Info about Camshaft Facebo10
 Info about Camshaft
blugu
blugu
Tag ID: : SFC02202
Number of posts : 2945
Info about Camshaft Empty
PostSubject: Info about Camshaft   Info about Camshaft Icon_minitime21/8/2008, 10:09 am
Camshaft
From Wikipedia, the free encyclopedia
Info about Camshaft 180px-Nockenwelle_ani
The camshaft is an apparatus often used in piston engines to operate poppet valves. It consists of a cylindrical rod running the length of the cylinder bank with a number of oblong lobes or cams protruding from it, one for each valve. The cams force the valves open by pressing on the valve, or on some intermediate mechanism, as they rotate.
A camshaft
Timing
The relationship between the rotation of the camshaft and the rotation of the crankshaft is of critical importance. Since the valves control the flow of air/fuel mixture intake and exhaust gases, they must be opened and closed at the appropriate time during the stroke of the piston. For this reason, the camshaft is connected to the crankshaft either directly, via a gear mechanism, or indirectly via a belt or chain called a timing belt or timing chain. In some designs the camshaft also drives the distributor and the oil and fuel pumps. Also on early fuel injection systems, cams on the camshaft would operate the fuel injectors.
In a two-stroke engine that uses a camshaft, each valve is opened once for each rotation of the crankshaft; in these engines, the camshaft rotates at the same rate as the crankshaft. In a four-stroke engine, the valves are opened only half as often; thus, two full rotations of the crankshaft occur for each rotation of the camshaft.
Duration
Duration can often be confusing because manufacturers may select any lift point to advertise a camshaft's duration and sometimes will manipulate these numbers. The power and idle characteristics of a camshaft rated at .006" will be much different than one rated the same at .002". Whenever duration is quoted, be sure to note the lift at which it is given.
Many performance engine builders have learned to gauge a race profile's aggressiveness by looking at the duration at .020", .050" and .200". The .020" number determines how responsive the motor will be and how much low end torque the motor will make. The .050" number is used to estimate where peak power will occur, and the .200" number gives an estimate of the power potential.
In general, duration determines how many crankshaft degrees a camshaft maintains more than a given tappet lift.
Camshaft position
Depending on the location of the camshaft, the cams operate the valves either directly or through a linkage of pushrods and rockers. Direct operation involves a simpler mechanism and leads to fewer failures, but requires the camshaft to be positioned at the top of the cylinders. In the past when engines were not as reliable as today this was seen as too much bother, but in modern gasoline engines the overhead cam system, where the camshaft is on top of the cylinder head, is quite common. Some engines use two camshafts each for the intake and exhaust valves; such an arrangement is known as a double or dual overhead cam (DOHC), thus, a V engine may have four camshafts.
Maintenance
The rockers or cam followers sometimes incorporate a mechanism to adjust and set the valve play through manual adjustment, but most modern auto engines have hydraulic lifters, eliminating the need to adjust the valve lash at regular intervals as the valvetrain wears, and in particular the valves and valve seats in the combustion chamber.
Sliding friction between the surface of the cam and the cam follower which rides upon it is considerable. In order to reduce wear at this point, the cam and follower are both surface hardened, and modern lubricant motor oils contain additives specifically to reduce sliding friction. The lobes of the camshaft are usually slightly tapered, causing the cam followers or valve lifters to rotate slightly with each depression, and helping to distribute wear on the parts. The surfaces of the cam and follower are designed to "wear in" together, and therefore when either is replaced, the other should be as well to prevent excessive rapid wear. In some engines, the flat contact surfaces are replaced with rollers, which eliminate the sliding friction and wear but adds mass to the valvetrain.
Info about Camshaft 4-Stroke-Engine
Double overhead cams control the opening and closing of a cylinder's valves.
