vimax original Facebo10
 vimax original
snt1050
snt1050
Number of posts : 11
vimax original Empty
PostSubject: vimax original   vimax original Icon_minitime8/1/2013, 8:51 pm
Vimax is a powerful natural herbal penis enlargement that increases penis length and girth, sexual desire, sexual health and helps to achieve stronger erections. Formulated from herbs from around the world that have been proven to work, you can be assured Vimax will improve your performance. Vimax uses some of the same type of herbs found in Polynesia.
Vimax penis enlargement pills are top rated for increasing both penis length and width along with improving overall sexual performance. Impotency and premature ejaculation are both cured with Vimax pills.
Vimax Pills
Vimax pills are made from all natural herbal ingredients so it’s 100% safe with absolutely no side effects at all. This is one of the best reasons why it is the right choice. There are many other copy cat products out there but none of them match the same high quality of ingredients that Vimax has. Vimax Pills is a 100% Natural and Safe Product that can safely and permanently enlarge your penis size up to 3-4 Inches in length and up to 25% in girth. By taking Vimax Pills you can be up to 3-4 inches longer and up to 25% wider.
What are Vimax Pills?
Vimax Pills are 100% natural herbal enhancement pills that will increase the width and length of your penis. You will experience an increase in sexual desire, health and be amazed at the stronger and longer erections you are having. Vimax Pills contain herbs found all over the world, some found in Polynesia where the tribal men from the Mangaian tribe have sex an average of 3 times a night, every night. Imagine your partner’s reaction if you could manage sex like the Mangaian men.
How will Vimax Pills Works for you?
Massively increase your sexual desire and stamina
Increase blood flow to your penis giving bigger and harder erections
Rock hard erections on demand every time you want one More intense longer lasting orgasms
No more premature ejaculations
The new size and appearance of your penis will arouse your loved one!
Satisfy your partner with your new larger longer lasting penis!
What are the Side Effects?
Put simply, there are NO side effects Vimax Pills are 100% safe made from 100% natural ingredients. If you class a longer, wider more impresive penis a side effect than there is one!
WEEKS 1-4
In a couple of weeks the most noticeable change will be the width of your penis and longer-lasting erections.
WEEKS 4-8
Then, after a month or two, you will see a change in the length of your penis and again you will notice a thicker and wider penis. As you stand in front of a mirror you will be amazed how, even without an erection, your penis will ‘hang’ longer and thicker.
WEEK 9+
When you have an erection you will see a very noticeable change. Not just in size, but your penis will look firmer and stronger than you ever dreamed possible.
How many Vimax Pills should I take?
Take 1 pill daily with water – if you would like to increase sexual performance, one more pill can be taken 30 mins before sexual activity.
*Please note that this product is not intended to diagnose, treat, cure, or prevent disease. As individuals differ, so will results.
call now for order 0195460533 free postage
Vimax Herbs adalah rumusan semulajadi untuk menambahkan air mani, membantu zakar tegang dengan sempurna dan juga cara untuk membesarkan zakar. Vimax herbs juga adalah ubat kuat tenaga batin lelaki yang inginkan kesihatan seksual yang hebat.
Vimax Herbs merupakan Herba Untuk Zuriat: Ia memperbaiki keseluruhan kesihatan seksual anda, membuat anda berasa lebih muda dan anda akan menikmati kepuasan seks lebih menyeronokkan. Cara membesarkan zakar, juga untuk awet muda.
Kesuburan anda juga meningkat, maka kadar untuk mendapatkan zuriat lebih cerah. Tidakkah anda ingin memberikan sesuatu yang terbaik buat pasangan anda? Inginkan zakar yang lebih sihat? Vimax Herbs mampu melancarkan aliran darah, menguatkan sperma dan meningkatkan ketegangan anda selain sebagai ubat kuat, ubat kuat tenaga batin lelaki.Permainan dan Dayungan anda juga akan bertahan lebih lama dan bertenaga.
SIAPAKAH YANG PERLU MENGGUNAKANYA UBAT KUAT TENAGA BATIN VIMAX HERBS SEBAGAI CARA MEMBESARKAN ZAKAR
Cara membesarkan zakar selain ubat kuat tenaga batin
1) Orang yang sudah mula menunjukkan tanda mati pucuk
(tidak cukup keras) ketika berjimak bersama pasangan sahnya.
2) Cepat keluar air mani dan pancutan tidak cukup laju.
3) Tiada mood ketika bersama.
