Shahrir FRESHIE
Countries/State : Age : 35 location : kuala pilah Points : 10616 Reputation : 1 Number of posts : 28
| Subject: Piston kancil up 30/11/2009, 2:45 pm | |
| aku kancil 660 ex nk upgrade pinston tapi comfius sikit ade pomen ckap pkai pinston 1.3 wira ade beza ke pkai iswara or saga pinston? lagi satu ape beza 2e ngn pinston 1.3 saga... help plz |
Viero MODERATOR
Countries/State : Age : 105 location : Melbourne Website : https://www.facebook.com/Vieros Points : 12429 Reputation : 18 Number of posts : 2464
| Subject: Re: Piston kancil up 1/12/2009, 8:16 am | |
| engine iswara & wira 1.3 sama ja... engine 4g13... rasanya takde beza... piston 2e tu turbo punya piston, 1.3 saga piston biasa jak... mau upgrade piston kancil 660 ni bro, kena pikir panjang juga... mau standby reserve block engine... lepas rebore masuk pison besar, block jadi lebih nipis... bila2 engine crack... alang2 ambik halfcut turbo...hehe |
Shahrir FRESHIE
| Subject: Re: Piston kancil up 1/12/2009, 8:21 am | |
| mahal lah turbo beli halfcut dah rm2k upah lagi rm1k... xmampu lah.. klu mampu dah lame aku amek turbo... |
Viero MODERATOR
| Subject: Re: Piston kancil up 1/12/2009, 8:29 am | |
| halfcut turbo 2k... cun harga tu... d sini halfcut l2s mau sampai 5k skrang ni... tolak bodypart ambik engine ja pun mau 3.5k harga... |
Shahrir FRESHIE
| Subject: Re: Piston kancil up 1/12/2009, 8:46 am | |
| aku baget rm1k cmru je... halfcut 2k upah 1k dah 3k bro... haahha lari baget,, aku egat nk upgrade pinston... max speed 160 bleh kan ... aku nk bagi pickup skit je spaya sng aku nk potong lori... nnt ade duit lebih aku pkai extractor 3.1 ngn open pad k&n ok kan.... just main n.a je |
DonJuanDeMarco REGULAR
Countries/State : Age : 46 location : SHAH ALAM Points : 11635 Reputation : 9 Number of posts : 269
| Subject: Re: Piston kancil up 1/12/2009, 12:27 pm | |
| - Viero wrote:
- engine iswara & wira 1.3 sama ja... engine 4g13... rasanya takde beza...
piston 2e tu turbo punya piston, 1.3 saga piston biasa jak... mau upgrade piston kancil 660 ni bro, kena pikir panjang juga... mau standby reserve block engine... lepas rebore masuk pison besar, block jadi lebih nipis... bila2 engine crack... alang2 ambik halfcut turbo...hehe betol tu.. wa sokong 120%.. |
Shahrir FRESHIE
| Subject: Re: Piston kancil up 1/12/2009, 12:32 pm | |
| klu bleh aku wat loan turbo dah lame aku wat... aku cadang nk wat extrator 3.1 n open pod k&n tapi mmber aku ckap baik pkai piston... turbo mahal sgt... nnt nk mantanace aku xmampu.. ape2 pun turbo mmg best... nk wat hicam macam mahal je.. ntah lah aku pun xpernh survey.. tapi pickup x top speed tambah x? |
swordfishxox WEBMASTER
Countries/State : Age : 43 location : Putrajaya, Perak Tag ID: : SFC 04219 Points : 16233 Reputation : 35 Number of posts : 4825
| Subject: Re: Piston kancil up 1/12/2009, 12:51 pm | |
| ada cara lain bro... member aku ada ckp ko main cluth 850 je... tu pun leh tambah pickup... stakat nk potong lori xde hal punya... kalu main piston tu agak2 la bro... enjin crack sama juga kalu ko angkat turbo... puas ati... kalu kancil lari 160 bukan piston je ko kena tukar... brek mau jaga, beringat la sblm kena...
