nomo JUNIOR
Age : 43 location : kota kinabalu Points : 11833 Reputation : 0 Number of posts : 98
| Subject: B.O.T tanpa Blowoff 19/4/2008, 1:43 pm | |
| bro..saya nak tanya kalau masuk turbo tapi kalau x pakai blowoff boleh ker? ada member ckp kalau x pakai blowoff guna ext westage untuk buat angin lebih. ada effect kat turbo ke kalu x pakai. saya cadang nak masuk turbo tapi x nak la cam org lain tarik2 sikit dah bunyi kecinggggg.cam menunjuk2 saja mantang2 turbo.kereta besar pun tak tarik2. :?: |
te37 MODERATOR
Countries/State : Age : 37 location : Kota Kinabalu - Keningau Tag ID: : SFC 02132 Points : 12190 Reputation : 0 Number of posts : 2660
| Subject: Re: B.O.T tanpa Blowoff 19/4/2008, 2:01 pm | |
| sa pernah experience jgk bgini bro..turbo tiada safe klu tiada blow off..yg bahaya itu turbo-shaft..klu tiada pakai blow off akan menyebabkan turbo-shaft putus, "bukan dalam masa yg singkat la"..klu boost tinggi confirm..JANJI..klu tiada mo kecinggggg-kecingggg...pakai la blow off lain yg bukan kecingggg..hehehe..
correct me if im wrong... |
nomo JUNIOR
| Subject: Re: B.O.T tanpa Blowoff 19/4/2008, 2:15 pm | |
| kenapa kereta 4x4 turbo tak pakai benda ni ok saja..sesiapa otai2 kings turbo sila membantu |
te37 MODERATOR
| Subject: Re: B.O.T tanpa Blowoff 19/4/2008, 4:45 pm | |
| bro, sa cari2 dapat ini tadi..mungkin ini membantu kita.. Okay, this is how diesels run: Air is drawn into the cylinders and is compressed by the pistons at compression ratios around 18:1, much higher than those spark-ignited (petrol) engines. Near the end of the compression stroke, diesel fuel is injected into the combustion chamber through an injector (or atomizer). The fuel ignites from contact with the air that, due to compression, has been heated to a temperature of about 700–900 °C (1300–1650 °F). The resulting combustion causes increased heat and expansion in the cylinder which increases pressure and moves the piston downward. The vehicle needs all the air that it’s turbo can supply. It essentially compresses air in the cylinders, so no combustion occurs until the diesel is introduced. Having a BOV will make the compressor work a lot harder to build the pressure. There is a loss in performance when the gears are shifted. After the 2nd & 3rd gear, you may find yourself losing even to a Kia Picanto. Diesel engines do not have throttle plates to control engine speed (unlike a gasoline/petrol engine which has a butterfly valve within the throttle mechanism). Engine speed is controlled by regulating the quantity of fuel injected into the cylinder during the power stroke, regardless whether by indirect injection or common rail injection. Truth is, any modification that raises the amount of fuel and air put through a diesel engine will increase its operating temperature, which will shorten its life and increase its service interval requirements. Most modern diesel engines have their fuel injection rates electronically controlled, so their torque is more or less equal, if not better, than petrol/gasoline driven cars.
