^TeRRoRiSTz^ REGULAR
Age : 48 location : Manjung, Perak Points : 12132 Reputation : 0 Number of posts : 439
| Subject: D.I.Y SHACK.. 11/11/2007, 11:35 am | |
| Getting this from my friends idea.. just wanna share with you guys n borneo.. hehehe good luck if anyone wanna try... and dont forget to share with us here.. custom eyelid using sticker material.. black sticker white reflect mark the line put black sticker as base 2nd layer 90% done.... close up result.... |
| Subject: Re: D.I.Y SHACK.. 13/11/2007, 10:17 am | |
| ( update doin' this kind if diy.....reducing weight dunno exactly what name of this part :| tools (include the biscuits) process begin finish and repair using hair dryer take 15-20 minutes each part close up all parts after the process ------------------------------------------------------------------------------------------------------------------------------------ and finally....CFed my bulky laptop skin tomorrow plan...put back all the parts |
Street_Mover* CONTRIBUTOR
Age : 40 location : Kota Kinabalu Points : 12128 Reputation : 0 Number of posts : 1237
| Subject: Re: D.I.Y SHACK.. 13/11/2007, 10:24 pm | |
| wah cun lah ko buat ni.... |
REV FRESHIE
Age : 45 location : cheras,tmn connaught Points : 12078 Reputation : 0 Number of posts : 17
| Subject: Re: D.I.Y SHACK.. 14/11/2007, 12:46 am | |
| u doing the inside A panel also carbon it?? nice how to make a sticker fully stick complete to the item fit??? |
Countries/State : Age : 35 location : Kota kinabalu,sabah Website : https://www.facebook.com/profile.php?id=100002328674361 Tag ID: : 00735 Points : 13777 Reputation : 24 Number of posts : 7994
| Subject: Re: D.I.Y SHACK.. 14/11/2007, 9:47 am | |
| Subject: Re: D.I.Y SHACK.. 14/11/2007, 10:25 am | |
| - REV wrote:
- u doing the inside A panel also carbon it??
nice how to make a sticker fully stick complete to the item fit??? Use hair dryer to stick it... and if wanna more cun.. cari CF sticker yg 3D.. |
| Subject: Re: D.I.Y SHACK.. 14/11/2007, 6:31 pm | |
| yes, guna hairdryer...tapi x bole terlalu dekat ohh...nanti rosak tu paper |
ikankalui PARTNER
Countries/State : Age : 47 location : Putatan-Kota Kinabalu Website : www.dcl2u.webs.com Points : 12209 Reputation : 0 Number of posts : 1209
| Subject: D.I.Y SHACK.. 15/11/2007, 9:21 am | |
| ini brg mo tangan yg stidi...tangan stidi tangan yg ada otot muscle kalu tangan anda inda ada ciri2 macam ini..jgn mimpi dpt buat ni brg...nampak sanang..tp susah ni... tp mo kasi tangan stidi ada tips dia....sia ady ckp...kena selalu meng****k ..konfom stidi tu tangan..... ngam kah ady? :twisted: |
| Subject: D.I.Y SHACK.. 15/11/2007, 9:48 am | |
ikankalui PARTNER
| Subject: Re: D.I.Y SHACK.. 15/11/2007, 9:58 am | |
| wahahaha...cip...ko paham juga bahasa sia....uinaaa..ingat ko nda paham |
| Subject: Re: D.I.Y SHACK.. 16/11/2007, 10:54 am | |
| - ikankalui wrote:
- wahahaha...cip...ko paham juga bahasa sia....uinaaa..ingat ko nda paham
Ba.. kan suda sia kasi tau.. 6 thn sia tinggal d sabah... hehehehe |
| Subject: Re: D.I.Y SHACK.. 16/11/2007, 11:06 am | |
| DIY HEADLAMP.. Just to share with your guys.. first take out your headlamp..got several screws there..if the the left one, got to unscrew your radiator coolant tank also..forgot how many screws..4 i think.. this is simple method i use..a hot water and a pail.. then pour the hot water onto your headlamps and open it bit by bit..i use screwdriver jer.. let it dry.. cover the red-coloured part with papers,or masking tape..pls be alerted that the shiny part in the headlamp is very easy to peal off.so avoid using much masking tap on those part..use only a little2..got it? then spray la what ur desired colour lah..then put it back together using silicone glue..well fix until now..no water comin in.. the finishing product.. not so obvious i think if it not the crystal clear glass.. good luck all.. |
nic961 SENIOR
Age : 36 location : kota kinabalu Points : 12155 Reputation : 0 Number of posts : 524
| Subject: Re: D.I.Y SHACK.. 19/11/2007, 7:56 pm | |
| wow!!save money oh if DIY!!!good job fren!! |
cosmetic REGULAR
Age : 42 location : Labuan Points : 12071 Reputation : 0 Number of posts : 301
| Subject: Re: D.I.Y SHACK.. 20/11/2007, 7:48 am | |
| edih.. sya pun mok try nih buat headlight itu mcm.. |
| Subject: Re: D.I.Y SHACK.. 20/11/2007, 9:18 am | |
| - nic961 wrote:
- wow!!save money oh if DIY!!!good job fren!!