Shahrir FRESHIE
| Subject: Re: Piston kancil up 1/12/2009, 1:37 pm | |
| tapi member aku ckap dia pernah tukar cluth 850 tapi xnmpk pun pickup... same je.. any sugestion lain? |
Viero MODERATOR
| Subject: Re: Piston kancil up 1/12/2009, 4:51 pm | |
| pakai clutch 850 pastu skim flyweel... kompom nampak pickup tambah...hehe |
Viero MODERATOR
| Subject: Re: Piston kancil up 1/12/2009, 5:18 pm | |
| main standard kilang 660 bgus ko try tukar piping dari depan sampai blakang 1.7 lepas tu pakai plug denso iridium, pakai cable plug besar(jngn pkai cap ayam)... masuk extractor 3-1, buat port&polish... pakai sportrim ringan(japan rim), air cleaner pakai open pod punya(brand mesti champion punya macam K&N), pakai adjustable cam puley(setting ni mesti champion tangan) masuk lg fuel regulator (n/a punya), pasang lagi grounding cable... klu mau, pasang oil catch tank utk jaga hayat engine tu, lepas tu test la kereta tu, kalau x laju juga dri standard kilang, ambil blok 850 kahwin head l2/l2s 12v, masuk turbokit(best kalau efi ni)... hehe x puas hati, kalau turbokit efi, pasang e-manage, klu mau microtech pun bule dipasang... hehe |
Putra FRESHIE
Countries/State : Age : 34 location : Sepanggar-Papar-Labuan Points : 10871 Reputation : 1 Number of posts : 51
| Subject: Re: Piston kancil up 1/12/2009, 7:04 pm | |
| - Viero wrote:
- main standard kilang 660 bgus ko try tukar piping dari depan sampai blakang 1.7
lepas tu pakai plug denso iridium, pakai cable plug besar(jngn pkai cap ayam)... masuk extractor 3-1, buat port&polish... pakai sportrim ringan(japan rim), air cleaner pakai open pod punya(brand mesti champion punya macam K&N), pakai adjustable cam puley(setting ni mesti champion tangan) masuk lg fuel regulator (n/a punya), pasang lagi grounding cable... klu mau, pasang oil catch tank utk jaga hayat engine tu, lepas tu test la kereta tu, kalau x laju juga dri standard kilang, ambil blok 850 kahwin head l2/l2s 12v, masuk turbokit(best kalau efi ni)... hehe x puas hati, kalau turbokit efi, pasang e-manage, klu mau microtech pun bule dipasang... hehe kalaw kasi 2 inci ngam ka tu? xda bullet kasi direct masuk performence muffler, haha, harga port polish untuk kancil berapa erk.. |
Shahrir FRESHIE
| Subject: Re: Piston kancil up 1/12/2009, 11:10 pm | |
| - Viero wrote:
- pakai clutch 850 pastu skim flyweel... kompom nampak pickup tambah...hehe
macam mantap je... tapi klu pkai clutct racing leh masuk x? then ape brand? bape harge skim flyweel pula?... sory im new... nak tau baget siap pasang n brand best |
Shahrir FRESHIE
| Subject: Re: Piston kancil up 1/12/2009, 11:18 pm | |
lepas tu pakai plug denso iridium, pakai cable plug besar(jngn pkai cap ayam)... masuk extractor 3-1, buat port&polish... pakai sportrim ringan(japan rim), air cleaner pakai open pod punya(brand mesti champion punya macam K&N), pakai adjustable cam puley(setting ni mesti champion tangan) masuk lg fuel regulator (n/a punya), pasang lagi grounding cable... klu mau, pasang oil catch tank utk jaga hayat engine tu, lepas tu test la kereta tu, kalau x laju juga dri standard kilang, ambil blok 850 kahwin head l2/l2s 12v, masuk turbokit(best kalau efi ni)... hehe x puas hati, kalau turbokit efi, pasang e-manage, klu mau microtech pun bule dipasang... hehe mantap lah bro... aku suka care ko komen aku... sunguh membina heheheh... erm fuel regulator tu brand ape bgus? bape harge.... dia ade meter ke? hehehe |
Countries/State : Age : 35 location : Kota kinabalu,sabah Website : https://www.facebook.com/profile.php?id=100002328674361 Tag ID: : 00735 Points : 13777 Reputation : 24 Number of posts : 7994
| Subject: Re: Piston kancil up 2/12/2009, 1:23 am | |
| kalau main tebo mmg kos tinggi sudah tapi puas hati bro.... |
| Subject: Re: Piston kancil up 2/12/2009, 1:12 pm | |
| tukar caburetor mikuni,performance camshaft & xtractor..pon dah byk beza.. |
Putra FRESHIE
| Subject: Re: Piston kancil up 2/12/2009, 11:12 pm | |
| - swordfishxox wrote:
- ada cara lain bro...
