Countries/State : Age : 30 location : Melaka Points : 11243 Reputation : 6 Number of posts : 115
Subject: ceta pasal gear 4/5/2009, 11:15 pm
halo kawan2,baru2 ni sya bwa kreta cikgu skola mnegah sya,keta wira engine vr4 full modify kali,turbo garrett(sadap bawa ni keta,gear 2 blum abis tarik smpai 120km/h)...sya mau taw bha pasal gearnya,besa kalau kreta standet mau masuk gear kasi dalam2 surung itu batang gear,tapi keta yg sya bawa ari tu,surung sikit seja...knapa itu arh??sapa2 buli kasi tunjuk ajar??sory sya budak bru blajar..hehe
Countries/State : Age : 35 location : Kota Kinabalu Tag ID: : SFC 01287 Points : 13599 Reputation : 34 Number of posts : 5595
Subject: Re: ceta pasal gear 4/5/2009, 11:30 pm
maksud brother, kereta cikgu kamu time masuk gear, itu gear knob tolak sikit saja?
kalau tak silap dia ada pakai short shift kali.
motec12 REGULAR
Countries/State : Age : 37 location : Tawau Tag ID: : SFC 05325 Points : 11558 Reputation : 7 Number of posts : 488
Subject: Re: ceta pasal gear 4/5/2009, 11:35 pm
atau quick shiift
Subject: Re: ceta pasal gear 5/5/2009, 12:15 am
oh ya, sama saja bah tu. hahahaha
Silent_Night CONTRIBUTOR
Age : 36 location : Keningau-Kota Kinabalu Tag ID: : 3910 Points : 11630 Reputation : 1 Number of posts : 1137
Subject: Re: ceta pasal gear 5/5/2009, 12:49 am
erm....Tuan Nieto...ada jenis ka quick shifter nie..aku kurang pasti lg...boleh share2 ka??...
DarkSmoke JUNIOR
Subject: Re: ceta pasal gear 5/5/2009, 1:01 am
ya,sikit2 jak di tolak trus msuk gear...mcm mna mau buat tu arh??brapa kos nya??
matnoor REGULAR
Countries/State : Age : 37 location : Labuan - Gerai bukit Tg. Aru... Points : 11472 Reputation : 3 Number of posts : 390
Subject: Re: ceta pasal gear 5/5/2009, 7:34 am
quick shift cepat kan masuk gear hehehe...rasa ringan..hmmm ..harga dlm rm300 kali...
Countries/State : Age : 45 location : Kota Kinabalu-Putatan Tag ID: : SFC02202 Points : 12209 Reputation : 10 Number of posts : 2945
Subject: Re: ceta pasal gear 5/5/2009, 7:39 am
What is a short shifter?
The desired effect of a short shifter is to reduce the distance your hand needs to move to engage the next gear, thus reducing the amount of time spent shifting, reducing wasted time between shifts, and resulting in improved performance. A common misconception in the tuning world is that a short shifter is just a chopped off version of the stock shifter. In fact, chopping your shifter has no effect on the angle that your shifter shaft travels through between gears and therefore does not reduce the shifter's angular throw.
A true short shifter decreases throw by reducing the angle that the shifter shaft travels through during its stroke between gears. By reducing the angle that the shaft travels through between gears, the distance that your hand needs to move between gears is also reduced. In many cases, the shifter shaft is also re-designed to be shorter than stock thus creating a sportier look and feel, as well as aiding in reducing the linear throw length when coupled with the reduced angular throw.
The geometry of a short shifter differs from the stock shifter in order to reduce the distance that the upper section where your shift knob threads on needs to move to achieve the same degree of movement in the lower section where the shift rod or shifter cables attach. This ensures that although your hand is moving a shorter distance, the transmission is still fully engaged in every gear. The main pivot point, or fulcrum of the shifter lever is re-positioned on the shaft in such a way that the lower section which connects to the shift rod or shifter cables is longer than stock, resulting in the desired effect. A TWM short shifter is carefully designed to create the optimal throw length, angular shift throw, and shift knob height resulting in the ultimate short shifter.