4) Semua lelaki yang inginkan tubuh badan dan senjata
yang kekal sihat,dan hebat.
APAKAH FAEDAH LAIN VIMAX HERBS
1) Dapat menambah pemanjangan dan pembesaran zakar (tambah hingga 2″-3″ panjang dan tebal) * keputusan setiap individu adalah berbeza-beza.
2) Tingkatkan LIBIDO dan STAMINA – (daya seksual)
Memberi tenaga dan kecergasan ketika berjimak atau pun kerja seharian seperti bersukan dan sebagainya.
3) Penambahan air mani. (Meningkatkan kesuburan dan menguatkan sperma)
4) Melancarkan aliran darah dan meningkatkan ketegangan anda
5) Dijamin 100% (dirumus dengan herba terbaik dan bermutu)
APAKAH KESAN SAMPINGAN VIMAX HERBS
1) TIADA KESAN SAMPINGAN, .
2) Selain daripada itu,vimax adalah selamat dimakan.
CARA PENGAMBILAN VIMAX HERBS
1) Pastikan perut anda tidak kosong.
2) Ambil vimax 1 biji (sebiji) sehari dan untuk prestasi yang lebih baik boleh juga ditambah
1 biji 1 jam sebelum berjimak (jangan lebih 2 biji sehari). Minumlah air lebih atau makan buah-buahan
jika terasa pening (tip dari pelanggan yang telah menggunakannya).
3) Jika hari ke 3 merasa pening berlarutan ,sila ambil separuh,
buka kapsul dan tuangkan kedalam minuman panas seperti kopi.
Vimax Produk Yang Diperbuat dari Herba 100%
Pertama sekali, Vimax adalah makanan tambahan (atau Food Supplement) untuk para lelaki.
100% diformulasi dan diperbuat daripada herba – herba terhebat.
Vimax terdiri daripada formulasi herba – herba terbaik seperti Epunedum Sagitum (Horny Goat Weed), Ginkgo, Ginseng, Saw Palmetto, Cayenne Fruit untuk menjadikannya Pil Herba #1 untuk para lelaki. Formulasi ini dirumus untuk memberikan kesan dan faedah yang sering diidamkan oleh lelaki seperti saiz, ereksi mantap, ejakulasi dan orgasma yang hebat, libido yang sihat serta stamina yang tinggi. Dengan kata lain, Vimax mampu membawa faedah bukan sahaja untuk prestasi dan kepuasan seksual, juga untuk kesihatan lelaki pada amnya.
Dengan amalan Vimax, lelaki mampu keluar dengan lebih YAKIN dan KONFIDEN . Dan ini adalah bersifat KEKAL .
Vimax memberikan kesan dan faedah yang KEKAL .
Vimax Pills – Gain up to 3 or 4 inches in length, and up to 25% increase in girth !! Vimax Pills is 100% safe & one of the best solutions on the enlargement pills. Bigger actually IS better. Sorry, but the truth hurts guys!
Kebaikan Vimax Herbs Untuk Anda..
Formulasi kami dirumus untuk faktor yang sering lelaki idamkan. Pengguna melaporkan kesan yang memuaskan dari segi saiz, kekerasan, dan produksi sperma. Vimax Herbs juga meningkatkan nafsu seks dan stamina ketika hubungan intim. Pancutan yang lebih puas dan lama juga dapat dinikmati, selain seks yang lama hingga berjam lamanya.
Pengguna juga melaporkan peningkatan dari segi konfiden dan Vimax selalu menjadikan mereka lelaki idaman wanita yang sering mereka impikan menjadi kenyataan.
Bagi yang sentiasa mencuba daripada satu produk ke satu produk dengan tujuan untuk pembesaran, pastinya hanya tujuan itu sahaja yang sentiasa berlegar dalam pencarian produk terbaik di pasaran. Ketahui yang Vimax bukan sahaja mampu menambah saiz, namun ia juga berupaya memberikan kesan positif kepada kesihatan dan kesuburan lelaki. Di samping menguat dan mengaktifkan sperma, Vimax juga terbaik dalam memastikan perjalanan dan aliran darah adalah pada tahap yang optimal.
Tambah Saiz
Isu saiz seringkali berlegar dalam kotak fikiran kebanyakan lelaki. Ada yang mencuba teknik lama seperti menggantung pemberat dan sebagainya. Ada juga yang mengamalkan teknik Jelqing selain dari kaedah urutan dengan pelbagai jenis minyak. Senaman juga turut terlibat dalam usaha untuk mendapatkan saiz dan kepuasan yang diidamkan.
