hehe..btul ka ko pnah guna tu lu? so, brapa lama la boleh btahan?
ni la yang terlast yg masi tinggal, masa aku guna dekat kereta tu guna cd-rom cap ayam tu la pasal nda tahan tu, p yang ni masi berfungsi lagi ni dah masuk3-4 tahun dah |
venusz MODERATOR
| Subject: Re: DIY = CD player 5/4/2009, 8:45 pm | |
ni la yang terlast yg masi tinggal, masa aku guna dekat kereta tu guna cd-rom cap ayam tu la pasal nda tahan tu, p yang ni masi berfungsi lagi ni dah masuk3-4 tahun dah jd bro..sepanjang ko guna tu, tidak da masalah ka?t kasi tguk aku aa.hehe |
Leader MODERATOR
| Subject: Re: DIY = CD player 6/4/2009, 6:08 pm | |
ni la yang terlast yg masi tinggal, masa aku guna dekat kereta tu guna cd-rom cap ayam tu la pasal nda tahan tu, p yang ni masi berfungsi lagi ni dah masuk3-4 tahun dah jd bro..sepanjang ko guna tu, tidak da masalah ka?t kasi tguk aku aa.hehe ada plyer yg sensitip ngan lubang kecik, p sekarang aku tak guna dah, dah ganti ngan Xplode |
| Subject: Re: DIY = CD player | |
