Countries/State : Age : 35 location : Kota Kinabalu Tag ID: : SFC 01287 Points : 13567 Reputation : 34 Number of posts : 5595
| Subject: oil catch tank 21/8/2008, 10:46 pm | |
| oil catch tank yang berjenama, dan oil catch tank yang biasa punya apa beza? |
Countries/State : Age : 45 location : Kota Kinabalu-Putatan Tag ID: : SFC02202 Points : 12177 Reputation : 10 Number of posts : 2945
| Subject: Re: oil catch tank 22/8/2008, 7:30 am | |
| - FYI, installing an OCT and engine breather can keep the intake manifold
and throttle body clean in long term. This is particularly impostant for
the Wira 1.3/1.5, Satria GTi with a Siemens-VDO ECU, which uses a
contaminant sensitive throttle body.
I personally recommend to install one. DIY constructing one will be much
cheaper.
This is my modified cusco-look-alike OCT, intercepting the PCV hose. A
breather is also installed, terminating the connection to the intake hose.
OCT: http://drexchan.fotopic.net/p18359799.html
Breather: http://drexchan.fotopic.net/p18359798.html
- Oil catch tank (OCT) is recommended to use when N/a car have problem of engine eat oil. For track car is a must to install. This OCT will catch the oil vapour in blow by gas (gas that pass through piston ring into crank housing and this gas will be take out by PCV valve to trottle body connected by a hose called PCV hose). If u ur engine eat oil, then those oil will ended up at ur trottle body and sludge will build up ur trottle body. Effiency of trottle body will decrease.....
Got this info from the other forum, most of the forumner prefer to DIY theirself for making an OCT, so... the conclusion, it doesn't matter either you want to buy a branded one or campalang one, as long as the OCT works with no leak. Maybe the branded looks nicer because of the brand value, for me, better get a campalang one, as long as the OCT works, it was good enough for me.
My 2 cents. |
Countries/State : Age : 32 location : Kota Belud Tag ID: : SFC 02544 Points : 12650 Reputation : 13 Number of posts : 16246
| Subject: Re: oil catch tank 22/8/2008, 5:54 pm | |
| da bza jga rpanya..pkirkn lbh krg ja..hihi..prlu bnyk lg aku nie bljr.. |
| Subject: Re: oil catch tank 22/8/2008, 5:57 pm | |
| oh gitu, pakai breather sama oct sama saja ba kan? ada effect performance atau maintainance ka? |
tony84 CONTRIBUTOR
Countries/State : Age : 39 location : org twu/stay d kgu/jln2 d kk Tag ID: : SFC 02317 Points : 12292 Reputation : 9 Number of posts : 1300
| Subject: Re: oil catch tank 23/8/2008, 9:08 am | |
| oil catch tank ni saya rasa lebih sesuai dgn enjin yg berturbo....sebab enjin lebih byk minyak berlebihan keluar balik ke manifol apabila kita tarik tarik....minyak ini akan buat tb jd kotor... |
| Subject: Re: oil catch tank 23/8/2008, 9:14 am | |
| setahu saya, kancil 660 850 standard pun mesti mahu pasang breather atau oct, sebab itu minyak naik terus kena filter, hitam terus tu filter haha |
Countries/State : Age : 35 location : Kota kinabalu,sabah Website : https://www.facebook.com/profile.php?id=100002328674361 Tag ID: : 00735 Points : 13731 Reputation : 24 Number of posts : 7994
| Subject: Re: oil catch tank 23/8/2008, 10:32 am | |
| aku punya kena psg benda ini juga ka? |
kelisa_hitachi REGULAR
Age : 41 location : keningau~kk Tag ID: : TAG ID : SFC 03153 Points : 11713 Reputation : 0 Number of posts : 315
| Subject: Re: oil catch tank 23/8/2008, 11:52 am | |
| kalu turbo kene pakai jg???setau aku..kalu turbo ni TB sentiasa clean coz masa ko tarik injector ko da tembak minyak utk clean kan TB...kalu ko p workshop mtk diorag cucui TB pun diorg tmbak mnyak kat TB ni... |
tony84 CONTRIBUTOR
| Subject: Re: oil catch tank 23/8/2008, 1:21 pm | |
| maksud minyak bukan minyak petrol....enjin oil bah.... |
| Subject: Re: oil catch tank 25/8/2008, 10:20 am | |
| - kelisa_hitachi wrote:
- kalu turbo kene pakai jg???setau aku..kalu turbo ni TB sentiasa clean coz masa ko tarik injector ko da tembak minyak utk clean kan TB...kalu ko p workshop mtk diorag cucui TB pun diorg tmbak mnyak kat TB ni...
