ckmoy007 CONTRIBUTOR
Countries/State : Age : 39 location : Kota Kinabalu Points : 12306 Reputation : 4 Number of posts : 1317
| Subject: SQ style ICE 19/5/2009, 8:19 pm | |
| lets talk about anything and everything about sq(Sound Quality) setup here... cheers and have a nice day. WELCOME TO THE SQ WORLD What is SQ? There's a misunderstanding that SQ(Sound Quality) is a system that can't play loud. Stock system also can't play loud but that's far from a real SQ system. So what is Sound Quality? SQ is that aspect of a sound system, which encompasses all of the performance factors which give the system the ability to re-produce an accurate and life-like rendition of the original recording as perfectly as possible. It includes factors such as tonality, ambience, subtle nuance, system gain structure, dynamics, transient response, and the list goes on and on. SQ is a combination of all these technical factors as well as proper speaker placement and proper system design. When a system is said to have perfect SQ, it generates the most accurate sound possible, with a sense of musical realism that gives the listener the impression that they "hear" a live performance right in front of them, as if the listener was in the audience watching the actual performers on an actual stage. Now, to get this realistic musical "sound stage" in a car, it takes careful system planning, speaker placement, and tuning. From the reputable car audio enthusiast http://teamaudionutz.com/a2.htm
| Subject: Re: SQ style ICE 19/5/2009, 8:46 pm | |
| bro rickengineering tanya apa brand yang sedap untuk main SQ... brand ada banyak. tahap yg SQ boleh dicapai ditentukan oleh budget, masa dan tuning skill. sebagai reference, ada beberapa brand yang keluarkan barangan yang famous di dunia SQ, list di bawah, segelintir saja, ada banyak lagi:
~dari Germany:
Rainbow Helix / Brax RS Audio MB Quart Micro Precision Eton
~dari England:
Genesis
~dari Israel:
Morel
~dari Sweden:
DLS
~dari Norway dan Denmark:
SEAS ( Norway ) Scanspeak Vifa Peerless Dynaudio
~dari Italy:
Sinfoni Audio Development Celestra Audison Audio System Hertz ~dari Spain: Beyma
~dari France:
Focal Audax
~dari USA:
Zapco TRU Technology Boston Acoustics Phoenix Gold PPI McIntosh Diamond Audio Image Dynamic Xetec Xtant
~dari Jepun:
Alpine F#1 Status Pioneer ODR (Optical Digital Reference) Clarion Sound Monitor Luxman Sansui Bewith Denon (HU) Nakamichi Anatomy of the Power Amplifier Dissecting the Modern Audio Power Amplifier and Power Supply By Robert Zeff (Designer of Zapco's amplifiers)
With the Proliferation of Different Amp Types, Which is the One for You? In the past we had essentially two types of amplifiers to choose from: Class "AB" and class "A". Today we have AB, A, D, G, H, & T, in addition to some that do not have a class name. New technology brought down the size and price while improving performance and efficiency. We'll review the various topologies of the modern amplifier, spending extra time on the aspect of efficiency (as the quest for smaller, more efficient designs have spawned the class D, G, H, & T designs). We'll also try to dispel some of the misconceptions and folklore that seem to surround amp design.
Amplifiers require circuitry for short and thermal protection, fan control, turn on delay, and over voltage protection. In the past we littered the designs with dozens of components to handle these events. Today we can use a single microprocessor to handle all of this in addition to having many more features without additional cost. The microprocessor can monitor the battery voltage, internal voltages, temperature, control volume and crossovers, and drive external displays. These embedded computer chips also allow features like compression and power limiting with little added cost. Of course, what is an amplifier without a power supply? First we'll visit the power supply designs, as every amplifier needs one.
The Power Supply The purpose of the supply is to convert the auto's battery voltage to a higher voltage. For example, if an amplifier is to produce 100 watts into a 4 ohm speaker, we need 20 volts RMS. This implies that we need about +/-28 volts. (20 volts R.M.S. = 28.28 volts peak). We call that the "rail" voltage. Since the amplifier's output transistors cannot pull all the way up to this rail, we actually need a slightly higher voltage.
The process is to convert the 12 volts DC into AC, feed it to a transformer and convert it back to DC again.
Converting the 12 volt battery voltage to AC is simple, a PWM (pulse width modulator) IC feeds a bank of MOSFETS (MOSFETs are switching transistors perfectly suited for this task).
