| Apa punca Top Speed menurun? | |
Age : 46 location : SU, SA, SB Points : 12008 Reputation : -1 Number of posts : 6286
| Subject: Apa punca Top Speed menurun? 29/7/2008, 10:59 pm | |
| harap otai-otai redline dpt beri pendapat serta tunjuk ajar yg berguna..MANTAP!!?!! Hope the old timers can share their knowledge for the good benefits to all automotive enthusiast..MARVELOUS!!?!! |
Age : 42 location : Semporna / Tawau / Lahad Datu / Flamingo / Putatan Points : 12494 Reputation : 3 Number of posts : 1106
| Subject: Re: Apa punca Top Speed menurun? 30/7/2008, 7:57 am | |
| kalau enjin NA top speed menurun berpunca dr gearbox juga ratio tinngi digear 5 boleh menurun top speed keta tu, sebab tu apabila sdh top speed digear 5 lama2 drop pi gear 4 juga tu |
| Subject: Re: Apa punca Top Speed menurun? 30/7/2008, 8:10 am | |
| Biasanya wear & tear enjin punya masalah utamanya nie, it's time to do top overhaul or major overhaul, mungkin dalaman enjin suda longgar² suda atau gearbox lama tidak diservis, ini biasanya berlaku kepada transmission auto, lama kelamaan D2/OD tidak akan berfungsi... just my two cents |
RBN76 SUPERIOR
Age : 46 location : ANYWHERE AND ANYTIME Points : 11755 Reputation : 0 Number of posts : 2142
| Subject: Re: Apa punca Top Speed menurun? 30/7/2008, 8:16 am | |
| ini mesti kacau itu fly wheel ni..ataupun lama inda service ataupun air filter sumbat ataupun wiring spark plug putus ataupun alternator mo hangkang ataupun ataupun valve suda haus ataupun piston ring sudah haus ataupun spark plug suda mati..kekeke |
te37 MODERATOR
Countries/State : Age : 37 location : Kota Kinabalu - Keningau Tag ID: : SFC 02132 Points : 12190 Reputation : 0 Number of posts : 2660
| Subject: Re: Apa punca Top Speed menurun? 30/7/2008, 9:43 am | |
| besanya mo overhaul engine & servis gearbox.. |
Rojakman FRESHIE
Age : 46 location : Sabah Points : 11897 Reputation : 0 Number of posts : 64
| Subject: Re: Apa punca Top Speed menurun? 30/7/2008, 11:36 am | |
| Automatic - torque converter mau mau hangus Manual - tgk clutch lining |
ikankalui PARTNER
Countries/State : Age : 47 location : Putatan-Kota Kinabalu Website : www.dcl2u.webs.com Points : 12209 Reputation : 0 Number of posts : 1209
| Subject: Re: Apa punca Top Speed menurun? 30/7/2008, 3:27 pm | |
| itu injin hangkang suda...time utk masuk injin baru |
devilboy7 SENIOR
Countries/State : Age : 47 location : kk Points : 11614 Reputation : 0 Number of posts : 983
| Subject: Re: Apa punca Top Speed menurun? 30/7/2008, 4:35 pm | |
| let me see...kali kreta terlampau berat da...downforce kacau top speed jg kadang2..tu la elak guna spoiler unless diperlukan ja..kira tu jak la sy tau...hhuhuh.. |
| Subject: Re: Apa punca Top Speed menurun? 30/7/2008, 5:39 pm | |
| pendapat saya~ memang banyak oh:
bahagian ENGINE- walaupun kita jaga engine macam emas, seperti tukar engine oil yang bagus setiap masa, tukar fuel filter, oil fitler, air filter, isi petrol mahal pun pandai wujudnya carbon di dalam engine. kotoron yang terdapat dalam engine juga boleh menyebabkan kurangnya kuasa. Timing valve sudah lari, air/fuel ratio pun lari. piston ring pun mungkin bermasalah menyebabkan combustion tidak cantik, juga spark plug cable yang sudah wear.
bahagian Electronic- setiap kereta pun memang ada wayar wayar, wayar yang sudah lama ataupun sedikit rosak, alternator yang sudah tak cantik, body yang berkarat tidak dapat transfer earth dengan baik juga mempengaruhi top speed.
chasis and gearbox: Flywheel yang sudah lama, biasanya flywheel pendek nyawa sebab clutch tidak tukar ikut masa, kalau selalu ta luk kereta itu pun pandai juga. gearbox minyak tidak kira auto atau manual, tidak tukar ikut masa, kotoran dihasil dan gear atau bearing sudah mula rosak. drive shaft joint kalau sudah lama pun pandai effect. axle atau lsd juga, kena tukar minyak differential setiap masa untuk kurangkan kotoran dan kerosakan.
Wheel: Rim yang sudah bengkok, tayar yang sudah tidak balance, thread tayar yang tidak sesuai untuk kelajuan tinggi, saiz dan sebagainya.
lain lain:~~ Driver sudah gemuk, meter cable hangkang.... dan driver takut drive sampai topspeed, wakakaka!!
itu saja yang saya ingat... |
codeng SUPERIOR
Age : 40 Points : 12035 Reputation : 0 Number of posts : 2370
| Subject: Re: Apa punca Top Speed menurun? 30/7/2008, 6:20 pm | |
| **lain lain:~~ Driver sudah gemuk, meter cable hangkang.... dan driver takut drive sampai topspeed, wakakaka!!** wah pedas, terasa aku.... |
| Subject: Re: Apa punca Top Speed menurun? 30/7/2008, 7:04 pm | |
| codeng... jangan gitu, saya sendiri pun rasa pedas.. wakaka |
kelisa_hitachi REGULAR
Age : 41 location : keningau~kk Tag ID: : TAG ID : SFC 03153 Points : 11759 Reputation : 0 Number of posts : 315
| Subject: Re: Apa punca Top Speed menurun? 30/7/2008, 9:13 pm | |
| aku sokong apa yg pioneer ckp tuh...benar!!! |
pgmohdshukri FRESHIE
Age : 42 location : Penampang, SABAH Points : 12206 Reputation : 0 Number of posts : 48
| Subject: Re: Apa punca Top Speed menurun? 31/7/2008, 4:38 pm | |
| tp kan.......klau aku lah......:- > mula2x memang rasa laju...psl baru drive tu kreta.... > lepas tu, klau sdh terlampau slalu drive tu kreta...makin lama makin slow lah rasanya... > lg satu, paling rasa speed kreta tu kurang sdh apabila kreta yg kamu pandu tu sdh tdk dpt overtake kreta lain apabila kamu cuba mau menunjukkan kekuatan dan ke speedan kreta kamu tu..... > Last but not least, of courselah kreta tu sdh lama tdk kena service and all that..... |
| Subject: Re: Apa punca Top Speed menurun? | |