Namun begitu, dengan komitmen dan kesibukan kerja yang semakin hebat masa kini, teknik – teknik dan amalan senaman sebegini memerlukan komitmen yang tinggi. Amalan sebegini harus diamalkan secara berjadual dan menuntut sedikit ruangan masa. Dan juga ia mengambil masa untuk mendapat kesan dan faedah yang diinginkan.
Di sinilah kebaikan Vimax Herbs. Tidak perlu lagi senaman, teknik regangan dan tuaman. Tidak perlu lagi mengurut secara sembunyi. Hanya ambil 1 kapsul pada setiap hari. Vimax akan mengembangkan tisu – tisu ereksi dan menguatkan pembuluh darah – seterusnya ini akan menjadikan zakar lebih kuat, keras, dan panjang. Daripada testimoni yang diterima, ada yang sudah mencapai saiz 2 ” – 3 ” selepas mengamalkan pengambilan Vimax.
Maklumat Herba Dalam VIMAX HERBS
Epimedium Sagittatum atau Horny Goat Weed – herba ini mampu mencetuskan libido di samping meningkatkan fungsi ereksi. Digunakan untuk mengembalikan tenaga seksual di samping keletihan yang melampau. Secara amnya, ia berfungsi dengan membebaskan testosterone yang membenarkan anda memiliki kehendak seksual dan tenaga batin yang tinggi, di samping menambah sensasi seksual dan fizikal.
Cayenne Fruit – digunakan untuk mencegah penyakit serta mengawal keseimbangan pengaliran darah. Ia juga mampu mencegah angin ahmar dan serangan sakit jantung dengan meningkatkan keaktifan jantung (bukan tekanan darah). Ia juga berupaya membina semula tisu – tisu yang lemah serta membantu dalam mencegah keletihan.
Ginkgo – Herba ini mampu membantu otak, sistem saraf utama dan gejala mati pucuk. Ginkgo dikenali kerana mampu meningkatkan aliran darah ke dalam otak yang mana membantu kepada fungsi mental. Herba ini juga meningkatkan aliran darah ke dalam sistem zakar yang mana turut meningkatkan fungsi seksual.
Saw Palmetto – dikenali mampu merangsang libido yang rendah dalam lelaki, di samping meningkatkan tenaga seksual. Ia juga meningkatkan kefungsian seksual dan kehendak serta di samping mengurangkan paras kolestrol dan asid lemak di dalam darah.
Ginseng – digunakan untuk mendapatkan tenaga tambahan. Sekumpulan saintis Rusia mendapati Ginseng merangsang aktiviti fizikal dan mental dan mempunyai kesan yang positif terhadap kelenjar seks dan menambah prestasi. Digunakan untuk merawat gejala mati pucuk di mana ia mengawal keseimbangan tekanan darah di samping merawat dan membaiki sistem badan. Ia juga menyumbang kepada perkembangan tisu – tisu sarah. Satu elemen penting di dalam ginseng ialah ginsenosides yang mengubah aliran darah ke otak dan sistem zakar. Ginseng juga membantu kepada masalah ketidaksuburan dan ejakulasi pra matang
Jangkaan Pertumbuhan dan Perubahan
- Minggu 1 Hingga 4;
Kesan dapat dilihat dalam beberapa minggu, iaitu ketebalan dan ereksi yang lebih lama .Kesan yang dapat dilihat pada beberapa minggu pertama seperti ereksi yang lebih lama, lebar genggam (atau girth). Ada juga pengguna yang sebelum ini jarang – jarang ereksi pada waktu pagi, dapat merasakan kembali ereksi selepas pengambilan Vimax. Apa yang berlaku ialah formulasi Vimax berfungsi untuk merawat dan membaiki sistem saraf dan aliran darah dalam sistem zakar untuk kembali pada tahap terbaik
- Minggu 5 Hingga 8;
Selepas sebulan dua, zakar akan ketara dari segi panjang, tebal dan lebar. Berdiri di depan cermin dan amati. Anda akan kagum dengan saiz zakar anda yang baru.
- Minggu 9 ;
Bila anda ereksi, anda dapati kesan perubahan yang amat ketara sekali. Bukan hanya dari segi saiz, malahan zakar lebih padat dan kuat dari sebelumnya.