The 12 volt power is switched at a very high frequency, somewhere between 40 and 150 kHz. Slower switching speeds require a larger transformer, but high speeds have more switching loss. Advanced transformer core materials, faster rectifiers, and clever winding methods have enabled us to utilize very high frequencies. Some of today's better amplifiers have very small power supplies that produce enormous amounts of power.
Regulated Power Supplies Most early audio amplifiers contained unregulated power supplies. Regulated supplies require very high quality filter capacitors (called "low ESR" capacitors), output chokes, and an optically isolated voltage feedback circuit. Regulation occurs by controlling the switching pulse width from 0 - 100% to compensate for changes in the battery and rail voltage. The same action occurs when the audio level increases. As the amplifier draws more power from the supply, the rail voltage drops. Again, the regulator circuitry senses this drop and responds with an increased pulse width.
The high frequency PWM waveform is rectified (converted to DC) and applied to the output filter choke and capacitors. This output of this circuit is the + and - DC rails that feed the power amplifier.
Unregulated Power Supplies Unregulated power supplies are less expensive than regulated supplies. They do not require an output choke, voltage sense or isolation circuitry. Because the duty cycle is nearly 100%, capacitor ripple current is much lower in unregulated supplies. Lower ripple current requires less expensive capacitors throughout.
Often we hear that unregulated designs have more "headroom". That means that the amplifier will produce extra power during transients. Most home audio amplifiers employ unregulated power supplies. The power supplies in these amplifiers run at 60 Hz, thus the filter capacitors must be 200-500 times larger than those used in high frequency switchers. The extra capacitance in home audio amplifiers results in extra headroom. Headroom for anything other than very short transients simply doesn't exist in the unregulated designs. The following is an example of specifications for an unregulated vs. regulated amplifiers.
Unregulated designs have a higher supply voltage at low power, causing higher voltage on the output transistors. This reduces the amplifier's efficiency.
Small amplifiers (less than 100 watts) cannot justify the extra cost of the regulation circuitry, so we often see unregulated supplies in these amplifiers.
Pros and Cons of Regulated / Unregulated SuppliesSome designers try to keep their supplies regulated down to battery voltages as low as 9.5 volts. The supply compensates by increasing the current. The following table shows voltage and currents for a 500 watt over-regulated amplifier operating at full power.
The current increases dramatically at the lower voltages. Because of higher currents at the lower voltages, the supply efficiency drops further, requiring even more current.
At higher voltages, the pulse width reduces, causing increased ripple current. This high current creates heat in the filter capacitors and can destroy the capacitor's electrolyte. Some manufacturers do not use capacitors of sufficient quality for this range of regulation. These amplifiers may not perform up to specification just one year after installation. Also, the extra current at low voltages is extra hard on a battery that is already suffering! So, we recommend that amplifiers stay in regulation down to about 11 - 11.5 volts. Any properly working charging system can easily keep the battery voltage well above this.
The Amplifier Section, Class AB and AClass AB and A amplifiers are similar, so we'll discuss both here. Class AB amplifiers have transistors that pull up to the positive rail and transistors that pull down to the negative rail. This corresponds to the action of pushing the speaker cone out and in.
Class AB means that the output transistors do not always have current on them. For example, when the upper transistors are pulling up towards the positive rail (pushing the speaker out), there is no current in the lower transistors. When the output signal swings through zero, towards the negative rail, the output transistor must go through a transition from zero current to a non-zero current. The best analogy that I can think of is driving an old car with too much slop in the steering. As you go from one side of the road's crown to the other, the steering crosses a "dead" zone, and you tend to over-steer. Special temperature compensated bias circuitry reduces this dead zone, known as notch distortion. The figure below shows the output of a class AB amplifier with too little bias and the resulting distortion. Notch distortion increases at higher frequencies and low volume levels. Some modern designs have reduced this type of distortion to very low levels.
Class A means that every transistor is always conducting current. They are very similar to class AB amplifiers, but the bias circuitry is set so that there are very high currents in the output transistors. Because these amplifiers do not have this "dead zone', less feedback is required to achieve low distortion.
A 100 watt amplifier may dissipate nearly 100 watts internally even when there is no audio output. This type of design is impractical in the harsh auto environment. Many class A amplifiers pedaled for the automotive market are not really class A. They are huge power wasters in the home as well.
