| | Tips on how to clean your car battery terminal... | |
| Author | Message |
babyiemori69 CONTRIBUTOR
Countries/State : Age : 39 location : JeSSeLtoN, Sabah Website : www.twitter.com/babyiemori69 Tag ID: : SFC 09305 Points : 12381 Reputation : 19 Number of posts : 1644
| Subject: Tips on how to clean your car battery terminal... 1/7/2010, 4:07 pm | |
| So you've decided those battery terminals need to be cleaned. If they are dirty, corroded or covered in calcium, then you are right! I am excited to present you with an easy how-to on cleaning your battery terminals. It is a simple and easy job that ANYONE can do, and you might just like it so much that you decide to do a little more maintenance. Which is what I am hoping! If you're bitten by the maintenance bug, you can learn some basic auto repair tips. 1. Head down to your local auto parts store, or get online. You need to buy yourself a battery terminal brush and some battery cleaner spray. It is also wise to invest in a cheap set of gloves for this endeavor, but they are optional. 2. Pull out that old toolset you've had in the back of the closet. You will need a socket, wrench, and possibly a crescent wrench. Once you have located these tools (or gone out and bought some), your job is to remove the battery cables from the battery. Make sure your car is off and they keys are not in the ignition before you try to remove them. 3. After you have removed the cables from the terminals, get out your handy dandy can of battery cleaning spray. Do not be afraid to cover your battery terminals and cable connectors with this cleaning product. It is made of an acidic chemical that will help break away the rust, corrosion and calcium that may have built up on your battery.
| | | Kornurts SIFU
Countries/State : Age : 33 location : KK**TAWAU** Website : Www.Sioloon.com[Low Profile Crew] Tag ID: : SFC 15951 Points : 18489 Reputation : 128 Number of posts : 8256
| Subject: Re: Tips on how to clean your car battery terminal... 3/10/2010, 3:26 pm | |
| thanks 4 da info sis..sis,if me,juz use the boiled/hot water to clean the batry terminal...the calcium that covered btry terminal wiil be punish and clean..hihihihi |
| | | bebiri JUNIOR
Countries/State : Age : 43 location : KK and Kuching Points : 10833 Reputation : 4 Number of posts : 219
| Subject: Re: Tips on how to clean your car battery terminal... 10/12/2010, 6:24 pm | |
| hi there,i just wanna share my 2 cents.
1.cleaning =use boil water same as Kornurts 2.prevention = a)buy tht sponge thingy from parts shop(i dunno it's name),it's oily something like sewing machine oil,it prevents the build of calcium. b)the metal battery holder would corroded and must b clean.Clean it with hot water,wait it to dry n spray it with spray can(mine i sprayed silver color). c)best solution is to change ur battery to dry cell.(bateri kering).hassel free.
Dry Cell VS Wet Cell a)life span: approx 2 yrs,wet cell would last longer. b) maintainence : wet cell=need to add in water,dry cell= 0 maint c)price: almost the same (try to buy GP brand. |
| | | Kornurts SIFU
| Subject: Re: Tips on how to clean your car battery terminal... 10/12/2010, 11:35 pm | |
| - bebiri wrote:
- hi there,i just wanna share my 2 cents.
Dry Cell VS Wet Cell a)life span: approx 2 yrs,wet cell would last longer. b) maintainence : wet cell=need to add in water,dry cell= 0 maint c)price: almost the same (try to buy GP brand. bro,the oily thing that u mentioned is grease ka?member told me that put the grease on trminal btry can prevent the calcium.. |
| | | keba ELITE
Countries/State : Age : 34 location : Kemaman - Kota Bharu Website : contact 01119778382 Tag ID: : SFC08063 Points : 14901 Reputation : 69 Number of posts : 3981
| Subject: Re: Tips on how to clean your car battery terminal... 10/12/2010, 11:40 pm | |
| can use grease? can b used on both dry n wet cell? |
| | | bebiri JUNIOR
| Subject: Re: Tips on how to clean your car battery terminal... 11/12/2010, 2:04 am | |
| Kornurts : nope dun use grease cos when ur engine bay heat up,it vaporize and smells like something burning (quite strong),plus it's very troublesome when u gotta do maintainence(adding battery's water or help ur fren jump his dead battery ).Grease attracts dust.Anyway YES grease do prevent calcium build up.
Keba:only on wet cell normally,but sometimes dry cell do have calcium build up but not tht noticeable.
Check on Battery Maintainence on this site..u can get anti corrosion spray or that felt ring.
##When the battery terminals are re-assembled, they are coated with Vaseline/petroleum jelly (grease is not desired) to reduce the rate of corrosion accumulation##
http://www.therangerstation.com/Magazine/Fall2008/truck_batteries.htm
DIY:make a donut Felt and use Sewing Machine Lubricant(Minyak Licin)to damp it.
p/s: Felt:= a fabric type |
| Subject: Re: Tips on how to clean your car battery terminal... 12/8/2011, 11:30 pm | |
| - bebiri wrote:
- Kornurts : nope dun use grease cos when ur engine bay heat up,it vaporize and smells like something burning (quite strong),plus it's very troublesome when u gotta do maintainence(adding battery's water or help ur fren jump his dead battery ).Grease attracts dust.Anyway YES grease do prevent calcium build up.
p/s: Felt:= a fabric type ~ Very nice bro..another useful tips for us..thanks for sharing anyway ^^
| | | Sponsored content
| Subject: Re: Tips on how to clean your car battery terminal... | |
Similar topics | |
Similar topics | |
Page 1 of 1 | |
Mahu Bincang Tentang?
Aktiviti Kelab Sioloon?
Mencari Yang Menarik?