The end result is a shorter, more precise shift, which requires a shorter hand movement to engage the next gear, and looks and feels sportier than the unsightly long shifter shaft most cars come stock with.
matnoor REGULAR
Subject: Re: ceta pasal gear 5/5/2009, 7:43 am
bro blugu bnda ni boleh buat custom ka? huhuhu
Subject: Re: ceta pasal gear 5/5/2009, 7:54 am
Boleh, terdapat cara yang lebih mudah untuk customize short shift nie, tetapi kena mod di bahagian gearbox untuk menghasilkan kesan short shift yang sama. Kesan sampingannya pula, masa nak engage gear agak keras & kedudukan gear knob akan kebelakang sedikit berbanding short-shift kit.
matnoor REGULAR
Subject: Re: ceta pasal gear 5/5/2009, 6:56 pm
ya ka..hmm alang² beli ja la aftermarket pnya..lagi bgs kalau gtu..
Countries/State : Age : 35 location : Kk-Keningau-Beaufort-Kuching Tag ID: : SFC02081 Points : 13982 Reputation : 10 Number of posts : 6723
Subject: Re: ceta pasal gear 5/5/2009, 9:07 pm
bro,ko skulah di mna?tucikgu mu siapa namanya...mnataw kenal heheh...
p/s : keluar topic skit..maybe dya sudah pakai quick shift
Age : 42 location : Semporna / Tawau / Lahad Datu / Flamingo / Putatan Points : 12480 Reputation : 3 Number of posts : 1106
Subject: Re: ceta pasal gear 5/5/2009, 9:26 pm
gear sa pon sama tolak skit jak sdh masuk tapi kekerasan gear pula masalah x la keras btl, ada bikin skit la
DarkSmoke JUNIOR
Subject: Re: ceta pasal gear 5/5/2009, 9:58 pm
ya bgus,tapi ada ka untuk keta yg lama??mcm corona GL
DarkSmoke JUNIOR
Subject: Re: ceta pasal gear 5/5/2009, 10:01 pm
hehe,namanya???Louis,ckgu physic sya,d Kudat bha.. dulu keta ni abg nya yg punya,aku dgr2 slalu kunu dulu d Lintas tarik2...(urg ckp la)hehe
Subject: Re: ceta pasal gear 5/5/2009, 10:02 pm
aftermarket brand biasa, rm150 harga di kl lah.
DarkSmoke JUNIOR
Subject: Re: ceta pasal gear 5/5/2009, 10:21 pm
buli tlg cari ka bro?hehehehe
Subject: Re: ceta pasal gear 5/5/2009, 10:22 pm
kalau tak silap mudah ada jual, tapi tak tau apa brand
DarkSmoke JUNIOR
Subject: Re: ceta pasal gear 5/5/2009, 10:25 pm
smua keta sama ka tu bro??apa2 model pun buli masuk ka??
Subject: Re: ceta pasal gear 5/5/2009, 10:26 pm
bukan semua, tengok model juga tu.
DarkSmoke JUNIOR
Subject: Re: ceta pasal gear 5/5/2009, 10:31 pm
ooo,sya ni x taw pa2,heheh,terpaksa la ni bawa p workshop suruh drg atur.. ada keburukan ka ni barang?
bbr 193 REGULAR
Age : 111 location : SELURUH SABAH Points : 11602 Reputation : 0 Number of posts : 291
Subject: Re: ceta pasal gear 5/5/2009, 11:25 pm
bro darksmoke..ko punya kerata apa jenis...klu wira aku ada RM130
pnp untuk wira....
klu berminat ko pm aku k...aku boleh tolong pasang lagi..
chiqen JUNIOR
Countries/State : Age : 43 location : kedah Points : 11110 Reputation : 1 Number of posts : 93
Subject: Re: ceta pasal gear 6/5/2009, 1:30 pm
model integra da6 ada stock tak bro bbr 193
bbr 193 REGULAR
Subject: Re: ceta pasal gear 6/5/2009, 4:58 pm
ADA BAH..KO PM AKU
DarkSmoke JUNIOR
Subject: Re: ceta pasal gear 6/5/2009, 7:33 pm
pnp untuk wira....
kreta lama boss,toyota corona gl...huhuh wira punya buli masuk ka???