Input and Driver Stages The amplifier works this way: A small audio signal is presented to the amplifier's input. Transistors are not linear, which means that the input signal will distort somewhat as it passes through the various amplifier stages. To correct this distortion, a portion of the output is compared with the input. The difference creates a correction signal reducing this distortion. The input stage is a special type, called "differential". It has a + and a - input because it must accept both the audio input and the input from the feedback circuitry. Excess feedback can lower distortion dramatically, but cause instability. Careful design rules must be followed to avoid this instability.
The output of the input stage feeds into the driver stage. The driver stage may use one, two, or three devices. Often this circuitry is referred to "Darlington", or "Triple Darlington". The driver circuit feeds the output stage, which may have two, four, six, or more transistors. The more output transistors, the better. Multiple output devices reduce distortion (requiring less negative feedback) and improve reliability.
Bipolar or MOSFET? We have seen both MOSFET (Metal Oxide Silicon Field Effect Transistor) and Bipolar transistors used in audio amplifiers. Claims have been made that each is superior. I have seen claims that MOSFETs have a tube ("Valve" for the Brits) sound. This is more folklore. The musicians and their instruments are supposed to have "the sound", not audio equipment! MOSFETs are tougher than Bipolars, and can pull closer to the supply rail. It takes more Bipolar transistors to achieve the same power as a MOSFET, therefore Bipolar amps tend to be more expensive. But, MOSFETs are very non-linear, compared to Bipolars and require much more feedback to achieve reasonable distortion numbers. They are a great choice for bass amps, as low frequency audio is not difficult for a MOSFET. The most expensive car and home amplifiers almost always use Bipolar transistors.
Efficiency What makes an amplifier get hot? Both the power supply and the power amplifier generate heat. The maximum efficiency of the power supply is nearly 100%. Good power supply designs, with the highest quality components approach 85%. The class AB amplifier efficiency at full power can approach 75%. The total efficiency, including the power supply, can be about 65%. But, efficiency drops at lower power and can typically be under 20%. A class AB amplifier actually runs cooler at full power than it does at half power. Run this amplifier into clipping and it might run even cooler! Where is all this power going? The output transistor is basically a large variable resistor. If the instantaneous output voltage should be 40 volts and the power supply is 100 volts, then 60 volts must be "wasted" in the output transistors. Driving a reactive load (like a speaker) causes the efficiency to drop ever further. This brings us to the other audio classes designed to improve efficiency.
Class D First, let's dispel another myth: Class D does not stand for digital. The input is converted to a two-state (binary) representation of the audio waveform. That's where the similarity ends. This distinction is important because class D doesn't provide the benefits normally associated with digital components.
That being said, class D designs dramatically improve efficiency. Instead of wasting power in the output transistor, the output is switched at a very high frequency between the positive and negative supply rails. If the output is to be zero, then the waveform is at a 50% duty cycle. If the output is to be a positive voltage, then the duty cycle would be greater than 50%. Because the output devices are either completely turned on (no wasted voltage) or completely turned off, theoretically efficiency is 100%. So the audio input must be converted to a pulse width modulated waveform (PWM). The yellow trace below is the output of the amplifier; the blue trace is the PWM waveform. The blue waveform is fed to an output filter, which results in the yellow output waveform. Notice that the output looks somewhat distorted. All of the switching noise and distortion cannot be removed and the result can be seen here. Because of this process of converting the input signal to PWM and converting back to analog, a good deal of distortion is introduced. Conventional feedback like that used in class AB designs is used in these amplifiers to reduce distortion.
MOSFETs are the only choice for class D designs. Most class D designs are useful only for bass amps as they can not switch fast enough to reproduce high frequencies. Some high quality, full range class D designs exist for pro audio, but they are complex with multi-phased outputs.
Class T Class T (Tripath) is similar to class D with these exceptions: This class does not use analog feed back like its class D cousin. The feedback is digital and is taken ahead of the output filter, avoiding the phase shift of this filter. Because class D or T amplifier distortion arises from timing errors, the class T amplifier feeds back timing information. The other distinction is that this amplifier uses a digital signal processor to convert the analog input to a PWM signal and process the feedback information. The processor looks at the feedback information and makes timing adjustments. Because the feedback loop does not include the output filter, the class T amplifier is inherently more stable and can operate over the full audio band. Most listeners can not hear the difference between class T and good class AB designs. Both class D and T designs share one problem: they consume extra power at idle. Because the high frequency waveform is present at all times, even when there is no audio present, the amplifiers generate some residual heat. Some of these amplifiers actually turn off in the absence of music, and can be annoying if there is too much delay turning back on.