**Nota: Jangkaan pertumbuhan dan perubahan adalah bergantung pada setiap individu. Kadar pertumbuhan yang dinyatakan adalah berdasarkan kadar yang normal. Ada individu yang memperoleh kesan yang cepat serta ada yang sedikit lambat. Namun, kesan dan perubahan ADALAH POSITIF.
**Formulasi Vimax TIDAK BERTUJUAN UNTUK MERAWAT, MENYEMBUH ATAU MENGELAKKAN SEBARANG PENYAKIT. Individu yang dinyatakan memperoleh faedah dan manfaat yang hebat. Setiap individu berbeza, maka kesannya juga akan berbeza. Sila rujuk dan berbincang dengan doktor anda
Klik Di Sini Untuk Zoom Gambar
Tempah Vimax Herbs Sekarang…!!!
PENGHANTARAN ADALAH PERCUMA KE SELURUH MALAYSIA
CARA MEMBUAT TEMPAHAN
Cara Membeli
Cara untuk membeli adalah amat mudah dan senang. Segalanya boleh dilakukan secara online dan anda tidak perlu bersusah payah untuk pergi kemana-mana. Kami menerima pembayaran melalui online, paypal mahupun bayaran secara offline iaitu bank transfer.
Tempahan boleh dibuat melalui:-
Maybank2u.com / Maybank Atm Cash Deposit
CimbClicks / Cimb Atm Cash Deposit atau Paypal
1. Bankin RM260.00 ke Akaun :
Nama : Abdul Halim
Nama Bank : Maybank Berhad
Acc No :157090929702
Nama Bank : CIMB Bank
Acc No : 0702 0002 2932 09
2. Simpan segala bukti transaksi pembayaran anda.
(Simpan sehingga anda menerima barangan anda)
3. Sms / Call : 019-5460533
BERHATI-HATI DENGAN VIMAX TIRUAN DI PASARAN!
KAMI HANYA MENJUAL VIMAX YANG ASLI, ORIGINAL DARI CANADA!
Vimax Original mempunyai Batch number.
Approved by FDA
Anda boleh dapatkan maklumat lanjut dari http://www.pillsexpert.com iaitu pengeluar Vimax yang sah.
Berikut adalah maklumat yang tentang Vimax yang kami perolehi sendiri daripada mereka:
“After 2-3 weeks, it can enhance sexual performance when taken 1 hour – 30 minutes before sexual activity. And after 3-6 weeks, you can see the first result in term of increase in penis size.
One bottle is a 1 month supply.
Each month supply gives 0.5 inch in lengths and 5% increase in overall girth. The maximum results one can gain from Vimax are 3-4 inches and 25-30% increase in overall girth.
However, the results may differ among individuals.
Currently, the Vimax pills packed in Canada/USA comes in 3 different colors: brown, red-white, or green. We might also manufacture Vimax in other color in the future. The appearance of the bottles and the pills may change but the formula is the same, and the ingredient is the same.
NOTA: Kesan yang diperolehi adalah berbeza bagi mengikut individu. Kami tidak dapat menjamin yang anda akan memperolehi hasil yang sama seperti di atas. [img][/img]
finalazy84
finalazy84
Tag ID: : SFC 04901
Number of posts : 3863
PostSubject: Re: vimax original   vimax original Icon_minitime9/1/2013, 7:13 am
Sila Baca Terma Dan Syarat Sebelum Membuat Topic Baru
7. Setiap pengiklan hanya dibenarkan membuka 1 topik sahaja untuk mengiklan semua barangan mereka.
Other topics Deleted.
First Warning
https://www.facebook.com/alfian.karim
finalazy84
finalazy84
Tag ID: : SFC 04901
PostSubject: Re: vimax original   vimax original Icon_minitime17/1/2013, 7:36 am
4. Urusan jual / beli mesti sesuai untuk khalayak ramai ( dari segi jantina dan umur )
Second Warning
Sila beri kerjasama.
Sila edit post pertama (post paling atas)anda untuk membuat sebarang penambahan. Bookmark atau guna butang search untuk ke page ini untuk memudahkan anda membuat pengemaskinian.
finalazy84
finalazy84
Tag ID: : SFC 04901
PostSubject: Re: vimax original   vimax original Icon_minitime19/1/2013, 2:17 pm
Last Warning.
Other topic Deleted.
finalazy84
finalazy84
Tag ID: : SFC 04901
PostSubject: Re: vimax original   vimax original Icon_minitime22/2/2013, 1:41 pm
USER BANNED
vimax original
SIOLOON FUN CLUB :: FORUM OVERVIEW :: OTHERS-
