About Points System And Reputation System Facebo10
MiRA_TaSHa
MiRA_TaSHa
Female
Tag ID: : SFC 00002
Number of posts : 2047
About Points System And Reputation System Empty
PostSubject: About Points System And Reputation System   About Points System And Reputation System Icon_minitime18/3/2009, 10:03 pm
1 - Points System (similar to cash mod)
The points system is a system based on different criteria and allowing users to evaluate themself or even to compete.
How are points calculated?
- Points generated by the number of posts
- Points generated by the number of topics created
- Points generated by the number of friends that the user has
- Reputation points
- Points generated by the registration date of the member
- Points generated by the number of message on his profile
2 - Reputation system :Evaluation + "Thanks" Button (similar to karma mod)
The reputation system, is a sub part of the points system. It also works with points.
In each posts, if the feature is activated, small buttons to rate the post will be apparent. Each positive or negative rate can make you win or lose reputation points.
The number of points won or lost can be modified and can be customized for each categories.
The button "Thanks" allows a member who created a topic to thank the user who wrote the message that it considers most appropriate. The post then appears highlighted.
http://www.tagged.com/mira_tasha
aLFFiaN
aLFFiaN
Website : www.sioloon.com
Tag ID: : SFC00001
Number of posts : 7895
PostSubject: Re: About Points System And Reputation System   About Points System And Reputation System Icon_minitime29/4/2009, 1:11 pm
translatation in malay
1 - Sistem Markah (Points System)
sistem ini berdasarkan kepada
beberapa kreteria dan membolehkan pengguna menilai prestasi diri
mahupun untuk bertanding secara sihat dengan pengguna lain.
Bagaimana markah dikira
-markah terhasil daripada jumlah posting
-markah terhasil dari jumlah topik dipost
-markah terhasil dari jumlah list rakan/kawan user
-markah reputasi
-markah terhasil dari tarikh user register
-markah terhasil dari jumlah message user
2 - sistem reputasi (reputation) : penilaian + butang "thanks" diberi
system reputasi adalah sub kecil dari sistem point. seperti system point, ia juga berfungsi menggunakan point.
bagi
setiap posting, sekiranya sistem ini aktif, butang kecil akan keluar
dalam setiap posting(positif & negatif). kedua butang ini mempunyai
fungsi umum iaitu membolehkan kita mendapat markah reputasi(positif)
dan kehilangan markah reputasi(negatif)
jumlah markah yang diperolehi atau hilang boleh diubah dan bagi setiap ketegori ia boleh diubah atau dibuat butang
"Thanks" membolehkan user yang mencipta sesuatu topik memberi penghargaan kepada user lain yang membalas dalam topiknya dengan posting yang dirasakan sama-ada, membantu, bernas, atau berguna, bergantung kepada topik tersebut.post yang ditekan butang tersebut akan menjadi Highlight(button thanks Off)
http://www.sioloon.com
SIOLOON FUN CLUB :: SIOLOON FORUM :: HELPDESK-