ba try DIY la..spray headlamp ko...haha:lol: |
andypeterh ELITE
Age : 44 location : Kota Kinabalu (Kepayan & Putatan) & Ranau Points : 12179 Reputation : 1 Number of posts : 4411
| Subject: Re: D.I.Y SHACK.. 20/11/2007, 9:25 am | |
| tp susah mo kasi lekat balik itu silikon bah.. |
| Subject: Re: D.I.Y SHACK.. 20/11/2007, 10:06 am | |
| - andypeterh wrote:
- tp susah mo kasi lekat balik itu silikon bah..
ya memang susah tu...mau yg pro boleh buat...haha.. |
cosmetic REGULAR
| Subject: Re: D.I.Y SHACK.. 20/11/2007, 11:47 am | |
| Subject: Re: D.I.Y SHACK.. 20/11/2007, 11:52 am | |
| kalo nda gam bagus nnti hujan masuk air bro... |
| Subject: Re: D.I.Y SHACK.. 20/11/2007, 1:23 pm | |
| Subject: Re: D.I.Y SHACK.. 20/11/2007, 1:24 pm | |
| Subject: Re: D.I.Y SHACK.. 20/11/2007, 1:26 pm | |
| - ^TeRRoRiSTz^ wrote:
Ba.. kan suda sia kasi tau.. 6 thn sia tinggal d sabah... hehehehe baru ko tau,...apa ko rasa....??? montoku???/ bah bila ni tauke.....haus sdh sa ni....moginum saja ko sendiri2... |
| Subject: Re: D.I.Y SHACK.. 2/1/2008, 6:01 pm | |
| Last sunday.. manage to do my own.. servicing and cleaning my radiator.. Radiator spare water tank have some leaking.. change new one.. find at chop shop cost me rm20only.. Old one.. New one.. from chop shop.. RM20 only.. hehehe Open all the hose attached to radiator.. and water it with lots of water from pipe.. heheh so all the karat gone.. change new tank.. new tank fixed.. fixing back all the hose.. Add 1 tin of Coolant.. made in japan oooo... hahahaha JOB DONE!!... cost me only RM25.00 and only take me bout 1/2 hour to done this thing.. Check today at the radiator.. so far so good,.. no leaking no nothing.. hehehe New Tank : RM20.00 jer.. kat kedai potong COOLANT : RM5.00 kat kedai spare part.. Upah : F.O.C hehehehe |
Age : 46 location : SU, SA, SB Points : 12008 Reputation : -1 Number of posts : 6286
| Subject: Re: D.I.Y SHACK.. 2/1/2008, 9:29 pm | |
| thanx for the info bro.. More.. More.. More.. MANTAP!!?!! 8) |
| Subject: Re: D.I.Y SHACK.. 25/3/2008, 1:12 pm | |
| Ok this is the laters DIY form DIY king.. ( my good friend ) UPDATE (still in progress) Single CCFL Eagle Eye Item: 1. Used local satria headlamp 2. Waja foglamp (mini projector) 3. CCFL ring 4. other tools 20% progress... put back the glass..(should be better if clear glass type) CCFL ring u can get it at acc shop. mini projector- waja (1st batch) foglamp .also can buy it here >>> http://www.lelong.com.my/Auc/List/2008-03DeSale12336119_AUCTION_Super_Bright_Stylish_Dome_Fog_Lamp_with_mounting_Can_upgrade_to_HID.htm yup u can taiwan glass headlamp as long it is glass, not recommended for plastic type headlamp. Done!!! mini projector = rm100 CCFL ring (pair) = rm30 tin spray = rm6 silicone gum = rm8 gudang garam Surya = rm2.50/box each 5 hours working used headlamp = got 1 pair fm my car, 1 pc right side (contribution fm Axra) ENJOY... |
| Subject: Re: D.I.Y SHACK.. | |