Class G Class G improves efficiency in another way: an ordinary class AB amplifier is driven by a multi-rail power supply. A 500 watt amplifier might have three positive rails and three negative rails. The rail voltages might be 70 volts, 50 volts, and 25 volts. As the output of the amplifier moves close to 25 volts, the supply is switched the 50 volt rail. As the output moves close to the 50 volt rail, the supply is switched to the 70 volt rail. These designs are sometimes called "Rail Switchers". This design improves efficiency by reducing the "wasted" voltage on the output transistors. This voltage is the difference between the positive (red) supply and the audio output (blue). Class G can be as efficient as class D or T. While a class G design is more complex, it is based on a class AB amplifier and can have the same clean characteristics as well.
Class H Class H is similar to class G, except the rail voltage is modulated by the input signal. The power supply rail is always just a bit higher than the output signal, keeping the voltage across the transistors small and the output transistors cool. The modulating power supply rail voltage is created by similar circuitry that you would find in a class D amplifier. In terms of complexity, this type of amplifier could be thought of as a class D amplifier driving a class AB amplifier and is therefore fairly complex.
How to Choose? Regulated or unregulated? Class AB, D, or T?If you're really into a lot of bass, the class D or T may be for you as these amplifiers will produce the highest SPL with the smallest size. If you just want to wake the neighbors, blur your vision, or make a big splash in SPL contests, maybe you just need one of the inexpensive, powerful, & dirty class D designs. Want the cleanest high frequencies? Maybe a good class AB amp would be your selection. Whatever you choose, I hope this information helps you achieve the sound you're looking for!
| | | brena9767 JUNIOR
Age : 45 location : Penampang Points : 12170 Reputation : -2 Number of posts : 100
| Subject: Re: SQ style ICE 19/5/2009, 8:48 pm | |
| ok....my SQ system are HU : CD 1000 Eclipse Front Door Speaker : 2-way Component Velocity Blaupunkt Back Door Speaker: 3 way Alpine Woofer : DVC JBL 12 inches powered by Caliber Amp Sony Xplod 4 channel amp powering the door's speaker RCA cable from Soundstream n MTX N Phoenix Gold All door equipped with MBQ Sound Insulation plus i installed 1 set of cap Ayam DVD player for 7 inches in-dash monitor from Pyle....pakai tgok Blue...kakakakakakakaa |
| Subject: Re: SQ style ICE 19/5/2009, 8:53 pm | |
| hahaha, blue ada surround, mantap juga tu... lol. ur RCA rojak kao kao, semua diff brand. mau join kami punya SQ TT di 18 Julai ka? everyone is welcomed... |
| | | rickengineering SUPERIOR
Countries/State : Age : 42 location : Majlis Daerah Beluran Website : https://www.facebook.com/rickengineering Tag ID: : SFC 01950 Points : 13293 Reputation : 67 Number of posts : 2793
| Subject: Re: SQ style ICE 20/5/2009, 9:08 am | |
| thanx 4 de info bro ckmoy... sebenarnya sa berminat bha mo men sq juga ni... tapi betul2 sa tidak mampu... hu sq pun mahal... 2ch amp pun mahal... klu pakai brand cap ayam mesti bunyi comp set wpun yang mahal nda lawa kan. |
| Subject: Re: SQ style ICE 20/5/2009, 4:40 pm | |
| tak ada hal, bro.kalau tak mampu beli... join la TT dan dengar orang lain punya. tapi betul la, kalau betul betul mau main SQ tu, mmg mahal. yg cable dia tu sudah boleh capai beribu-ribu. i think di m'saya SQ paling murah tu Pegasus. banyak local yg guna tu, tapi i tak pernah dengar la. tak tau sedap atau tidak. untuk SQ, HU mmg important, kalau tiada HU yg mantap, SQ pun tak mantap. Rubbish in, Rubbish out.
