Info about Greddy (Trust) E-manage Facebo10
blugu
blugu
Tag ID: : SFC02202
Number of posts : 2945
Info about Greddy (Trust) E-manage Empty
PostSubject: Info about Greddy (Trust) E-manage   Info about Greddy (Trust) E-manage Icon_minitime13/2/2009, 8:23 am
E-MANAGE
Every fuel injection car runs with an ecu to
control every operation of the engine.This include controlling the duty
cyle of the injector(how long the injector is on , means amount of fuel
injected), ignition timing, camshaft profile, and few other. The ecu variable input such as rpm,manifold pressure or the mass air flow.
Basically the rpm and the amount of air available will be used by the ecu to calculate the correct amount of fuel to be injected.
The E-MANAGE BLUE is a piggy back ecu. It is not an ecu but it is design to manipulate the ecu input to vary the amount of fuel injected,ignition timing and few other functions.
The primary function of a piggyback controller is to adjust the fuel to be injected.
ECU will inject the fuel according to the Manifold Absolute Pressure (MAP) or Mass Airflow Sensor (MAF).
When e-manage is installed the output of the MAP or MAF will be
supplied to the E-manage.In the E-manage, user can set their own
airflow adjustment mapping
. So the e-manage will refer to the map the
and give the signal to the ecu. So instead of ecu getting input from
maf or map, it will receive it from the unit. So the ecu will give the
signal to the injector to inject that certain amount of fuel.
E-MANAGE BLUE FUNCTIONS
Air & Fuel Control
For larger mass air flow meter or throttle bodies, you can adjust the
input signal±20% to correspond with the correct proportional amount of
fuel delivery
Fuel delivery can be adjusted at 5 different RPM points for use with larger injector
Auto idle correction to prevent engine stalling
Fuel/boost cut controller included to allow maximum horsepower from the turbo and prevent lean run at top RPM’s Optional boost sensor & harness allows for fore more refined turbo interaction & control E-Manage can control up to 2 additional injectors that can be activated by RPM or Boost pressure(optional harness required)
Info about Greddy (Trust) E-manage Airflow-map
AIRFLOW ADJUSTMENT MAP
Ignition Timing Control
With the optional harness, you are able to control ignition timing for high boost conditions
Info about Greddy (Trust) E-manage Ignition-map
IGNITION TIMING MAP
Vtec Control
Adjustable vtec control fo RPM’s, engine speeds, hold between gear shifting Unlimited VTEC adjustment. For vehicles with a vtec engine swaps, the E-Manage can be used to activate vtec for a non vtec ecu
Monitoring Functions
Unmatched fuel control, richen or lean by 10% out of the fuel mixture when vtec engages Data logging and display through E-01 or windows laptop Map tracing of fuel, air flow,RPM’s and vtec operation
Info about Greddy (Trust) E-manage Emanage
TYPICAL INSTALLATION LOCATION
In a nutshell, you can use your e-manage to increase the amount of fuel injected to cater for modification that you had done or you can use the unit to reduce the amount of fuel injected to reduce your fuel consumption.
And the best thing is if you know how to tune the car, you can tune it
using your laptop with the use of a wideband o2 sensor.However it is
VERY RECOMMENDED to send to a reputable tuner to tune it for you on a
dyno machine
ROUGH PRICE OF E-MANAGE AND ITS ACCESSORIES
Info about Greddy (Trust) E-manage Imitation
HOW TO DIFFERENTIATE ORIGINAL AND IMMITATION
Estimate figure of emanage blue;
E-MANAGE BLUE unit RM800-1000
Ignition harness RM180
Injector harness RM200
Boost sensor RM 350
PC cable RM180
Installation of E-Manage RM80-RM150
Tuning of E-manage on dyno RM250
BEWARE OF E-MANAGE IMMITATION !
Info : http://kereta.info/trust-greddy-e-manage-blue-pigyback-specs-and-price/
blugu
blugu
Tag ID: : SFC02202
PostSubject: Re: Info about Greddy (Trust) E-manage   Info about Greddy (Trust) E-manage Icon_minitime13/2/2009, 8:40 am
Newspaper clip on E-manage from Mutiara Motors
Info about Greddy (Trust) E-manage 07112110
Nieto
Nieto
Tag ID: : SFC 01287
Number of posts : 5595
PostSubject: Re: Info about Greddy (Trust) E-manage   Info about Greddy (Trust) E-manage Icon_minitime23/3/2009, 9:52 am
huhu semua original e manage, cable mereka pun grey, led dia pun orange. tapi greddy dia ada 3d, ada serial number juga. screw driver dia hitam. hahaha??