te37 MODERATOR
| Subject: Re: B.O.T tanpa Blowoff 19/4/2008, 4:54 pm | |
| bayangkan jika blow off tiada dipasang..angin akan balik ke turbo dengan arah yang berlawanan..ini menyebabkan effect yg kurang baik kepada turbo-shaft..bearing pun cepat makan.. |
KewLOne ADMINISTRATOR
Countries/State : Age : 47 location : Kota Kinabalu Tag ID: : SFC00724 Points : 12245 Reputation : 3 Number of posts : 466
| Subject: Re: B.O.T tanpa Blowoff 19/4/2008, 5:08 pm | |
| nomo.. penggunaan B.O.V. ni penting jugak... untuk menjaga jangka hayat turbo tu... kalau tidak mo pakai pun ok... syaratnya tidak ble lebih dari 7psi boost... tapi kalau hari2 tarik boost sampai 7psi.. sakit jugak turbo tu.... 4WD kebanyakan tidak pakai sebab dorang boost standard tidak lebih dari 7 or 8psi.. tapi bila dorang buat mods sudah.. kasi tinggi boost.. mesti ada BOV suda tu... turbo mahal bos.... standard BOV pun baru seratus lebih jak.... renung2kan... hehehe... ini pandangan saya la... kita share sama2... |
junraz CONTRIBUTOR
Countries/State : Age : 50 location : Negeri Dibawah Bayu Points : 12292 Reputation : 0 Number of posts : 1635
| Subject: Re: B.O.T tanpa Blowoff 19/4/2008, 5:25 pm | |
| Betul pendapat kewlone tu... |
| Subject: Re: B.O.T tanpa Blowoff 19/4/2008, 5:45 pm | |
| jadi untuk cari standard BOV (teda keching2 atau kepesh2).. sila lah berhubung dgn bro Junraz.. hehehehhe..... |
| Subject: Re: B.O.T tanpa Blowoff 20/4/2008, 1:42 am | |
| - nomo wrote:
- kenapa kereta 4x4 turbo tak pakai benda ni ok saja..sesiapa otai2 kings turbo sila membantu
mcm mana mau guna,disel car kebanyakan guna fuel pump untuk rev tu minyak....bukan mcm petrol guna throttle body (EFi),lepas pedal minyak pandai tutup tu throttle body jd tekanan berlebihan yg dijana turbo leh keluar di blow off...kalau diesel,bila di tekan tu minyak dia control di fuel pump..xdada mulut throttle untuk Chhommmm ChhoMMmmmm... lau salah betulkan arr..choommm choommm.. |
LoLLiPoP SENIOR
Age : 45 location : kk-kb-kl-putatan Points : 11909 Reputation : 0 Number of posts : 656
| Subject: Re: B.O.T tanpa Blowoff 20/4/2008, 12:33 pm | |
| pakai greddy type-s klu tiamau bunyi bising... best tu... |
bokil FRESHIE
Age : 35 location : W.P LABUAN Points : 11588 Reputation : 0 Number of posts : 25
| Subject: Re: B.O.T tanpa Blowoff 7/6/2009, 2:48 pm | |
| pakai blow off Sheep Doggg pn sdp juga tu!!! |
Countries/State : Age : 35 location : Kota kinabalu,sabah Website : https://www.facebook.com/profile.php?id=100002328674361 Tag ID: : 00735 Points : 13777 Reputation : 24 Number of posts : 7994
| Subject: Re: B.O.T tanpa Blowoff 7/6/2009, 3:37 pm | |
| jika nda mau asyik kecchhiiinngg kasi tukar turbo besar ja...sebab lambat masuk boost kan...mo blast baru ada bunyi...sama kasi up boost sekali.. |
kelisa_hitachi REGULAR
Age : 41 location : keningau~kk Tag ID: : TAG ID : SFC 03153 Points : 11759 Reputation : 0 Number of posts : 315
| Subject: Re: B.O.T tanpa Blowoff 7/6/2009, 5:04 pm | |
| pakai je la BOV..xnk bunyi jgn la blast..maintain slow je BOV--->pish...pishh SQV--->kechinggg..kechinggg |
LIDEY JUNIOR
Countries/State : Age : 40 location : sabah Points : 11149 Reputation : 3 Number of posts : 161
| Subject: Re: B.O.T tanpa Blowoff 7/6/2009, 5:16 pm | |
oky_da_alung CONTRIBUTOR
Countries/State : Age : 38 location : Sandakan - Ranau - KK - Kuala Penyu Tag ID: : SFC 04806 Points : 12350 Reputation : 6 Number of posts : 1251
| Subject: Re: B.O.T tanpa Blowoff 7/6/2009, 10:55 pm | |
| klu x mo terasa mcm menunjuk nunjuk. bawa keta mcm org gila.hehehe..nnti org blah sama kita.. |
AIRpulse CONTRIBUTOR
Countries/State : Age : 43 location : BKI <--> KGU &l Website : http://www.hasegawa-kitagawa-sigma.jp Tag ID: : S.F.C 0548 Points : 12811 Reputation : 9 Number of posts : 1725
| Subject: Re: B.O.T tanpa Blowoff 8/6/2009, 10:53 am | |
| thanks..sekarang baru saya faham napa 4x4 yg ada turbo tu tiada bunyi kepish tu..