| | | appleyard FRESHIE
Age : 46 location : KK Points : 11603 Reputation : 0 Number of posts : 9
| Subject: Re: SQ style ICE 20/5/2009, 6:05 pm | |
| | | brena9767 JUNIOR
| Subject: Re: SQ style ICE 20/5/2009, 7:53 pm | |
| memang betul tu HU mahal..bab tu la i mampu beli HU Eclipse yg termurah dalam line up model dia..CD 1000..tu pun RM488 ja... |
| | | finalazy84 MODERATOR
Countries/State : Age : 39 location : Keningau - KK Tag ID: : SFC 04901 Points : 15002 Reputation : 41 Number of posts : 3863
| Subject: Re: SQ style ICE 20/5/2009, 8:05 pm | |
| woh...m poisond ordy...masi lgi ta dpt make up my mind mo main mcm mna ni...hehe tpi klo mhl ni yg payah ni...buat loan la...haha |
| Subject: Re: SQ style ICE 20/5/2009, 9:25 pm | |
| - appleyard wrote:
- ckmoy
dont poison them.. just spreading the SQ poison la, haha... din know u oso hang out around here, bro. ur car ready for the TT d? bought which HU? |
| Subject: Re: SQ style ICE 20/5/2009, 9:30 pm | |
| - brena9767 wrote:
- memang betul tu HU mahal..bab tu la i mampu beli HU Eclipse yg termurah dalam line up model dia..CD 1000..tu pun RM488 ja...
no matter wat, the branded ones alwez sound better than the cap ayam china stuffs. di m'saya, barangan ICE mmg mahal, distributor semua potong leher. tengok blue dengan eclipse ni sudah cukup lo... haha. or should i say 'dengar' blue, ada SQ ba tu... imagine warm, laid back voice of the porn star, lol. |
| Subject: Re: SQ style ICE 20/5/2009, 9:35 pm | |
| - finalazy84 wrote:
- woh...m poisond ordy...masi lgi ta dpt make up my mind mo main mcm mna ni...hehe tpi klo mhl ni yg payah ni...buat loan la...haha
oh, itu sendiri mau fikir betul betul lo. mcm aku last time oso SPL, blast onli, but then i feel that i can't tahan for long, i prefer to enjoy music. once in a while blasting ok la, dats why i changed to SQ since i'm the one listening to my own music most of the time. SQ can oso go loud by the way, cuma bass kurang saja. SQ tu, kalau mau main, mesti pergi dengar system org lain supaya dapat idea mana jenis yg kamu suka. this coming TT is a gud opportunity. |
| | | onesensei WEBMASTER
Countries/State : Age : 36 location : Membakut - KK - Bangi - Shah Alam Website : http://onesensei.blogspot.com/ Tag ID: : SFC 03495 Points : 14019 Reputation : 75 Number of posts : 2551
| Subject: Re: SQ style ICE 20/5/2009, 9:47 pm | |
| - brena9767 wrote:
- ok....my SQ system are
HU : CD 1000 Eclipse Front Door Speaker : 2-way Component Velocity Blaupunkt Back Door Speaker: 3 way Alpine Woofer : DVC JBL 12 inches powered by Caliber Amp Sony Xplod 4 channel amp powering the door's speaker RCA cable from Soundstream n MTX N Phoenix Gold All door equipped with MBQ Sound Insulation plus i installed 1 set of cap Ayam DVD player for 7 inches in-dash monitor from Pyle....pakai tgok Blue...kakakakakakakaa bro..manada cap ayam ni Pyle.. jenama bagus ni~ http://www.pyleaudio.com/about.asp |
| Subject: Re: SQ style ICE 20/5/2009, 9:54 pm | |
| pyle ni mmg cap ayam bro... kole, MIX, AV Quart, AudioQuart, revenge digital dan lain2 lagi pun sama. cap ayam maksudnya bukan jenama tiruan, tapi quality yg kurang baik berbanding dengan branded. |
| | | brena9767 JUNIOR
| Subject: Re: SQ style ICE 20/5/2009, 10:24 pm | |
| itu Pyle hanya monitor...tak kisah asal boleh nampak muka pelakon biru tu...udah la...kakakaakakaaaaa...... |
| | | appleyard FRESHIE
| Subject: Re: SQ style ICE 22/5/2009, 12:37 pm | |
| - ckmoy007 wrote:
- appleyard wrote:
- ckmoy
