Info Hari ini Facebo10
 Info Hari ini
al_chehim
al_chehim
Number of posts : 15
Info Hari ini Empty
PostSubject: Info Hari ini   Info Hari ini Icon_minitime21/5/2009, 1:46 pm
Please
note and circulate...
Do not turn on A/C immediately as soon as you enter the car!
Please open the
windows after you enter your car and do not turn ON the
air-conditioning
immediately. According to a research done, the car dashboard,
sofa,
air freshener emits Benzene, a Cancer causing toxin (carcinogen- take note
of the
heated plastic smell in your car). In addition to causing cancer, it poisons
your
bones, causes anemia, and reduces white blood cells. Prolonged exposure
will
cause Leukemia, increasing the risk of cancer may also cause miscarriage.
Acceptable Benzene level indoors is 50 mg per sq. ft. A car parked indoors with
the
windows closed will contain 400-800 mg of Benzene. If parked outdoors
under
the sun at a temperature above 60 degrees F, the Benzene level goes up
to
2000-4000 mg, 40 times the acceptable level... & the people inside the car
will
inevitably
inhale an excess amount of the toxins.
It is recommended that you open the windows and door to give time for
the
interior to air out before you enter. Benzene is a toxin that affects your
kidney and liver, and is very difficult for your body to expel this
toxic stuff.
p/s Sampaikan walau sepotong ayat. Al_chehim
swordfishxox
WEBMASTER
swordfishxox
Countries/State : Perak
Tag ID: : SFC 04219
Number of posts : 4825
Info Hari ini Empty
PostSubject: Re: Info Hari ini   Info Hari ini Icon_minitime24/5/2009, 12:36 am
nape jarak2...
susah nk paham ni...
napster
napster
Countries/State : Selangor
Tag ID: : SFC 03920
Number of posts : 6364
Info Hari ini Empty
PostSubject: Re: Info Hari ini   Info Hari ini Icon_minitime26/5/2009, 5:26 pm
aku pun pening baca... klu leh cuba rapat2 kan ayat tu...
baca kat ni je la.. same je... double post dah topic ni >>> Dilarang Menghidupkan Penghawa Dingin Sebaik Menaiki Kereta
taktahu
taktahu
Countries/State : Canada
Tag ID: : 01370
Number of posts : 5398
Info Hari ini Empty
PostSubject: Re: Info Hari ini   Info Hari ini Icon_minitime26/5/2009, 5:29 pm
bikin takut taw.... hehehe
Info Hari ini Empty
Info Hari ini
SIOLOON FUN CLUB :: START YOUR ENGINE'S :: ACCESSORIES & D.I.Y-
