nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Facebo10
Altec90
SUPERIOR
SUPERIOR
Altec90
Tag ID: : SFC 02424
Number of posts : 1890
nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Empty
PostSubject: nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge   nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Icon_minitime1/9/2008, 12:11 am
Hai there, i want to ask about installing air fuel ratio gauge, is that require any adapter? like water temp/ oil temp those?
This Gauge contain 4 wires, which is Orange, Black, Green, Red.
I know about black = ground, Red and orange should be + / Ignition/ Dimmer Light/ Light On/, red should be + charge current, And Green wires should be o2 sensor, and Air/Fuel Ratio use for.
F.Y.I I'm using Waja 4G18 model, which known most makan minyak kerita at malam or pagi, and mostly eat when open aircond, and crusing about 90km/h and so on. hahaha!! So that green wire, any Cip/Otai/Sensei/ Master can teach me?? about that wires where should i connect to? find from that computer box? or fuse? or? LOL i dont know.? any clue? Suspect Suspect
http://www.friendster.com/alteckevin
Altec90
SUPERIOR
SUPERIOR
Altec90
Tag ID: : SFC 02424
PostSubject: Re: nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge   nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Icon_minitime1/9/2008, 10:16 am
under18crew wrote:
mmg lh kuat mkn mnyk klu pkai aircond lg..hihi..cri fuse box lh..
betul kah tidak ohh bro?? setahu aku fuse pandai transmite wave(data) kahh? current jak bah. Suspect
Nieto
Nieto
Tag ID: : SFC 01287
Number of posts : 5595
PostSubject: Re: nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge   nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Icon_minitime1/9/2008, 11:34 am
lol air fuel ratio ah, bukan senang mahu pasang oh....
under18crew
under18crew
Tag ID: : SFC 02544
Number of posts : 16246
PostSubject: Re: nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge   nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Icon_minitime1/9/2008, 1:10 pm
ko mau smbg apa?wyar yg mna?bkn sng mau psng 2 barang..
Nieto
Nieto
Tag ID: : SFC 01287
PostSubject: Re: nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge   nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Icon_minitime1/9/2008, 1:19 pm
saya rasa air fuel gauge ini tak boleh diy... jus my 2 cent.
Nieto
Nieto
Tag ID: : SFC 01287
PostSubject: Re: nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge   nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Icon_minitime1/9/2008, 2:21 pm
biasanya air fuel meter ini, sesuai tuned car sahaja, untuk monitor mixture lean or rich. kalau kereta standard ini memang tidak perlu punya.
sini ada link for installation
http://neptune.spacebears.com/cars/stories/scagauge.html
or
http://www.egauges.com/Defi/dg_install.html
Last edited by Nieto on 1/9/2008, 2:22 pm; edited 2 times in total (Reason for editing : http://www.egauges.com/Defi/dg_install.html)
red_didie
SENIOR
SENIOR
red_didie
Number of posts : 768
PostSubject: Re: nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge   nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Icon_minitime8/9/2008, 5:03 pm
buli2 suda bha si nieto nie..menan enjin suda ar..cun la nieto.. Very Happy
http://www.microntm.com
lentugi
lentugi
Number of posts : 1755
PostSubject: Re: nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge   nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Icon_minitime10/9/2008, 10:10 pm
kalau O2 sensor dia single wire senang pasang..
kalau yang triple sama 5 batang wire tu blum kaji lagi hehehe...
Cabotz lariiii
http://www.sioloon.com
Neo575
Neo575
Number of posts : 267
PostSubject: Re: nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge   nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Icon_minitime4/11/2008, 9:03 pm
kereta aku ada O2 sensor.. tapi nda tau mcm mn mo install.. member di semenanjung ramai yg dah pasang.. kita yg di KK ni teda ka yg expert mo pasang... tadi mmg aku sket lagi mo beli di FUJI..
http://profiles.friendster.com/daus
henzuemi
Number of posts : 14
PostSubject: Re: nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge   nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Icon_minitime2/10/2009, 1:45 pm
aku baru ja mau pasang di Gen 2 aku...dimna le dpt fuel ratio ni...di fuji brapa harga?
http:// <div id="cse-search-results&
Altec90
SUPERIOR
SUPERIOR
Altec90
Tag ID: : SFC 02424
PostSubject: Re: nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge   nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Icon_minitime2/10/2009, 6:27 pm
tia tau laa.. bgus beli afr ration with sensor come along, ada kereta tia support bab pakai wideband. macam my waja if use another sensor. if use back own sensor will kacao itu voltage. dan kalau terkacau salah reading di ecu pandai sott Sad
henzuemi
PostSubject: Re: nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge   nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Icon_minitime5/10/2009, 6:40 pm
kalau GEN 2 pn sama ka?
ada 4 wayer di senser tu,apa caler mau conect?
henzuemi
PostSubject: Re: nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge   nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Icon_minitime11/10/2009, 9:54 am
meter ai/fuel ratio dah selamat pasang...very esay....dah pasang di gen2..
mel@sagaburuk
Number of posts : 1
PostSubject: Re: nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge   nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Icon_minitime14/10/2010, 9:14 pm
berapa harga geng ni benda , kalau kita pasang boleh adjust tu air/fuel mix kah atau dia bagi reading saja
Kornurts
Kornurts
Website : Www.Sioloon.com[Low Profile Crew]
Tag ID: : SFC 15951
Number of posts : 8256
PostSubject: Re: nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge   nak tanya pasal pemasangan D.I.Y Air/Fuel Ratio gauge Icon_minitime16/10/2010, 9:29 am
tumpang tnya bro skalian.. meter reading air fuel ratio ne kgunaan dia utk apa?n yg reading utk o2 tu sama lean n rich apa fungsi?kancil carburator boleh pkai ka ne brg? cheers
SIOLOON FUN CLUB :: START YOUR ENGINE'S :: ACCESSORIES & D.I.Y-
