First topic message reminder :pernah kah korang dengar CD player DIY menggunakan CD-Rom. topic ni sebenarnya telah lama dibincangkan oleh kaki2 DIY (seluruh dunia mungkin) antara laman forum yang membincangkan topic DIY cd player ni ialah www.diyaudio.com
bermacam-macam versi CD player yang di DIY tapi kebanyakkannya kita ter paksa membeli KIT untuk membolehkan CD-Rom ini berfungsi sebagai CD palyer
Display Kit
Power supply kit
Inilah hasil dia
Power Supply For CD-ROM1.First wire from two polaritys of battrey (+) and (-) to where you wanna place your CDROM
( you can use wires of car too ,but first you have to find 12V and GND(Ground) between your
wires using a multimeter (set on DC Voltage - Range 20V a tleast) ).2.When you got your 12V DC input , you must use two IC_Regulators : 7809 and 7805 like this :12V DC ------- ( 7809 ) ---------- ( 7805 ) -------->------ 5V DC
oooooooooooooo | oooooooooooo | oooooooo
GND ------------------------------...You mus see the face of IC's as you making this circuit ( there are written marks on the top )now you have your 5V DC too.3.Find an unused Power Supply of computer ( dameged one )
and cut one of its four wired jakes which matches CDROM input of power
( Yellow . Black . Black . Red )4.Plug 12V DC Directly to Yellow wire where you cut it before
plug the GND to both Black wires
plug the circuit output ( 5V DC ) to Red wire5.Important : screw your regulators to a heat sink because they
get too hut and may get dameged.6.At last wire from socket of audio output at the back panel of
your CDROM ( it has marks on above like this : R G G L )
It has four pins.plug R wire to the right speaker wire ( standard color : white )
plug your G G wires to the common wire of your speaker
( standard color : Black )
plug L wire to the left speaker wire ( standard color : Red )7.use a switch in your input line ( 12V DC ) before circuit :12V DC -------------0 \o--------------->----------> circuit
ooooooooooooooooooooooooooo |
ooooooooooooooooooooooooooo .----------> 12V DC inputto switch your system off when you do not use it.tah aku pun tak berapa faham apa di atas tu
Ok bagi versi aku pula, display kit tu tak la penting sangat janji dapat play tu CD,
jadi setelah membuat penyelidikan hampir sebulan gitu, penyelesaiannya dan kesimpulannya hanya mencari power supply untuk CD-Rom.
sekarang aku hanya menggunakan 3 komponen elektronik
IC_Regulators 7805-2 Kapasitor 1000uf 16Volt (C1&C2)jangan lupa korang kena cari power supply komputer rosak untuk dapatkan penyambung/plug power supply yang korang dah buat tadi (yang ada wayar merah/hitam/hitam/kuning)5V / - / - / 12Vuntuk cd rom pulak aku guna cd-rom jenama asus 52X
contoh sambungan ic regulator dan pastikan benda ni diskrukan ke badan cd-rom tu
pasal benda ni panas gila ooooo...
ok, pas tu sambungan untuk kapasitor pula
cam ni
rupa dia lebih kurang cam ni
ok, cara pakainya senang jak
cd-rom ni cuma ada 2 button yng sebelah kiri play/next song, kanan open tray/stop
audio output ada dua, depan dan belakang. yang depan ada volume control.
blakang tu teda.
tapi korang kena apa preamp dan power amp kalau tak korang boleh dengar guna headfon jak ni cucuk dari lubang depan cd-rom tu
kalau nak guna audio output di belakang korang kena ada audio analog connector
kasi potong pas tu sambung ngan wayar yang guna utk sambung ke preamp
kalau dekat rumah begini la jadinya
update 5may2018
new power supply from china dvdplayer
so kalau ada tak paham, soalan di buka
