| DIY- Install Car Battery Volt Meter | |
icanfly FRESHIE
Countries/State : Age : 48 location : Bukit Mertajam Points : 10858 Reputation : 1 Number of posts : 4
| Subject: DIY- Install Car Battery Volt Meter 11/7/2009, 2:59 pm | |
| Most of us have experiences that the car cannot start when we want to go to work, go to shopping, come back from work and etc. This is very painful if we are not able to reach the destination on time and it may cause you lose the money. Useful and very accurate digital meter that always helps you to monitor your car battery condition. From the Battery Volt Meter, you will always know your battery condition when you switch on the car key and started. Inexpensive, affordable. Easy Installation: Two wires connection only, positive(Red) and negative(Black). The positive wire connects to one of the fuse that supplies voltage to Radio, Wiper and etc. While negative to ground(Car body). Go to this link for more detail, http://cscomm.weebly.com/ |
Leader MODERATOR
Countries/State : Age : 42 location : Astoria, Oregon Website : http://leader-tm.blogspot.com Tag ID: : SFC 04137 Points : 12562 Reputation : 19 Number of posts : 1531
| Subject: Re: DIY- Install Car Battery Volt Meter 11/7/2009, 11:13 pm | |
| great infomation, |
| Subject: Re: DIY- Install Car Battery Volt Meter 13/7/2009, 4:27 pm | |
| positive wire it is better to install directly to the battery positive terminal. for grounding better wire it to engine bay area. Because the reading might drop if taken from other device positive wire. |
nijam REGULAR
Countries/State : Age : 34 location : ranau-inanam-tawau-kuching Tag ID: : SFC 04683 Points : 11678 Reputation : 0 Number of posts : 481
| Subject: Re: DIY- Install Car Battery Volt Meter 13/7/2009, 5:21 pm | |
| bro klu positif wire sambung pg (+) batri,, trus negatif wire sambung pg (-) batri pn ok jua tu kan bro... |
| Subject: Re: DIY- Install Car Battery Volt Meter 13/7/2009, 5:49 pm | |
| ini pengalaman saya pasang volt meter, kalau saya ambil dari meter lain punya voltage atau device lain punya wayar positif, memang pandai turun sikit banding dengan direct.
bagus terus direct wire dari battery untuk volt meter, meter lain tidak direct pun apa, yang penting wire dari volt meter jangan ada ganguan. grounding pun boleh ambil dari battery, dari engine bay pun boleh, reading sama. |
bigcatclaw REGULAR
Age : 48 location : Tenom Tag ID: : SFC 02834 Points : 11884 Reputation : 3 Number of posts : 399
| Subject: Re: DIY- Install Car Battery Volt Meter 13/7/2009, 5:56 pm | |
| Menarik.
macam ngam juga utk dijadikan portable voltmeter. Boleh pakai utk direct check terus ke bateri atau check bateri kereta kwn2 yg belum ada voltmeter.
Thumbs up! barang bagus ni. Mana boleh dapat? |
icanfly FRESHIE
| Subject: Re: DIY- Install Car Battery Volt Meter 13/7/2009, 9:04 pm | |
| I dah check, voltage ada beza sikit di antara direct ke bateri dan ke fuse. Tapi ia hanya sikit beza sahaja,lebih kurang 0.2V. So, pasang ke fuse wiper tak ada masalah. Sekarang I tak paya risau bila bateri I akan kong atau alternator tak boleh charge.
Bro, I dapat volt meter ini melalui website ini, http://cscomm.weebly.com/ dia orang hantar melalui courier service. Satu hari sudah sampai loh. |
bigcatclaw REGULAR
| Subject: Re: DIY- Install Car Battery Volt Meter 13/7/2009, 10:04 pm | |
| Thanks 4 the link bro; sya bru ja order 1 tadi. Hopefuly can get the item bfore friday and DIYing it on this comin weekend.. |
Leader MODERATOR
| Subject: Re: DIY- Install Car Battery Volt Meter 13/7/2009, 10:59 pm | |
| cadangan aku, memang direct pergi tu batt tapi mesti melalui relay dan relay berfungsi semasa turn on kunci ikut tu radio atau sejawatan ngan nya |
henzuemi FRESHIE
Countries/State : Age : 36 location : beaufort-kk-long pasia Points : 10708 Reputation : 1 Number of posts : 14
| Subject: Re: DIY- Install Car Battery Volt Meter 2/10/2009, 1:38 pm | |
| sambung terus di batry ker nih? |
icanfly FRESHIE
| Subject: Re: DIY- Install Car Battery Volt Meter 5/11/2009, 1:39 pm | |
| x bleh sambung terus ke bateri kerana ia akan display juga apabila kunci dah off. sambung ke point point yg kaitan dgn VCC atau ON posisi di kunci tu. bleh rujuk website ni utk maklumat lanjut http://cscomm.weebly.com |
bigcatclaw REGULAR
| Subject: Re: DIY- Install Car Battery Volt Meter 5/11/2009, 8:51 pm | |
| Rasanya boleh sambung direct ke bateri. Lepas tu tambah switch on/off di dashboard. Boleh pilih wayar negetif atau positif dari voltmeter tu untuk pasang switch. Kebaikan: 1. Buli check bateri tanpa on ignition (tanpa kunci krta) 2. Full control-Check bateri hanya bila kita rasa mo check ja. Kekurangan; 1. Buli read cas bateri ja. tdk dapat read cas alternator. very humble oppinion frm me |
AIRpulse CONTRIBUTOR
Countries/State : Age : 43 location : BKI <--> KGU &l Website : http://www.hasegawa-kitagawa-sigma.jp Tag ID: : S.F.C 0548 Points : 12809 Reputation : 9 Number of posts : 1725
| Subject: Re: DIY- Install Car Battery Volt Meter 6/11/2009, 10:33 pm | |
| wow..cun!
bagus ni..if the LED is in blue lagi cun hehehe |
| Subject: Re: DIY- Install Car Battery Volt Meter 15/12/2009, 3:52 pm | |
| aisee... bagus ni... kalau bateri weak blh tngk di meter volt tu... aku pun ada pakai ni... |
| Subject: Re: DIY- Install Car Battery Volt Meter 21/12/2009, 10:19 am | |
| VS raizin terbaru pun dah ada built in Volt meter ni..
cun, warna purple lagi hehehe... |
| Subject: Re: DIY- Install Car Battery Volt Meter 21/12/2009, 12:37 pm | |
| digital ka bro? ada gambar? brp rm la tu ar sebiji...
mau dibeli tu tau... |
icanfly FRESHIE
| Subject: Re: DIY- Install Car Battery Volt Meter 21/1/2010, 11:09 am | |
| Last month, I punya volt meter tu display 11.6V bila i switch on kunci sebelum start engine, biasa ia display 12.5V on kunci sebelum start engine. I dah suspect something wrong, terus pi battery shop check, lepas check dan confirm battery i dah lemah bila bila masa akan kong. So, tukar battery terus loh. Haha, volt meter tu dah jimat masa ku. |
| Subject: Re: DIY- Install Car Battery Volt Meter | |