dont poison them.. just spreading the SQ poison la, haha... din know u oso hang out around here, bro. ur car ready for the TT d? bought which HU? Trying to find someone who is going to Sibu and can buy me a P80 if not I might get 9887 local. After that reinstallation will begin and building a new box. Nah I dont hang out here a lot. Just looking around. I'm mostly in CA.com or realmofexcursion forum. |
| | | saa3479j JUNIOR
Countries/State : Age : 38 location : Pitas Website : mempakadlaut.pjk.com.my Points : 11344 Reputation : 0 Number of posts : 115
| Subject: Re: SQ style ICE 22/5/2009, 7:54 pm | |
| nak join ni bro... TT SQ nak buat dmana nanti? soal lain, saya juga gemar dengan SQ ni dlu saya guna nissan frontier main SQ la kunu. woofer 10inci MTX thunder 6000 ja ba 1 biji. box buat sendiri memanjang la kunu untuk kc muat kat belakang kerusi belakang. mid 4 biji jak semua lekat kat pintu (replace ori) main 6.5inci n 4inci brand MTX. player sony VCD tu yg murah2 ja. 4chnl 1, 2 chnl 1 kdua2nya brand usa bumper. besa2 ja ba bos mana da duit... |
| | | brena9767 JUNIOR
| Subject: Re: SQ style ICE 22/5/2009, 8:14 pm | |
| main SQ memang mahal...ni pun i tgah berkira nak pasang electronic crossover...tapi harga masih mencucuk langit...tunggu la nanti..bonus hujung tahun.... tapi as far as i know la..brand MTX ni sesuai main SPL sebab bunyi dia 'strong', padu n solid la.....dan kalau main sound SQ player dia mesti main 1 format ja...jenis non-visual / non-video playback...CD,MP3 dan sbgainya...keluar sound ja.. |
| Subject: Re: SQ style ICE 22/5/2009, 8:30 pm | |
| - brena9767 wrote:
- main SQ memang mahal...ni pun i tgah berkira nak pasang electronic crossover...tapi harga masih mencucuk langit...tunggu la nanti..bonus hujung tahun....
tapi as far as i know la..brand MTX ni sesuai main SPL sebab bunyi dia 'strong', padu n solid la.....dan kalau main sound SQ player dia mesti main 1 format ja...jenis non-visual / non-video playback...CD,MP3 dan sbgainya...keluar sound ja.. lebih baik kalau beli alpine 9887 yg baru untuk 1288 saja. semua function ada. tak payah bazir duit sama wiring lagi. |
| | | saa3479j JUNIOR
| Subject: Re: SQ style ICE 22/5/2009, 8:31 pm | |
| kira2 bos nak main MTX ba tu tapi saya da survey kat kl kira jalan2 la tu kunu.. tapi tu monoblock 600rms pun da menceca rm3k lebih... adui tak da harapan la ni nak main brand MTX. last2 saya tukar p main ameron ja kat avanza saya.. so skrg tak main lagi kat D-Cab... |
| Subject: Re: SQ style ICE 22/5/2009, 8:32 pm | |
| boleh join. sila tengok thread aku di 'planing' tu. akan tt d lintas. |
| | | saa3479j JUNIOR
| Subject: Re: SQ style ICE 22/5/2009, 8:38 pm | |
| emmm... mana dapat kut ni p main2 kat sana paling2 pun d tengok2 ja... ala bos saya ni beli pun harap gaji ja, mcm tak sanggup saya nak buat loan untuk main ni brg2... sedangkan skrg pun masih bujang habis bulan habis ja... blm kwin hehehehehehe........................................... kawin sama sound la kalau bgtu.... |
| Subject: Re: SQ style ICE 22/5/2009, 8:43 pm | |
| boleh, asalkan ada minat tu, boleh bagi fon number kat aku dan nanti bila ada tt akan call u. |
| | | saa3479j JUNIOR
| Subject: Re: SQ style ICE 22/5/2009, 8:48 pm | |
| brpa hr bln tu bos? barang2 brand pa jak yang main tu nanti? |
| Subject: Re: SQ style ICE 22/5/2009, 8:55 pm | |
| 18 julai. setahu aku, ada vifa, pioneer, dls helix, clarion, eclipse dan lain lain lagi. |
| | | Sponsored content
| Subject: Re: SQ style ICE | |
Similar topics | |
Similar topics | |
Page 1 of 40 | Go to page : 1, 2, 3 ... 20 ... 40 | |
Mahu Bincang Tentang?
Aktiviti Kelab Sioloon?
Mencari Yang Menarik?