betul tu.. tp.. masuk je la piston besar, haha, kasi puas at.. tp spare blok 1 jga.. besa orang men piston besar mesti ada spare blok.. silap2 hari bulan tersadai tepi jalan.. |
Shahrir FRESHIE
| Subject: Re: Piston kancil up 2/12/2009, 11:21 pm | |
betul tu.. tp.. masuk je la piston besar, haha, kasi puas at.. tp spare blok 1 jga.. besa orang men piston besar mesti ada spare blok.. silap2 hari bulan tersadai tepi jalan.. haha ade juga member yg sokong aku... wa blok nk kena spare ke... bape baget blok skng ek?haah kan alang2 pkai piston besar trus.. hahah puas ati... tapi bape baget pling murah nk wat bro? aku tgh survey ari tu dia kate rm1100 murah ke? |
Age : 42 location : Semporna / Tawau / Lahad Datu / Flamingo / Putatan Points : 12494 Reputation : 3 Number of posts : 1106
| Subject: Re: Piston kancil up 3/12/2009, 9:16 am | |
| blok 660 max rebore 74mm (paling last), pakai 4e nya piston mmg NA punya, potong 2mm atas dia supaya head x kena valve.
p/s = x kuat mana pon NA kalau stakat ganti piston paling besar mana pon, pakai turbo mmg kick heheheh (racun racun) wakakakak. |
Putra FRESHIE
| Subject: Re: Piston kancil up 3/12/2009, 4:13 pm | |
| - pioneer_syntium wrote:
- blok 660 max rebore 74mm (paling last), pakai 4e nya piston mmg NA punya, potong 2mm atas dia supaya head x kena valve.
p/s = x kuat mana pon NA kalau stakat ganti piston paling besar mana pon, pakai turbo mmg kick heheheh (racun racun) wakakakak. yaya.. bak kata seorang sepupuku.. N.A is better.. BUT TURBO IS THE BEST wkwkwk.. nak main n.a men ar blok ngan pisten ni ngam.. p x lawan larian tubo.. harga x pasti lak.. ikut tempat ar.. ngam sgt law ko guna blok 850 pastu pisten 1.3, wkwkwk, tp kalau da bajet lebih.. main l2s cam pioneer.. taiko l2s
Shahrir FRESHIE
| Subject: Re: Piston kancil up 3/12/2009, 10:26 pm | |
| yelah2 atas permintaan smua nk aku turbo... aku kumpul duit turbo terus l2s..... baru nk main n.a. tapi smua batu api hasut pkai turbo...... geram btul aku... klu aku pkai x pickup turbo siap korang. hahaha erm bape baget aku ni? rm2000 kebawah bleh dapat x siap pasang |
Putra FRESHIE
| Subject: Re: Piston kancil up 4/12/2009, 11:23 am | |
| - Shahrir wrote:
- yelah2 atas permintaan smua nk aku turbo... aku kumpul duit turbo terus l2s..... baru nk main n.a. tapi smua batu api hasut pkai turbo...... geram btul aku... klu aku pkai x pickup turbo siap korang. hahaha erm bape baget aku ni? rm2000 kebawah bleh dapat x siap pasang
x taw la pula tmpt ko, sini kat sabah mahal geng.. l2s halfcut rm2500-rm3000++ cari orang2 yang nak besara main l2s r best.. macam ada member nak jual kereta haritu dia cari enjin kilang nak trade in l2s dia complete pai tangki minyak smua, dia minta rm1500++ je.. hehe, rajin2 cari ar.. |
AP3_3927 REGULAR
Countries/State : Age : 31 location : keningau-kk Tag ID: : SFC 05172 Points : 11484 Reputation : 3 Number of posts : 338
| Subject: Re: Piston kancil up 4/12/2009, 8:28 pm | |
| - Putra wrote:
x taw la pula tmpt ko, sini kat sabah mahal geng.. l2s halfcut rm2500-rm3000++ cari orang2 yang nak besara main l2s r best.. macam ada member nak jual kereta haritu dia cari enjin kilang nak trade in l2s dia complete pai tangki minyak smua, dia minta rm1500++ je.. hehe, rajin2 cari ar.. Ya bro.. L2s cnie sabah dlam RM2500-Rm3500.. halfcut Rm3500.. klu Rm2500 enjin lantai ja.. |
the BLitz CONTRIBUTOR
Countries/State : Age : 37 location : kota belud Tag ID: : SFC 04544 Points : 12736 Reputation : 11 Number of posts : 1700
| Subject: Re: Piston kancil up 4/12/2009, 8:43 pm | |
| uik kwn aku angkat halfcut L2s di inanam baru2 ni Rm5000.. kira murah sdh tu klu ada yg RM3500..
Putra FRESHIE
| Subject: Re: Piston kancil up 4/12/2009, 10:02 pm | |
| - the BLitz wrote:
uik kwn aku angkat halfcut L2s di inanam baru2 ni Rm5000.. kira murah sdh tu klu ada yg RM3500.. rm3500 x syok.. sal xda budikit.. hehe, enjin complete tangki smua komputer bux ja.. yang rm5000 tu puas at tu taw.. |
| Subject: Re: Piston kancil up | |