Ini mesti pakai extra injector nie... org komfius cara penyampaian ko ni bro... |
tony84 CONTRIBUTOR
| Subject: Re: oil catch tank 25/8/2008, 2:37 pm | |
| haha...itu lah...bahaya bro kelisa_hitachi nie.... |
tony84 CONTRIBUTOR
| Subject: Re: oil catch tank 25/8/2008, 2:40 pm | |
| ini brg saya pun ada pakai...tp mcm lum ada pa2 berubahan dlm tangki ni.....pernah saya nampak kat invader pasang...3 ari sudah penuh tangkinya....huhu....sya rasa keta diesel lebih sesuai ni benda,.....hehe... |
mad4toy JUNIOR
Countries/State : Age : 44 location : Brunei Points : 11557 Reputation : 3 Number of posts : 151
| Subject: Re: oil catch tank 25/8/2008, 9:16 pm | |
| i think installing branded or not, you'll be safe for this one i cant notice the difference between branded with non branded |
apink_silika JUNIOR
Age : 36 location : labuan Points : 11480 Reputation : 0 Number of posts : 118
| Subject: Re: oil catch tank 31/8/2008, 10:55 pm | |
| - mad4toy wrote:
- i think installing branded or not, you'll be safe for this one
i cant notice the difference between branded with non branded 8) ....ermmmm..... |
| Subject: Re: oil catch tank 1/9/2008, 11:39 am | |
| ohh so, not worth to buy branded 1 cos same thing wat... better buy chap ayam 1 lo like that hehe... buy expensive punya mean buy brand only. |
mad4toy JUNIOR
| Subject: Re: oil catch tank 2/9/2008, 2:28 am | |
| yup its true, remember the old day at racing? even the orang putih use this method, i just wish i have the picture to shares with you guys
they just use bekas botol oren campur! last time i saw this in one of the drag car in miri this year! using botol oren campur, nanti aku check mana tau ada gambar nya |
mad4toy JUNIOR
| Subject: Re: oil catch tank 2/9/2008, 10:51 am | |
apink_silika JUNIOR
| Subject: Re: oil catch tank 2/9/2008, 2:18 pm | |
| xiaomao punya diy pun cantik, pakai fuel filter... hehe |
gryphoon81 JUNIOR
Countries/State : Age : 42 location : Putrajaya Website : www.bloggermiey.com Points : 11456 Reputation : 0 Number of posts : 113
| Subject: Re: oil catch tank 3/9/2008, 10:34 am | |
| Bro please show me step by step DIY OCT for perodua viva 1.0 & kancil 850 (lampu petak) |
| Subject: Re: oil catch tank 3/9/2008, 5:17 pm | |
| - gryphoon81 wrote:
- Bro please show me step by step DIY OCT for perodua viva 1.0 & kancil 850 (lampu petak)
senang saja bro, cuba cari hose yang connect dari engine valve cover tu intake. buang itu hose, pakai stopper getah sumbat itu intake sana, kemudian beli air breather (air filter yang kecil tu) sambung pada engine valve cover. |
| Subject: Re: oil catch tank 3/9/2008, 5:46 pm | |
- xiaomao punya diy pun cantik, pakai fuel filter... hehe
aku punya pun perlu pakai oil catch tank ka??? |
| Subject: Re: oil catch tank 3/9/2008, 5:49 pm | |
| kalau boleh pakai ja lah lebih bagus... taiwan punya rm100+ saja ma |
| Subject: Re: oil catch tank 3/9/2008, 6:06 pm | |
| mcm mana sambung?aku ada 1 hos ja...itu kena pakai dua hos kan.. |
gryphoon81 JUNIOR
| Subject: Re: oil catch tank 4/9/2008, 8:55 am | |
| kalau ada image utk psng kat viva lagi cun... |
| Subject: Re: oil catch tank | |
