nomo JUNIOR
Age : 43 location : kota kinabalu Points : 11813 Reputation : 0 Number of posts : 98
| Subject: oversize piston 2/9/2008, 8:23 am | |
| saya mau tau baa. apa kebaikan dan keburukan kalau oversize piston. seperti contoh kalau kasi skim head power bertambah laa tapi enjin cepat naik suhu sama skim kasi ringan flywheel jalan lurus memang ok tapi bukit susah mau naik. berapa mm size paling maksimum kalau nak over size, saya ada dengar org oversize piston kancil 660 masuk piston kelisa (68mm - 72mm= 4mm). |
Countries/State : Age : 45 location : Kota Kinabalu-Putatan Tag ID: : SFC02202 Points : 12203 Reputation : 10 Number of posts : 2945
| Subject: Re: oversize piston 3/9/2008, 7:14 pm | |
| From what I heard, that setup is the max that 660cc can re bore, correct me if im wrong |
Age : 42 location : Semporna / Tawau / Lahad Datu / Flamingo / Putatan Points : 12474 Reputation : 3 Number of posts : 1106
| Subject: Re: oversize piston 3/9/2008, 8:08 pm | |
| 72mm max bagi 660t, pasal skim head sa x tau plak temp cepat naik, baik jgn skim head tu buat p&p. lepas tu cerita pasal flywheel plak agak2 la buang tu berapa kg, selalunya 2 kg sdh cukup. |
nomo JUNIOR
| Subject: Re: oversize piston 4/9/2008, 9:03 am | |
| kalau oversize piston hp akan bertambah dan cc jga berubah. ada kesan lain ker cam enjin masalah. kita pun kena pikir 2x kalau mau kasi modified untuk inda posing2 kepala kemudian hari |
tony84 CONTRIBUTOR
Countries/State : Age : 40 location : org twu/stay d kgu/jln2 d kk Tag ID: : SFC 02317 Points : 12318 Reputation : 9 Number of posts : 1300
| Subject: Re: oversize piston 4/9/2008, 9:34 am | |
| 1 soalan....oversize piston maksud oversize diameter piston kah ketebalan piston???? |
| Subject: Re: oversize piston 4/9/2008, 10:08 am | |
| - tony84 wrote:
- 1 soalan....oversize piston maksud oversize diameter piston kah ketebalan piston????
Biasanya Oversize diameter piston, ketebalan piston amat jarang dipakai, kerana diameter piston yg menentukan compression dlm enjin, bukan ketebalan piston tersebut |
nomo JUNIOR
| Subject: Re: oversize piston 14/9/2008, 3:49 pm | |
| kalau htr sana enginering berapa dia org caj ahh kalau kasi oversize piston. |
| Subject: Re: oversize piston 14/9/2008, 7:28 pm | |
| 1 lobang blok 30 ringgit darab 3 lobang = 90 ringgit la (rebore blok) |
nomo JUNIOR
| Subject: Re: oversize piston 15/9/2008, 9:43 am | |
| mana kedai enginering yang cun bikin kalau di KK |
DeDiCooL FRESHIE
Countries/State : Age : 41 location : Sandakan, KK, Sabah Points : 12168 Reputation : 0 Number of posts : 54
| Subject: Re: oversize piston 16/9/2008, 10:17 pm | |
| bila dah install oversize piston, cc engine bertambah, torque engine tu juga akan meningkat.. Blok L2s aku pernah cuba rebore kasi fit piston kelisa.. teda masalah.. water temp. stable.. worth to try.. |
nomo JUNIOR
| Subject: Re: oversize piston 17/9/2008, 9:21 am | |
| nanti cuba try. kira power laa L2s kau skrg ni dedicool |
DeDiCooL FRESHIE
| Subject: Re: oversize piston 17/9/2008, 11:14 am | |
| blum kuat lagi nomo, masi ada yang perlu di "perfect" kan.. itu la kita sama2 belajar.. |
scrypto REGULAR
Countries/State : Age : 40 location : Kota Kinabalu Tag ID: : SFC 03719 Points : 11581 Reputation : 0 Number of posts : 385
| Subject: Re: oversize piston 6/10/2008, 9:31 am | |
| boleh ka guna piston kelisa masuk pi kancil 660??? mo rebore kan... teda kesan sampingan ka??? kalau masuk piston kelisa,, ada barang len lagi ka yang mo ditukar???? |
nomo JUNIOR
| Subject: Re: oversize piston 11/2/2009, 11:27 am | |
| kalau blok kelisa 1000cc kasi masuk piston 4e turbo,74mm kena porting tu head pison lagi ker supaya boleh boost tinggi atau x payah. |
zhariffz ELITE
Countries/State : Age : 35 location : Kota Kinabalu Tag ID: : SFC 04040 Points : 12411 Reputation : 7 Number of posts : 3450
| Subject: Re: oversize piston 11/2/2009, 11:50 am | |
| klu 4g13, piston apa & size apa yg plg ngam utk tmbh power yg kaw2 tanpa menyebabkan kerosakkan & kesan sampingan thadap enjin tersebut?? |
| Subject: Re: oversize piston 11/2/2009, 2:23 pm | |
| - zhariffz wrote:
- klu 4g13, piston apa & size apa yg plg ngam utk tmbh power yg kaw2 tanpa menyebabkan kerosakkan & kesan sampingan thadap enjin tersebut??