Info about Camshaft 100px-Nockenwelle_2005
Info about Camshaft Magnify-clip
A camshaft
tony84
tony84
Tag ID: : SFC 02317
Number of posts : 1300
PostSubject: Re: Info about Camshaft   Info about Camshaft Icon_minitime23/8/2008, 9:11 am
bro...mcm mana mau tau cam tu standart atau hi cam????
blugu
blugu
Tag ID: : SFC02202
PostSubject: Re: Info about Camshaft   Info about Camshaft Icon_minitime25/8/2008, 10:29 am
Sy pun tidak pasti o bro...
tapi sy nak share info skit disini....
http://www.junauto.co.jp/products/cylinderhead-part/camshaft/index.html?en << JUN
http://todaracingusa.com/category?section=product&cid=22&id=10?section=product&cid=22&id=10 <<< TODA RACING
tony84
tony84
Tag ID: : SFC 02317
PostSubject: Re: Info about Camshaft   Info about Camshaft Icon_minitime25/8/2008, 2:41 pm
wahsei...benggong sya baca....good info... Very Happy
Ujang87
Ujang87
Number of posts : 1899
PostSubject: Re: Info about Camshaft   Info about Camshaft Icon_minitime25/8/2008, 3:05 pm
ui..dmana murah mau dpt ni brg..powerzone gila2 harga dia..heheheh
blugu
blugu
Tag ID: : SFC02202
PostSubject: Re: Info about Camshaft   Info about Camshaft Icon_minitime25/8/2008, 4:53 pm
Try cek brand pipercam, di FTZONE dlm lelong.com
tony84
tony84
Tag ID: : SFC 02317
PostSubject: Re: Info about Camshaft   Info about Camshaft Icon_minitime26/8/2008, 9:14 am
ya...pipercam yg paling murah setakat ni....tp sayang xda vr4 punya...proton jah yg ada..sama 4g9x.....huhuh...
pioneer_syntium
pioneer_syntium
location : Semporna / Tawau / Lahad Datu / Flamingo / Putatan
Number of posts : 1106
PostSubject: Re: Info about Camshaft   Info about Camshaft Icon_minitime3/9/2008, 8:33 pm
pakai racing cam kelford la alang2 tapi harga pon alang2 Laughing
racing cam mat speed bagi enjin L2 degree 282/282 pon baru harga RM 950 Laughing
nomo
nomo
Number of posts : 98
PostSubject: Re: Info about Camshaft   Info about Camshaft Icon_minitime4/9/2008, 9:06 am
single cam lebih murah baa berbanding yang twincam.
blugu
blugu
Tag ID: : SFC02202
PostSubject: Re: Info about Camshaft   Info about Camshaft Icon_minitime4/9/2008, 3:47 pm
Itula kelebihan SOHC, barang performance murah berbanding dgn DOHC, cuma perbezaan HP diantara kedua-dua enjin nie, lebih kepada DOHC pale
nomo
nomo
PostSubject: Re: Info about Camshaft   Info about Camshaft Icon_minitime5/9/2008, 10:18 am
tu hari saya ada tanya kat powerzone twincam tu kelisa mau RM2k+, kalau trade in bayar dalam rm1K+ aja.
blugu
blugu
Tag ID: : SFC02202
PostSubject: Re: Info about Camshaft   Info about Camshaft Icon_minitime10/9/2008, 11:48 am
More info about camshaft setting(this is done by the use of Adjustable cam pulley for easier adjustment);
A typical std valve timing is 20deg-50deg /
50deg-20deg. A typical sport camshaft suited for both manual and
automatic gbox would be about 25 - 65deg/70 - 20 deg (270deg duration)
Std camshaft lifts about 23% of the valve diameter when racing
camshft can lift up until 35% of the valve diameter. The best airflow
happens when the valve is about 29-31% of the valve diameter. The gain
with more valve lift is that with fast opening and closing but
moderate(relatively) durations and overlap you get a wide torque range
without scarifying top end power......
Hurmm... to make it simpler..
ADVANCE : increases the time the intake valve is open during the
downstroke of the peston.. therefore inhaling a greater fuel/air
mixture and allowing more compression time, which is especially noticed
at the low rpm. I dont believe this is as rpm dependent *as retarding
the cam and low rpm power is increased by the timing at which the
mixture is drawn in.
However, at high rpm, the exhaust valve plays a larger role in
power. Since u also have closed the exhaust valve earlier, diminished
scavenging and top end power will decrease.
RETARDING : By diminishing the time at which the valve is open on
the downstroke and essentially slightly lowering the compression, u
will decrease low end power, yet increase top end power by a greater
amount of scavenging at high rmp. *** A good exhaust is mandatory for
this setting....
Info from Super91 at other forum
Info about Camshaft
