90 Degree Vertical Lambo Door Kit Facebo10
services
Countries/State : Singapore
Number of posts : 7
90 Degree Vertical Lambo Door Kit Empty
PostSubject: 90 Degree Vertical Lambo Door Kit   90 Degree Vertical Lambo Door Kit Icon_minitime20/8/2009, 9:36 pm
90 Degree Vertical Lambo Door Kit Pppuds10
90 Degree Vertical Lambo Door Kit RM1600 + CAURIER
TO ORDER PLEASE EMAIL ME AT services_you@yahoo.com
you name,phone no and location
Kit Includes:
1 Drivers Side Lambo Door Hinge
1 Passengers Side Lambo Door Hinge
4 220+ lb Gas Struts
4 Multi Angle Gas Strut Mounting Bracket
8 Gas Strut Ball Studs
2 Pre Installed Movement Cogs
2 Removable Mounting Arms
1 Detailed Instruction Guide
1 Warranty Card
90 DOOR KIT advanced lambo door hinge systems use the latest technology to ensure you a long life of smooth operation. Each kit is brand NEW in the box and comes with the factories full warranty and detailed instructions to make installation a snap! Each heavy duty arm is plated with a anti rust zinc plating resulting in a nice finish and years of trouble free operation. Be aware of lower end kits that use cheap powder coating to hide metal imperfections that can result in the unit failing after a couple of months of operation. 90 DOOR KIT universal design will make this system easy to install on all vehicles on the market.
The 90 DOOR KIT Universal door hinge conversion goes 90 degrees vertical. This design allows you to utilize the factory door latch, lock and electronics because the door swings out like stock before it goes directly vertical so you get all the looks AND you get to keep all of the OEM safety and amenities. The mechanism is also fully adjustable allowing you to decide exactly how the door operates and where it will stop horizontally and vertically to give your vehicle that perfect look.
90 DOOR KIT forges every hinge with high grade steel which then they heat treat. It makes their hinge much stronger than any other kit. Providing the power to lift the door are two gas charged lifting arms per door providing up to 440lbs of counter weight force per door. All components are reliable, safe, and come with warranty.
90 DOOR KIT kits include all the parts you need for you installation including 4 heavy duty 220+ lbs gas struts to ensure door operation. In addition 90 kit advance adjustment points allow you to fine tune your installation resulting in a perfect factory fit.
Unlike Other Kits 90 Lambo Door Kit Offers:
No Wind Leaks,
No Door Movement
No Door Vibration
No Shaking Of The Doors
No Dented Fenders
No Maintenance Needed
90 Degree Vertical Lambo Door Kit Pppuds11
This is hinge is specially designed to be as universal as possible and will bolt on to most cars. Please note that in order to insure perfect alignment, you'll need to test the motion of the hinge prior to drilling your final bolt pattern.
90 Degree Vertical Lambo Door Kit Att00010
90 Degree Vertical Lambo Door Kit Magnum10
man"s
man
Tag ID: : 201
Number of posts : 291
PostSubject: Re: 90 Degree Vertical Lambo Door Kit   90 Degree Vertical Lambo Door Kit Icon_minitime20/8/2009, 11:04 pm
nice bro..any cars can use this?
services
Number of posts : 7
PostSubject: Re: 90 Degree Vertical Lambo Door Kit   90 Degree Vertical Lambo Door Kit Icon_minitime23/8/2009, 6:26 am
please msg me for more detail at 0172571862 malaysia mobile no
Nasran
Nasran
Tag ID: : SFC01678
Number of posts : 393
PostSubject: Re: 90 Degree Vertical Lambo Door Kit   90 Degree Vertical Lambo Door Kit Icon_minitime23/8/2009, 12:55 pm
Inilah pintu yg saya mau cari2 ni..
Hehhehe..
SIOLOON FUN CLUB :: START YOUR ENGINE'S :: BODY KITS-