pakai stroker kit Proton Waja (4G18P) |
zhariffz ELITE
| Subject: Re: oversize piston 11/2/2009, 5:51 pm | |
| - blugu wrote:
pakai stroker kit Proton Waja (4G18P) confrm ngam ba ni kan bro & teda masala sampingan?wah, ni yg bez ni....... |
| Subject: Re: oversize piston 11/2/2009, 6:31 pm | |
| Komfom bro, bore piston 4G15P adala 75.5mm, bore piston utk 4G18P adalah 76mm, itu saja size maksima yg boleh utk enjin 4G13 nie bro.... slamat mencuba, lepas nie, cc utk enjin bro adalah 1.6 suda.... hehehehhe |
Red Bullet JUNIOR
Age : 42 location : Penampang Points : 11629 Reputation : 3 Number of posts : 211
| Subject: Re: oversize piston 11/2/2009, 7:30 pm | |
| - DeDiCooL wrote:
- bila dah install oversize piston, cc engine bertambah, torque engine tu juga akan meningkat.. Blok L2s aku pernah cuba rebore kasi fit piston kelisa.. teda masalah.. water temp. stable..
worth to try.. sifu bah ni... hai bro long time no see....bro ada beza kah blok 660 dgn 850 dua2 sumbat piston kelisa? |
mad4toy JUNIOR
Countries/State : Age : 44 location : Brunei Points : 11583 Reputation : 3 Number of posts : 151
| Subject: Re: oversize piston 11/2/2009, 10:05 pm | |
| cuba check oversize piston yang OEM, biasanya walaupun barang OEM tapi memang ada piston yg sudah oversize di buat oleh factory
pakai piston oversize memang cc ada up sikit lah, kalau sudah cc up power pun memang ada up juga lah, kalau untuk panduan harian bagus juga tanya block tu dalam standard boleh oversize sampai berapa |
zhariffz ELITE
| Subject: Re: oversize piston 12/2/2009, 1:02 am | |
| - blugu wrote:
- Komfom bro, bore piston 4G15P adala 75.5mm, bore piston utk 4G18P adalah 76mm, itu saja size maksima yg boleh utk enjin 4G13 nie bro.... slamat mencuba, lepas nie, cc utk enjin bro adalah 1.6 suda.... hehehehhe
thanx sifu blugu sbb bg byk info, nnt apapa aku tnya ko lg bro, thanx bro! |
nomo JUNIOR
| Subject: Re: oversize piston 12/2/2009, 10:16 am | |
| minggu lepas baru member sumbat piston kelisa kat block 660. dia nak pakai turbo besar. tapi belum jalan kat jalan gear dia ada masalah. |
fred_blet FRESHIE
Countries/State : Age : 35 location : Tuaran Tag ID: : SFC 04941 Points : 11132 Reputation : 0 Number of posts : 60
| Subject: Re: oversize piston 16/2/2009, 1:20 pm | |
| bos klu enjin 4k pla mcm? |
JayRyan FRESHIE
Age : 35 location : putatan Points : 11216 Reputation : 0 Number of posts : 27
| Subject: Re: oversize piston 16/2/2009, 8:42 pm | |
| erm...stroker kit 4G18 proton waja tu apa erk?? hehehe.. xtau menaw ne psl enjin2 ne... n kos nya?? tq sifu2 skalian... |
amenk REGULAR
Countries/State : Age : 38 location : Tuaran sabah Points : 11406 Reputation : 0 Number of posts : 418
| Subject: Re: oversize piston 28/2/2009, 6:37 pm | |
| otai2 sekalian..... tlong2 dlu..kekke enjin mna 1 boleh msuk piston 1JZ or 2JZ...??
1) GSR 2) VR4 3) EVO3 4) mivec
| Subject: Re: oversize piston | |
