| kereta tia mau idup..mau minta tlg neh.. | |
DarkSmoke JUNIOR
Countries/State : Age : 30 location : Melaka Points : 11257 Reputation : 6 Number of posts : 115
| Subject: kereta tia mau idup..mau minta tlg neh.. 4/12/2009, 1:38 pm | |
| kereta saya tia mau start bha...kereta lama,toyota corona.cek voltage battries normal jak...npa tu arh?? ada problem wiring ka?? mau kena pakai jumper bru dia mau idup..cek alternator ok jak..tyme idle voltage d battries naik..tu besa la kan,kena cas pakai alternator.. lepas sdh idup,saya bawa jln2..kmudian kasi mati..lepas tu kasi idup balik kdg2 dia idup kdg2 tia idup..trpaksa call member minta tlg kasi jumper...klu dia tia mau idup tu kan,tyme kasi on acc lampu depan pun kdg2 tia idup,tapi voltage battries ok jak...npa tu arh?harap otai2 kereta buli bntu...sedih neh tia drive kereta..hehe |
NeoSquall JUNIOR
Age : 36 location : Kota Kinabalu Points : 12082 Reputation : 0 Number of posts : 83
| Subject: Re: kereta tia mau idup..mau minta tlg neh.. 4/12/2009, 3:00 pm | |
| battery not enough amps to run your starter.. need to change.. eventhough you battery is not enough power.. the reading will still be 12V.. or 11.5V.. its the amps that you need to count..the voltage doesnt help.. as a general rule.. when it goes down below 12V like 11V or 11.5V.. thats the time the battery is starting to fail.. |
swordfishxox WEBMASTER
Countries/State : Age : 43 location : Putrajaya, Perak Tag ID: : SFC 04219 Points : 16233 Reputation : 35 Number of posts : 4825
| Subject: Re: kereta tia mau idup..mau minta tlg neh.. 4/12/2009, 3:05 pm | |
| baru ni kereta bini aku kena... dia pakai kelisa... nak start payah... tgh bawah leh mati enjin... ingat masalah bateri... aku pun pi jumpa mekanik dia kata.. skali belt putus... dkt area waterpump... check punya check... jumpa main problem... waterpump aku jammed... sbb tu belt putus... lps tukar waterpump sama belt... trus kereta bini aku jadi ok... xtau la pula kes ko macam mana
| Subject: Re: kereta tia mau idup..mau minta tlg neh.. 5/12/2009, 1:58 am | |
| bro, setakat check voltage tak cukup.
pakai battery tester check, kalau reading ialah 12v, cuba tekan itu switch di battery tester, kalau rendah dari 10v, battery tiada power.
test air battery juga untuk pastikan battery rosak atau cuma hilang tenaga. |
DarkSmoke JUNIOR
| Subject: Re: kereta tia mau idup..mau minta tlg neh.. 5/12/2009, 8:56 am | |
| Ty bro Neo...bro Nieto,sya sdh try tu batteri tester tyme d workshop,org tu bilang batteri ok jak...Batteri sel kering bro,tiada air..hehe MyB betul ckp bro NeoSqual,mau try la ne tukar bateri baru... or Batteri tia ckup cas kali...hehe |
| Subject: Re: kereta tia mau idup..mau minta tlg neh.. 5/12/2009, 9:49 am | |
| batteri tiada sel kering bro, itu maintainance free. dalam dia tetap ada air, cuma dia tak gitu cepat kurang. |
DarkSmoke JUNIOR
| Subject: Re: kereta tia mau idup..mau minta tlg neh.. 5/12/2009, 7:08 pm | |
| owh...bgitu pula..brapa lama tahan tu arh?? apa punca2 batteri saya ada masalah arh?? saya ada pasang,stablizer yg smbung p karen tu,2 amp 4 channel.. saya tia taw la pa puncanya.... |
| Subject: Re: kereta tia mau idup..mau minta tlg neh.. 5/12/2009, 7:14 pm | |
| battery tak dapat ramalkan bila rosak punya, stabilizer tak bantu banyak. amplifer, sportlight salah satu punca mengurangkan hayat battery, altenator lemah juga puncanya.
kereta kena setiap hari jalan, kalau tidak tenaga bateri pun pandai kurang, kena panas pun pandai pendekan hayat. |
| Subject: Re: kereta tia mau idup..mau minta tlg neh.. | |
