check ur tire.... Facebo10
 check ur tire....
AnDee
AnDee
Tag ID: : SFC07473
Number of posts : 306
check ur tire.... Empty
PostSubject: check ur tire....   check ur tire.... Icon_minitime29/7/2009, 9:54 am
You should know how to take care of your tires and rims properly when you are an every day driver.
You should know how to take care of them
without having to need help when you need to change a tire.
Every driver that is driving should know or know how to have their tires properly inflated.
You should always have your tires inflated to where they are needed if not then you will lose gas mileage as up to 0.4 for every pound that you are
losing.
So if you are not keeping your tires inflated the right way then you are going to be losing gas and that isn't cool at all.
You will want to be getting
everything out of the gas that you have to pay for with your own hard earned money.
Even though it may be tough to keep up with everything that your
car needs done you should at least be able to keep up with tire pressure.
You should just have your front ones rotated to the back or vice versa.
Whatever drive that your car is you need to take the tires
from the drives that are not spinning and if you have all wheel drive then you should just buy new tires every year.
If you just have 2 wheel drive either front or rear you need to swap them out after 6 months of driving on them.
If you do not
want to switch them then you should just buy new tires and while you are at it just buy new rims as well.
r3dskai
r3dskai
Number of posts : 1836
PostSubject: Re: check ur tire....   check ur tire.... Icon_minitime4/9/2009, 9:46 am
tq bro..any technical ifos for us to share ka? Very Happy
thenone
thenone
Tag ID: : sfc 03675
Number of posts : 1587
PostSubject: Re: check ur tire....   check ur tire.... Icon_minitime4/9/2009, 1:50 pm
thz for the imformation bro...... it will be a good info for us.... TQ!!!!
check ur tire....
SIOLOON FUN CLUB :: ENGLISH VERSION ::   :: SIOLOON DISCUSSION :: CAR MODIFICATION :: DIY - Do it yourself-