betul jugala, ramai menunjuk2 woo mantang2 ada turbo, tarik sikit ja suda bunyi kepish dia..
rupanya bunyi tu memang ada fungsi pula.. |
| Subject: Re: B.O.T tanpa Blowoff 8/6/2009, 1:40 pm | |
| ye la...kalu xpkai nanti air surge lak...rosak tebo |
DarkSmoke JUNIOR
Countries/State : Age : 30 location : Melaka Points : 11257 Reputation : 6 Number of posts : 115
| Subject: Re: B.O.T tanpa Blowoff 8/6/2009, 7:18 pm | |
| BlowOff dpt panjang kan hayat turbo,harga pun okok.. blowOff dpt kasi kurang turbo lag bha kan???~~~correct me if im wrong klu kreta x EFI pun buli pakai turbo ka?? |
zul@LA SUPERIOR
Countries/State : Age : 42 location : kapayan Tag ID: : 03519 Points : 12403 Reputation : 12 Number of posts : 2259
| Subject: Re: B.O.T tanpa Blowoff 8/6/2009, 7:34 pm | |
| klu mau kasi hilang 2 bunyi kepisshh2,pasang silentser depan blowoff,kompom sunyi punya.. wakakak.. |
| Subject: Re: B.O.T tanpa Blowoff 9/6/2009, 1:05 am | |
| kete karb pun ramai yg bikin tebo skang ni |
GTO TBNK CONTRIBUTOR
Countries/State : Age : 35 location : lahad datu-k.b Tag ID: : SFC 06385 Points : 12147 Reputation : 7 Number of posts : 1033
| Subject: Re: B.O.T tanpa Blowoff 9/6/2009, 6:22 am | |
| bro klu x pakai blowoff x apa lagi pun blowoff cuma nak bagi ganas bunyi tapi misal kata injin ko turbo ja x da msalah lagi pun klu mau bagi laju kereta mu 2 ko kena set bal turbo ngan guna felter racing kos aku slalu ikut drag kat tawau |
| Subject: Re: B.O.T tanpa Blowoff 9/6/2009, 8:26 am | |
| ko selalu ikut drag???selalu pergi ke selalu join race??? ko pakai kete apa???drag taun bila??? |
bod_supersperm SUPERIOR
Countries/State : Age : 42 location : kota kinabalu sabah Tag ID: : SFC 03551 Points : 13789 Reputation : 6 Number of posts : 2276
| Subject: Re: B.O.T tanpa Blowoff 9/6/2009, 9:32 am | |
| orang ringgo kali arh...ringgo tu Drag King Tawau..mesti org kenal.. hehe..pakai blow off tiada bunyi nunjuk2 aku rasa pakai turbo besar kali ya..hehe..idea taruk silencer tu pun ok..simpan piping ka..hahaks..blow off ada piping..ada bullet dan muffler..sure sunyi tu..hehe |
| Subject: Re: B.O.T tanpa Blowoff 9/6/2009, 5:04 pm | |
| mcm menarik oo xda blow off...hehehehe |
| Subject: Re: B.O.T tanpa Blowoff 9/6/2009, 8:01 pm | |
| bod.... ringgo punya stail sempoi...tapi ayat GTO tuh lain..kalu tol pun selalu join drag org xkan cakap...besanya org yg hebat die slow..humble...mcm nieto |
| Subject: Re: B.O.T tanpa Blowoff | |
