| Minta pendapat engine 4AG | |
ae110_toms FRESHIE
Age : 36 location : KK Points : 11816 Reputation : 0 Number of posts : 2
| Subject: Re: Minta pendapat engine 4AG 14/3/2008, 6:19 pm | |
| I'm new here. i nak tanya tentang 4AG. Jika nak turbocharge dengan 20 valves, mana yang lebih baik? silver atau black? Dan, boleh guna piston 4AGZE tuk lower compression kah? Saiz ngam tau tidak? |
Countries/State : Age : 45 location : Kota Kinabalu-Putatan Tag ID: : SFC02202 Points : 12217 Reputation : 10 Number of posts : 2945
| Subject: Re: Minta pendapat engine 4AG 18/3/2008, 6:44 pm | |
| tak silap, saiz blok sama, piston supercharger adalah piston low compression dgn seramik coated, mmg tiada masalah kalau masuk blok 4AG Enjin Blacktop mmg mantap |
ikankalui PARTNER
Countries/State : Age : 47 location : Putatan-Kota Kinabalu Website : www.dcl2u.webs.com Points : 12203 Reputation : 0 Number of posts : 1209
| Subject: Re: Minta pendapat engine 4AG 26/3/2008, 9:24 am | |
Lemon_ae92 SENIOR
Age : 36 location : Keningau Tag ID: : SFC 02137 Points : 12018 Reputation : 0 Number of posts : 711
| Subject: Re: Minta pendapat engine 4AG 26/4/2008, 1:33 am | |
| hahahhaha lawala bro kalui .... bila la nak jdi dreber mcm ni .... g2 sisip2 pun nampak kha bro wakakakaka |
te37 MODERATOR
Countries/State : Age : 37 location : Kota Kinabalu - Keningau Tag ID: : SFC 02132 Points : 12184 Reputation : 0 Number of posts : 2660
| Subject: Re: Minta pendapat engine 4AG 26/4/2008, 7:00 pm | |
| chris brown bha dreber dia tu...ehhehehehe |
Countries/State : Age : 35 location : Kk-Keningau-Beaufort-Kuching Tag ID: : SFC02081 Points : 13990 Reputation : 10 Number of posts : 6723
| Subject: Re: Minta pendapat engine 4AG 27/4/2008, 1:25 am | |
| bukan..christoper M tuu... |
Lemon_ae92 SENIOR
| Subject: Re: Minta pendapat engine 4AG 27/4/2008, 8:15 pm | |
| bila la dapat bwa injin ini mcham >> .... chommm!2x |
colvinae101 FRESHIE
Age : 44 location : kota kinabalu Points : 11626 Reputation : 0 Number of posts : 30
| Subject: Re: Minta pendapat engine 4AG 29/6/2008, 10:45 pm | |
| boleh sy share experience cni pasal turbocharging a 20valver 4ag? ok...20v ada dua jenis kan kita semua da tau..tapi 2 siri engine ini agak berbeza..perbezaan di cni bukan pasal horsepower yg ia hasil kan tapi ketahanan engine tersebut jika di"turbocharge"kan...silvertop terdapat 2 generasi nya...generasi ni dapat dibezakan dari throttle linkage nya...1st generation SVT 2 linkage yg hanya menghasil hp 145 sebenarnya daripada 160hp yg diperkatakan dlm spec...and 2nd genarasi 1 linkage yg menghasil kan 155hp daripada 160hp dan mempunyai sistem ecu yg diperbarui daripada 1st generasi SVT..slightly more power and torque gain...kenapa blacktop mamtap..ok..blacktop has lightened internals including its crackshaft, flywheel, pistons, factory port polish head, camshaft and improved ecu system..as well as MAP sensored as its main manifold control in sucking all the juicy air into the combustion chambers.as we all know the MAP sensor when in terms of function when it sucks it will nvr stops..decresed voltage signal to the ECU to comprensate absolute pressure in the intake manifold .thats why can open throttle .guys lets see the diffrent in block design..this is very critical ok...if both of you observe clearly the ribs on the block on each 20valver 4AG...actually the svt is the one suit for the turbocharging mechanism...7 ribs on the block..and actually a strengthened 4AGZE block! able to withstand a massive 350hp system! the BT has 6 ribs and the designed a little alter suit for it ligthened internals...for my opinion,,as experience with Bill Sherwood hehe...the SVT is the engine if turbocharging or supercharging system is apply:) see around in the web too...there is a monster supercharge 20v svt and turbo charge svt which eats vtec for breakfast..... |
colvinae101 FRESHIE
| Subject: Re: Minta pendapat engine 4AG 29/6/2008, 10:50 pm | |
| and for piston..pop in the 4aGZE piston into the 20v svt block...fit just like a d**k in the V****a.....no problem... |
| Subject: Re: Minta pendapat engine 4AG 30/6/2008, 1:44 am | |
| A very good explaination from colvinae101, just imagine the 16V 4AG turbo spec with AR70 as a booster, with a full spec of stage 3 modification, such power is fitted to a Toyota KE-70, then come this car with the same spec as mention above but with Black top, but with stronger long saft, i think it will easily outrun the 16V or maybe 3SGTE... fuh!! Dang....!!! |
colvinae101 FRESHIE
| Subject: Re: Minta pendapat engine 4AG 30/6/2008, 8:07 pm | |
| y not try a hybrid engine still with the 4AG series? NA which can broke the foot of the turbo charge 4AG ... my toy now with my dad is the hybrid 4 ag hi-compression head system AKA plug sorok head..with the bottom and block from SVT..y the hell i go for SVT? this is my personal selection...love SVT....even though blacktop has 5 hp more but the SVT block is more rigid and stronger compared ligthened BT block but this two block still cast iron block the last of its kind cos now toyota more using aluminium block for it performance engine replacing the 4ag iron block ..the 2zzge vvtli ...it didnt mind for me...how much horsepwer is not the matter but how efficient the engine will become is more important for me..last year project was to fit into ke70 a block from 20v SVT and head from the AE92 hi comp ..married happily with 4 throttle intake from svt...a little wiring setup and fuel controller piggyback from apexi..it runs fine..fix apexi neo in it which able to calculate Hp calcualte producing a hefty 162HP guys!!! standard parts inside.! but now its already mature with toda parts into with toms tecs ecu...result 203hp....rev 8700rpm with 18.3kg-ib of torque NA only..can kill torbocharge 4AG with minimal workout:) |
| Subject: Re: Minta pendapat engine 4AG 30/6/2008, 8:30 pm | |
| WOW! with these 203Hp on dyno with NA.... to your successful project |
colvinae101 FRESHIE
| Subject: Re: Minta pendapat engine 4AG 2/7/2008, 7:48 pm | |
| interested in AE101 4AGZE...but no half cut:( |
| Subject: Re: Minta pendapat engine 4AG 2/7/2008, 7:58 pm | |
| - colvinae101 wrote:
- interested in AE101 4AGZE...but no half cut:(
for me, i cant afford to look into it bro... but maybe someone here does... stuck with my iswara.. huhu |
| Subject: Re: Minta pendapat engine 4AG | |
